First post, by Vipersan
After receiving my quad flop board ..I set about building a disk based machine that could handle most formats.
It consisted of 4 floppy drives 1: 1.44mb 3.5" 2:720k 3.5" 3 1.2mb 5.25" and 4:360k 5.25"
Now I'm uncertain about the 720k ex Zenith Supersport drive as I'm not convinced it fully compliant with PC spec.
Nonetheless it did work with the quad-flop with a basic DOS os...
..so on to phase 2
The quad-flop was configured so I built up a Win98se system hoping the 4 floppy drives would just be 'picked up' during the build ..it was at this point I started to think I might have a faulty quad-flop or the MB-8500TTD mobo had compatibility issues with the card..
the install simply would not complete throwing up this error >>>> "While initializing device IOS:
Windows Protection error. You need to restart your computer."
After much pondering ..and hair tugging...I was getting to the point of giving up.
I watched Shelby and Phintage collector youtube vids many times over in case I missed something important...and came away none the wiser.
It looked like win98 only supported 2 floppy drives at most ?
I could NOT find any answers...until I discovered this link...
https://retroshack.net/2024/08/22/texelec-qua … er/#comment-621
Well at least it wasn't just me then.
I tried simply switching off the quad flop rom....and the 98 build completed WITHOUT the error...and drives A and B were listed.
I'm still uncertain about that 720k drive as it is unreliable and sluggish and gives a drive not recognised error ..press F1 to continue error at boot.
I re-ordered the drives so that windows only sees A:1.44mb .....and B:1.2mb.
The error at boot went away.
I have to assume the 720k 3.5" drive is not standard compliance thus doesn't play nice with 98se.
all in all it has been a frustrating couple of days....and I will have to follow retroshacks advice and fit a manual switch to enable/disable the quad-flop rom when using DOS or Win98se.
It would have been usefull to know these comliance issues when buying the card from TexElec.
I'm sure the creator of the card would have known....but I for one did not.
I doubt there would be a rom fix for this in the future...as the problem appears to lie with Win98...and built in limitations.
I hope this info will be helpful to anyone considering such a build.
rgds
VS
Comments/advice most welcome as always.
