Seagate Tools for DOS not loading
Reply 60 of 69, by Harry Potter
Well...it's out of Conventional memory, providing more Conventional memory for other programs.
Joseph Rose, a.k.a. Harry Potter
Working magic in the computer community
Reply 61 of 69, by DustyShinigami
Ahh, got you. Makes sense.
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
HDD: C, D - IDE 1, CD-ROM - IDE 2, E - IDE 3
Reply 62 of 69, by DustyShinigami
Not sure if command.com needs to be put in a particular place, but when I added it, it stopped everything else from loading properly after. Specifically the CD-ROM driver. Also, SHELLHIGH doesn't appear to work.
OS: Windows 98 SE
Reply 63 of 69, by Harry Potter
Oh.
Reply 64 of 69, by Harry Potter
Try adding it as the last command in CONFIG.SYS.
Reply 65 of 69, by DustyShinigami
Harry Potter wrote on 2025-11-06, 11:09:
Will do. Also, I added CuteMouse and it's working. No idea why it didn't last time.
OS: Windows 98 SE
Reply 66 of 69, by DustyShinigami
Is there a specific command that needs to be typed? Because if I put DEVICEHIGH=COMMAND.COM at the bottom, it stops doing anything. DOS no longer loads anything else; I get no text parser. Even Windows is prevented from loading.
OS: Windows 98 SE
Reply 67 of 69, by Harry Potter
Load COMMAND.COM using SHELLHIGH, not DEVICEHIGH. It's not a device driver but rather a command prompt. 😀
Reply 68 of 69, by DustyShinigami
Harry Potter wrote on 2025-11-06, 19:22:
Yeah, that's what I tried the other day, but it didn't recognise it.
OS: Windows 98 SE
Reply 69 of 69, by Harry Potter
Then I guess we have no choice but to keep COMMAND.COM in Conventional memory. 🙁 On a side note, if you use the command prompt more than occasionally, try DOSKEY. It's included with most versions of MS-DOS and adds support for better editing, macros and command history. There are also replacements online. I quickly looked online for them but can only find dosed520.zip at http://www.retroarchive.org/garbo/pc/cmdutil/index.html, but there are others.
