Amstrad Megapc advice
First post, by NightoftheRealm
I am working on a amstrad megapc that has had the battery leak and while i have the rest of the machine working really well including a megacard the machine cant find the floppy drive or a hard drive o have cleaned and fixed what traces i can find but still it resists me - can anyone tell me a way of splitting or adding a isa slot so o can run a xtide or isa drive controller along side the megacard?
Reply 1 of 3, by keropi
there must be broken connections under the FDD/HDD headers, the attached phot should help with finding them
I would recommend to remove both connectors and solder new ones
🎵 🎧 ⏳ ⚡ SoundVision PRO,MK1869 , PCMIDI MPU , OrpheusII , Megacard and 🎶GoldLib soundcard website
Reply 2 of 3, by NightoftheRealm
Thats beyond my level of skill is there a way of adding an extra isa slot?
Reply 3 of 3, by keropi
Not really, even if you would wire one there is no space left in the case...
