Best CGA & Hercules monochrome games
Reply 340 of 345, by Jo22
Hi! I didn't know that, I thoughts it's on auto-detect all time. Thanks for the tip! ^^
Btw, you can try installing an NEC V30. It should give 5 FPS, I think.
The upgrade itself is simple, but maybe you need to take care of using the right BIOS version, not sure.
I think there are tutorials/videos on how to upgrade an M24.
You can also avoid filling. That should cause more FPS. The switch is listed at the bottom.
Reply 341 of 345, by Kekkula
First thing I did when I got the machine working was I ordered v30, but it still haven't arrived.
I don't think it will make the game playable though. I think I'll try with my 486sx 🤔
Reply 342 of 345, by Grzyb
Kekkula wrote on 2025-05-24, 12:03:
8086 -> V30 speed increase is like 12%, so don't expect miracles...
In 2003, I voted in favour of joining the European Union. However, due to later developments - especially the restrictions on cash usage - I have withdrawn my support. DOWN WITH THE EU!
Reply 343 of 345, by Jo22
Though it may help with 3D routines a tiny bit, due to the way they work, how they run.
Similar to how the 68010 helped here (it had a tiny buffer which helped with code loops).
The 8086 had to calculate a addresses and jumps through ALU, had no dedicated unit for it.
Such calculations might be easier to V30, not sure.
The V-series has INS and OUTS commands for string operations, which can improve performance a lot.
- Provided that software makes use of it.
Unfortunately, I don’t know much about the The Colony engine.
Except that it pioneered colour graphics on Macintosh, sort of.
Does it support any FPU, for example? 🤷‍♂️
https://www.youtube.com/watch?v=i1XENlUUOhA
https://www.youtube.com/watch?v=3k3qrt76Ddk
https://www.youtube.com/watch?v=laqTN5xobVE
Edit: I've tried the game on my 4,77 MH XT with V20 CPU and VGA card (and 8087).
It was at around 2 FPS, I think. In EGA graphics mode (640x350 16c).
Given that the M24 runs at about twice the speed and has 16-Bit memory, it might end up running even better with a V30 processor.
I don’t know how quick the M24 graphics bord is, though.
Reply 344 of 345, by Benedikt
The DOS version of the game “Attack of the PETSCII Robots” apparently got a new, proper Hercules mode, recently.
It can be seen in action in this ”The 8-Bit Guy” video on the Hercules Graphics Cards: https://youtu.be/hblpFQ2ObCg?si=9IYH6Vcp0BJN0jo7&t=546
The games' original Hercules implementation, i.e. the one using hurriedly integrated CGA emulation, was actually by me, but this new version with customized artwork is clearly a lot more sophisticated.
Reply 345 of 345, by ediflorianUS
Benedikt wrote on 2025-10-29, 20:36:
Before "black-hawk-down" (my HDD going out in the Toshiba T3100e)
I can confirm " Attack of the PETSCII Robots " working fine on it, CGA , normal in-game rez on Mono Orange Plasma Display....(80286 , ibm cga specs closely related to jr).
My 80486-S i66 Project
