ISA Diamond SpeedStar 64 shows no signal
First post, by egbertjan
I received an ISA Diamond SpeedStar 64, which unfortunately doesn't display an signal. I've tried the card on various motherboards, from 486 to Pentium. What could be the reason for the lack of an signal? What often fails on this type of card, causing it to not display an image? Other ISA cards display perfectly fine on the motherboards I tested.
See the photos of my card.
The attachment 20251110_170537.jpg is no longer available
The attachment 20251110_170518.jpg is no longer available
Reply 1 of 40, by douglar
Check the tantalum capacitors for shorts. I bet you find one that’s taking a 5v or 12v power line to ground
Reply 2 of 40, by nuno14272
Re-set the Bios
Re-set the memory chips
Use multimeter to check the continuity in the tantalum capacitors
Clean the edge conector
check for bent pins ont the grapfic chip
1| 386DX40
2| P200mmx, Voodoo 1
3| PIII-450, Voodoo 3 3000
Reply 3 of 40, by MikeSG
I would reseat the BIOS a few times, take out the extra RAM chips temporarily.
Reply 4 of 40, by Grzyb
It's always a good idea to remove the BIOS chip, and try to read it in a programmer...
- if it reads, store the copy in a safe place - preferably let the entire world backup it for you 🤣
- if it doesn't, search for a copy...
Reply 5 of 40, by egbertjan
Thank you for all your good advice. Does anybody know which BIOS-chip is used on this card, so I can read it on my programmer? And where I can find the BIOS-file?
Reply 6 of 40, by weedeewee
egbertjan wrote on 2025-11-11, 14:43:
Don't know it by heart, but reading a normal 64k or 32k 27C512 or 27c256 series eprom will work just fune.
a bios file to compare against is available on theretroweb https://theretroweb.com/expansioncards/s/diam … tar-64-isa#bios
though if your version is a different version then comparing it won't be very helpful.
You say you do not get signal but you fail to mention if you can see/hear if your computer still boots.
Do not ask Why !
Reply 7 of 40, by douglar
weedeewee wrote on 2025-11-11, 14:52:
Or if the power supply fan spins.
If the power supply fan doesn't spin with the card in the system, then there's likely a tantalum capacitor short
If the mobo BIOS gives beep codes saying no VGA card, then the EEPROM rot is a likely culprit
If numlock light still works and you see floppy or storage activity, then I'd look at the card memory
Reply 8 of 40, by egbertjan
I tried the card on two different motherboards. There comes no post and the system doesn't boot and nothing to see on the monitor. I replaced the Speedstar with another videocard in the same slot. With both motherboards came a post and a correct boot. I also tested the card after removing two of the memorychips.
Reply 9 of 40, by weedeewee
egbertjan wrote on 2025-11-11, 18:16:
douglar wrote on 2025-11-11, 15:19:
Have you verified this ?
Do not ask Why !
Reply 10 of 40, by egbertjan
The power supply fan spins when the card is in
Reply 11 of 40, by egbertjan
It might also have something to do with the jumpers on the card. What's the best way to set the jumpers? I'm testing the card on a Pentium 60MHz board with socket 4.
Reply 12 of 40, by weedeewee
egbertjan wrote on 2025-11-11, 19:09:
The retro web entry has some documentation on the jumpers, though the identifications aren't the same, the positions seems to line up.
JP7 might be for using interrupt 2/9 or not
JP8 might be for 0 waitstates or not.
closed or open.
I doubt any of those jumpers will make a difference, though feel free to try.
out of curiosity, what markings are on the transistor right next to the label CR1, halfway in between D1 & C25 ?
Have you managed to read out the bios ?
Do not ask Why !
Reply 13 of 40, by egbertjan
weedeewee wrote on 2025-11-11, 19:37:
The retro web entry has some documentation on the jumpers, though the identifications aren't the same, the positions seems to li […]
closed or open.
Can you read the values ​​of the transistor on this picture of the card?
The attachment 20251111_204802.jpg is no longer available
The attachment 20251111_205311.jpg is no longer available
Reply 14 of 40, by weedeewee
egbertjan wrote on 2025-11-11, 19:51:
Can you read the values ​​of the transistor on this picture of the card? […]
closed or open.
Yes, Thanks.
I was wondering if it was some LDO voltage regulator.
ST LM334 L705 - Three Terminal Adjustable Current Source . 😐 no idea.
Any chance of getting a resistance measurment between GND&+5V, GND & +12V & (GND & -5v & GND & -12v if in use) ?
edit: if i'm counting correctly from the back of the card, only +5v is in use.
Do not ask Why !
Reply 15 of 40, by MikeSG
LM334 is the analog circuit voltage regulator
Reply 16 of 40, by MikeSG
Do both motherboards beep without a VGA card inserted?
If you take out the BIOS and two extra memory chips from the VGA card, does it beep?
Does it it beep after reinserting the BIOS?
Metal oxide build up on insertable chips is real
Reply 17 of 40, by egbertjan
nuno14272 wrote on 2025-11-11, 09:09:
Re-set the Bios Re-set the memory chips Use multimeter to check the continuity in the tantalum capacitors Clean the edge conecto […]
Re-set the Bios
What do you mean with continuity in de capacitors? I have a multimeter but I don't how to use it to check the capacitors.
With what kind of material do you clean the connector? Can I use alcoholpads?
Reply 18 of 40, by nuno14272
If no boot, and no beeps, the card is causing a short...
If bios problems the cpu would post , no video on screen but post.
so its a short problem.. need to check continuity in those tantaluns, and that diode
1| 386DX40
Reply 19 of 40, by egbertjan
nuno14272 wrote on 2025-11-13, 09:07:
When I start the computer with a good working videocard I hear one beep. When I start the computer with the Speedstar I hear a multiple beep and I hear the harddisk startup, nothing on the screen.
So, I don't think there is a shortcut. I'll be back when I know the exact beeps.
When I want to check the capacitors, do I have to remove them first from the card?
