Which soldering iron do you use?
Reply 20 of 43, by Jo22
shevalier wrote on 2025-11-12, 15:10:
Jo22 wrote on 2025-11-12, 14:51:
Hakko.. That's new to me. At first, I thought Hakko might be the name of another siblling of Yakko, Wakko and Dot.
Anyway. These Hakko soldering stations are interesting, they even colour match Play-Doh. 😉
Cousin.
This is an old Japanese brand that is most often counterfeited in China.
I see. It's just that the shape and yellow/blue design (FX-888 etc) reminded me of my visits at Toys'R'Us from years ago.
They had plastic toys with same style. And that's not even meant sarcastic, it's first thing that came to my mind.
Reply 21 of 43, by elszgensa
shevalier wrote on 2025-11-12, 16:13:
No one cares about maintaining the temperature precisely within the range of 1~ 50 degrees.
[...] the temperature does not have to be accurate, it just has to be stable.
I agree that the absolute temperature isn't terribly important (at least for irons and air)... "Two notches more should about do it... alright", and having more mass (= stability) is of course always welcome. But I do want to at least be able to adjust for leaded v unleaded solder, while not dumping more heat than necessary into any vintage (possibly poorly aged) parts, so irons without any temp control at all, even if they're perfectly stabilized around their fixed set point, can eff right off. The one you linked to does allow it, mine back then didn't.
Reply 22 of 43, by Lostdotfish
I use a Metcal SP200 for most stuff. It uses fixed temp cartridge tips and soaks heat incredibly efficiently.
I also recently picked up a Pinecil. I use this for quick work or things where the consistent soak of the SP200 isn't necessary. That said, I've found it to be incredibly capable. I'd definitely recommend it as a good entry point.
Reply 23 of 43, by BloodyCactus
hakko, the old analog model fx-888. probably 15+ years old and still going strong. love my hakko gear.
Reply 24 of 43, by Ozzuneoj
For soldering I use a Hakko FX888D that I bought 10 years ago. It's kind of old school but it has served me well. I have considered trying one of the newer cartridge style ones that are popular these days, but it's so hard to discern paid-for-advertising from actual honest reviews that I haven't committed to anything yet.
For desoldering through-hole components I had been using a Zhongdi ZD985, also for about 10 years, but it is so irritating and fiddly to keep it clean and clog-free that I found myself perpetually avoiding any jobs that would use it. Back in March I finally bit the bullet and bought a Hakko FR-301 (the Japanese 100v version because it was $100 cheaper than the US one... it seems to work totally fine on ~115v). I haven't used it a lot, but when I have it has worked perfectly. I do miss having digital temperature controls, but if it just works then it isn't really an issue.
For SMD work and pre-heating boards I have a cheap HFS 959D digital hot air station that I bought in 2018. I'm still very much a novice with SMD repairs and actually just got my first solder paste earlier this year. It is insane to watch solder paste pull components perfectly into position once it gets up to temp. Looks like nano-robot technology or something. 🤣
Oh, and getting a decent binocular microscope has helped tremendously with SMD repair work as well. I picked up a used base-model Amscope for really cheap earlier this year and it has been incredibly useful. Having it for fixing bent legs on chips (using a sewing needle) or for doing SMD repairs on boards with tiny components feels almost like cheating after doing it with just my eyes or with a basic wear-on-your-head magnifier for 10 years.
At this point the last thing I "need" would be a good board preheater, but I am sort of accident prone so I keep picturing burning my flesh off on a big hot plate while trying to focus on repairing something. Also, I was about to buy one shortly before the tariffs hit when popular models could be had for $50. Now they've gone up a lot and I haven't bothered to research them in a while.
Reply 25 of 43, by momaka
MattRocks wrote on 2025-11-12, 13:27:
I need to do all the electrolytic caps on a Radeon 9800 Pro, and at least one electrolytic cap on an Intel PERL motherboard (that board is packed with them though).
I know this isn't the main topic of the thread here, but worth mentioning here is that most Radeons do *NOT* need a recap - particularly the ones made by ATI, since they use good quality caps. The only reason to have to recap one is if someone tried "baking" the card in the oven to try and fix the common graphical artifacts issues that these cards are associated with... and in the process overheated the caps and "popped" them. Outside of that scenario, you shouldn't replace the original caps. Despite their age, they are still good.
The Intel PERL on the other hand, if it's all done with Chemicon KZG and KZJ... yeah, those should be done bloated by now.
Reply 26 of 43, by momaka
As for soldering irons...
I started out with a 30W Radio Shack "gun-style" iron about 20 years ago... and still have it and use it. However, it is NOT for motherboard recapping or anything that requires too much thermal mass, as this iron does not have much in the way of that.
Next, got a 40 Watt Radio Shack (again) desoldering iron with a rubber bulb (was popular back then) and... didn't use it a whole lot. As mentioned by a few other members here, it does kind of suck, and not in a good way. However, it does have its uses - I used it mainly for scavenging multipin DIP ICs from *single layer* PCBs (mostly old CRT TV/monitor boards, PSU board, and etc.) as well as replace a few flyback transformers on CRTs. It's clearly an outdated tool and its function would easily be replaced by one of the desoldering irons mentioned by other members above. So only mentioning it here for historical purposes.
After many years with struggling with the above two (along with getting a heat gun to help me do my 1st mobo recap with the 30 Watt Radio Shack iron above), eventually I got gifted a T12 tip style iron - a Circuit Specialists CSI 2900 (a rebranded Aoyue 2900) 75 Watt temperature-controlled soldering station... and that was really "it" for me. Didn't find the need to upgrade to anything else after, at least for the work I do, which is primarily PSU and motherboard recapping.
That being said, how do I remove caps from a motherboard without a desoldering iron? Really simple:
https://www.badcaps.net/forum/showpost.php?p= … 87&postcount=23
After this, I use a stainless steel needle to clear the holes.
Might sound like more work, but I'd rather do that any day over fiddling with a desoldering station. FWIW, the repair shop I worked at over 12 years ago did get a Hakko vacuum desoldering station (I forget what model number now, but kinda similar to the praised FR- units mentioned above.) I tried it, but just didn't like it. At the time, we were doing mostly console "repairs" (a.k.a. reflow "magic" on the Xbox 360's and PS3 GPUs), but occasionally also had to change caps on some Xbox 360 motherboards (be it because someone "baked" the board or because a few of the 1st gen 360 mobos came with Sanyo WF caps, which went bad pretty quickly.) Since I was de-facto "the recap guy" in that place, my experience with the Hakko desoldering station was that it was just too much maintenance to deal with way too frequently... despite being careful with it and not trying to pull anything more than solder from cap holes. But more importantly, that Hakko desoldering station kind of struggled with the big copper planes on the Xbox 360 motherboards, no matter if or how much flux + leaded solder was added to the cap solder spots . So certain holes would take multiple tries to get them cleared and the caps desoldered. Thus, it got to the point where it was just easier and faster to go back to my "cap walk-out method" with the 75-Watt CSI 2900 station... and why I continue to do recaps this way. Not to mention it's just one tool for the entire job.
That said, the CSI 2900 soldering station that I use has been out of production for a while now, so I can't really recommend it.
However what I *can* recommend are stations that use cartridge T12 -type soldering tips - basically stations that have the heating element built into each tip.
This is VASTLY different from the likes of the cheap 900M "cartridge" type tips, where the tip goes on top of a ceramic heating element. In the case of the 900M tips in particular, they lack thermal mass IME. And more importantly, depending on how cheap you go with them, the really low-quality tips and/or stations that use 900M tips will have poor thermal coupling to the tip "cartridges", resulting in really really poor heat transfer. FWIW, I also have a KADA 852D+ hot air + soldering iron station AIO unit. I didn't mention it in my history above, because it wasn't really worth mentioning. The hot air part is O.K. The soldering iron uses really cheap 900M tips and it's almost good for nothing. The fact that my 30 Watt Radio Shack iron performs better should tell something. I also used a few other Hakko clones with 900M tips back in that repair shop, and while they were better than the iron on my 852D+, they were still not something I'd deem adequate for recapping a motherboard.
So TLDR:
- Soldering stations / irons that use cartridge T12 -type tips - YES PLEASE!
- Soldering stations / irons that use 900M type (or similar "slip-on" style) tips - not recommended.
Now, if you have deep(er) pockets, you can go with a station brand like JBC. I had the pleasure of using one back in that repair shop many years ago, and it was a FINE soldering station, to say the least. We used it mostly to clean BGA pads under the GPUs of the Xbox 360s after removing the GPUs. With a 30 mm -wide tip, it had ZERO problems heating the board up - with and without braid. So yeah, that station was totally worth its money (from what I understood at the time, around $500). Obviously hard to justify that kind of money for the occasional hobby work, but just had to mention for purposes of showing a bigger "specter" of what's available out there in terms of soldering stations.
Oh, and a honorable mention I skipped talking about above...
I also have a very old Soviet-made 40 Watt regular soldering iron - a pass-me-down from my dad. Like most old things from that era, it was made of quality materials... but most importantly, it has a BIG, FAT, COPPER tip. So despite the rather low 40 Watt power rating, it has excellent thermal transfer and thus CAN be used for motherboard recaps - without much difficulty, either. The only reason why I still prefer my CSI 2900 is not because of power issues, but because the T12 tip holder on the CSI 2900 is much shorter than the big, long "wand" on that old 40 Watt iron. In essence, it's just easier to control tip motion when the tip is shorter (insert "that's what she said joke here"? 🤣 )
So it goes to show that in the end, tip design is the most important thing when it comes to soldering irons... with tip thermal mass thermal mass probably in the #1 spot. Everything else comes after that.
Speaking of tips, I prefer/use mostly the clunky "fat" types - e.g. either chisel or bevel type (but mostly bevel). The most used tips on my CSI 2900 are the D52 (5.2 mm wide bevel type) and BC3 (~3 mm "flattened pencil" type).
Reply 27 of 43, by MattRocks
momaka wrote on 2025-11-13, 01:56:
Interesting. I have my original 9700 Pro and the caps are fine. But, the 9800 Pro came from eBay sold by a total lying bag of excrement.
Reply 28 of 43, by Lostdotfish
Lostdotfish wrote on 2025-11-12, 18:33:
You know what, I'm going to upgrade my recommendation here. The Pinecil just out-performed my SP200 during a very tricky repair, and the thing is only $26. It is also incredibly light which makes it agile when working around boards at awkward angles or with tight spacings.
The attachment Screenshot 2025-11-13 162833.png is no longer available
https://pine64.com/product-category/pinecil/
This iron
https://pine64.com/product/pinecil-smart-mini … soldering-iron/
These tips - make sure you get the short ones - they heat up better and hold temp better than the long ones.
https://pine64.com/product/pinecil-soldering- … -tip-set-gross/
Definitely worth picking up this cable
https://pine64.com/product/usb-type-c-to-usb- … 5-meter-length/
These tips if you think you'll be doing seriously small work (but the large tips are better for most general use).
https://pine64.com/product/pinecil-soldering- … t-tip-set-fine/
Pair it with a good 65W USB C PD charger and you're good to go. You can even power it off a 3S Lipo if you want portability.
Reply 29 of 43, by gdjacobs
T12/T15 soldering irons are generally excellent. I have an FX-888D, and it's good, but tips with the heating cartridge incorporated are just so much more responsive. I've used OKI/Metcal Curie point stations before, and I would say they're broadly similar in capability. T12 irons are generally so much cheaper that the choice is a no brainer.
The other thing to remember is to use lots of good flux.
Reply 30 of 43, by tehsiggi
For day 2 day soldering: Atten ST-909
Desoldering: ZD-915
Hot-Air: 858D
Hot-Plate: 946C and a 853A
IR Soldering: IR6500
I have one portable soldering Iron that has to do whenever I'm not in the Lab.
AGP Card Real Power Consumption
AGP Power monitor - diagnostic hardware tool
Graphics card repair collection
Reply 31 of 43, by appiah4
I recently upgraded from a simple pen solder to a Yihua 878D solder/rework station and I love it. It's not state of the art but does the job perfectly well.
The attachment yihua-878d-isi-ayarli-sicak-hava-ufleme-lehimleme-havya-istasyonu-kcm91999074-1-c289e303028f4eeb9724d226a755d5b4.jpg is no longer available
Reply 32 of 43, by StriderTR
Lostdotfish wrote on 2025-11-13, 16:29:
I've been using my Pinecil V2 a couple years now, and it's been absolutely incredible. So much so I got rid of the Yihua 939D+ I was using prior, and I really liked that station, but the Pinecil was just so much "better" for my needs. I was going to keep the 939D+ around, but I was never using it so I just bought a second Pinecil as backup instead.
I really like the fact the Pinecil V2 can use TS100 tips, is very comfortable to use for long periods of time, and can even handle heat wicking areas quite well for something so small. I have yet to have any issue with mine. I power mine using a generic 19V/3.4A/65W brick I got off Amazon for $20.
DOS, Win9x, General "Retro" Enthusiast. Professional Tinkerer. Technology Hobbyist. Expert at Nothing! Build, Create, Repair, Repeat!
This Old Man's Builds, Projects, and Other Retro Goodness: https://theclassicgeek.blogspot.com/
Reply 33 of 43, by Tiido
At home I use my no-name 852D+ station, which has been modified to have two soldering irons instead of iron + pump based heatgun. The heatgun is wholly useless to me so I reused its circuitry for second iron. It allows me to have two of mym ost used tips ready and dual wielding is very useful every now and then too ~
I also added an IEC power socket since original power cable was permanetly attached and the outer insulation had gotten so stiff it was broken on both ends... Now there are no problems with that anymore ~
In any case I love the pots for temperature adjust. I hate all the buttons+menu based things, highly unergonomic... It is one of the reasons I haven't yet bought anything new although I keep entertaining the idea of my own station, using tips like Pinecil etc. uses...
At work I use JBC CD-2BQF, and it is quite excellent : https://www.jbctools.com/cdb-soldering-statio … oduct-1605.html
Very expensive however, and tips are not cheap either but it performs so very well and I'm somewhat spoiled by the nearly instant heatup and I miss it at home 🤣
Reply 34 of 43, by Vynix
I use a Pinecil, it's been more than enough for my uses, probably need to get a new set of tips for it
Reply 35 of 43, by Ozzuneoj
There is a good discussion about modern soldering irons here:
https://www.reddit.com/r/soldering/comments/1 … 2_or_soldering/
There is also some good discussion (and some pointless bickering...) in this post too:
https://www.reddit.com/r/soldering/comments/1 … ering_iron_was/
I am tempted to try one of these to see what it's like to use a modern style of fast-heating, high power delivery iron on a budget:
https://www.amazon.com/GEEBOON-TC22-soldering … B0DY45C97T?th=1
If you don't need the portability of something like a FNIRSI HS-02B (for normal soldering with C245 cartridges) or HS-02A (for microsoldering with C210 cartridges), I guess that's a good model that's able to use both C210 and C245 cartridges for any kind of soldering you could ever need to do.
Reply 36 of 43, by PC@LIVE
I don't know if it has already been put before, here is a Necroware video on the subject:
https://m.youtube.com/watch?v=LJWU62r85k8&t=9s
AMD 286-16 287-10 4MB
AMD 386SX-33 4MB
AMD 386DX-40 Intel 387 8MB
Cyrix 486DLC-40 IIT387-40 8MB
486DX2-66 +many others
P60 48MB
iDX4-100 32MB
AMD 5X86-133 16MB VLB CL5429 2MB
AMD K62+ 550 SOYO 5EMA+ +many others
Reply 37 of 43, by Locutus
For "heavier" works I use AXIUN T3A with T245 handle.
IMO, absolute gem.
Reply 38 of 43, by TheMobRules
Soldering: Pinecil, it's amazing and has never let me down
Desoldering: Hakko FR301 (I had a ZD915 for a while, but I became tired of some random part breaking and having to be replaced every time I used it)
Hot air station: generic chinese "JCD 858D", probably garbage tier but it does the job
Reply 39 of 43, by Wolfus
appiah4 wrote on 2025-11-14, 08:36:
I've bought 948-I (2 in 1 too but desolder instead of hot air) and love it so far. It's warming-up speed is lightning fast.
