Battle of the platforms: socket 754!
Reply 400 of 860, by nd22
C. KV8
Reply 401 of 860, by nd22
Nothing to see, all 3 results are still close so we move to:
11. 1280*1024 max details with no sound:
A. NF8
B. KU8
Reply 402 of 860, by nd22
C. KV8
Reply 403 of 860, by nd22
12. 1280*1024 max details with sound:
A. NF8
B. KU8
Reply 404 of 860, by nd22
C. KV8
Reply 405 of 860, by nd22
Still no clear winner as we head into the most demanding settings:
13. 1600*1200
A. NF8
B. KU8
Reply 406 of 860, by nd22
C. KV8
Reply 407 of 860, by nd22
14. finally we reached the end of tests in Aquamark3 with 1600*1200 sound on:
A. NF8
B. KU8
Reply 408 of 860, by nd22
C. KV8
Reply 409 of 860, by nd22
In Aquamark VIA has across all resolutions a 2-4% advantage over nforce3 - still not enough to score a clear victory. ULI is extremely close , even overtaking VIA at 1600*1200 with a very small lead!
Reply 410 of 860, by nd22
15. We go back in time to the only Directx7 benchmark: 3dmark 2000; all 3 systems are way overkill for any Directx7 test as we see in the results. Also Cool and quiet MUST be disabled in this test otherwise the CPU will just sit at 1000 MHz - and yes I did test all 3 systems with cool and quiet enabled and disabled
1024*768
A. NF8
B. KU8
C. KV8
Reply 411 of 860, by nd22
Abit KU8 with cool and quiet - notice the score is cut in half!
Reply 412 of 860, by nd22
16. 1280*1024
A. NF8
B. KU8
C. KV8
Reply 413 of 860, by nd22
17. 1600*1200
A. NF8
B. KU8
C. KV8
Reply 414 of 860, by nd22
In this CPU limited benchmark we got no winner! Clearly you are not going to encounter any problem playing your favorites games from the late 90's on such a system!
Reply 415 of 860, by nd22
18. Many people will consider 3dmark 2001 as the most important test for a system designed to play early 2000's games! A staple for all PC's from the 2000's with any operating systems - be it 98 or XP - it is considered a fundamental metric in all comparatives.
1024*768 default settings
A. NF8
B. KU8
C. KV8
Reply 416 of 860, by nd22
And we got a winner! VIA overtakes both nforce3 by 8% and m1689 by 5.8% in this test! For the first time since Newcastle is under testing there is a clear victor.
Reply 417 of 860, by nd22
19. 1280*1024 resolution with all details maxed out:
A. NF8
B. KU8
C. KV8
Reply 418 of 860, by nd22
20. 1600*1200
A. NF8
B. KU8
C. KV8
Reply 419 of 860, by nd22
VIA manages a first victory with Newcastle in 3dmark 2001!
