Reply 1680 of 1694, by FreddyV
It is like polluting PicoGUS posts by picoMEM but Anyway 😀
I added Mindscape and Covox to the PicoMEM.
Couvox sound master, sound master 2 and multiple other rare boards could be added as well.
So, maybe Ian will take those code and add to the PicoGUS. 😉
What other kind of "not CPU intensive/Impossible with a Pico" can be nice to add ?
Reply 1681 of 1694, by carlostex
FreddyV wrote on 2025-11-08, 09:54:
Hi, […]
IBM Music Feature? There's emulation for it in DOSBox, but i guess it needs to be ported to ARM. No idea if the RP2040 can do it, if not maybe the RP2350
Reply 1682 of 1694, by Isstanar
I'm having an issue getting the CDRom drivers to load on my PicoGUS 2.0 on my 486 Machine.
Specs:
Motherboard: Freetech/Flexus 486F38X
CPU: 486DX2-66
RAM: 64MB
Video: QDI S3VGA PS805 (VLB)
Sound: Soundblaster AWE64 Value
I/O: DTC2278E (VLB)
OS: DOS 6.22
Driver: CDMKE.SYS from PicoGUS wiki
Autoexec.bat:
@ECHO OFF
PROMPT $p$g
SET PATH=C:\WINDOWS;C:\DOS
SET TEMP=C:\DOS
SET CTCM=C:\CTCM
SET SOUND=C:\SB16
SET BLASTER=A220 I7 D1 H7 P300 E620 T6
SET MIDI=SYNTH:1 MAP:E MODE:0
LH C:\CTCM\CTCU /S
LH C:\SB16\DIAGNOSE /S
LH C:\SB16\AWEUTIL /S
LH C:\SB16\MIXERSET /P /Q
LH C:\CTMOUSE\CTMOUSE.EXE /S1
LH C:\DOS\MSCDEX /D:MSCD000
Config.sys:
DOS=HIGH,UMB
FILES=40
BUFFERS=40
STACKS=9,256
LASTDRIVE=H
DEVICE=C:\DOS\HIMEM.SYS /TESTMEM:OFF
REM DEVICE=C:\DOS\EMM386.EXE RAM
DEVICEHIGH=DOSEIDE.SYS /2
DEVICEHIGH=C:\DOS\CDMKE.SYS /P:250 /D:MSCD000 /Q
DEVICEHIGH=C:\CTCM\CTCM.EXE
All the other modes work fine on the PicoGus (I use it often with my MT-32Pi), I can see all the images on my USB stick, and I can switch between them. The problem is that when the CDMKE.SYS comes up to load during boot, it gives back an error that states "Interface Board or CD-Rom Drive is not ready". I tried different things with my AUTOEXEC.BAT and CONFIG.SYS files but nothing worked so far. I even tried the CDGOD disk with several different drivers, but none of them can detect the PicoGUS virtual CD. Anyone got any suggestions?
Reply 1683 of 1694, by NeoG_
Isstanar wrote on 2025-11-08, 18:47:
Try and move the port around (E.g. try 260 or 280), remember the port has to be changed in config.sys (/P:280 parameter) and also on the picogus (/cdport 280 /save). 250 may be blocked by another device.
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6800, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
Reply 1684 of 1694, by Isstanar
NeoG_ wrote on 2025-11-08, 21:20:
I cannot believe it was that simple. I switched to port 280 and now it works fine. Thank you sir.
I swear I did try to change the port, but I'm guessing I forgot the /save part.
Reply 1685 of 1694, by eliot_new
Isstanar wrote on 2025-11-08, 21:43:
Question 1: "and also on the picogus (/cdport 280 /save)"
=> means that you added a line in the AUTOEXEC.BAT like this?
SET PICOGUS /cdport 280 / save
Question 2: currently I have a PicoGUS 2.0 + MT32 Raspberry board and an AWE64 value with 4 colors + SIMMconn 32MB PS/2
=> how do I connect them with a "sound cable" in order to enable this combination in Doom 1: General Midi on GUS and SB16 effects on AWE64
=> do I need to connect the line out of the GUS to the line in of the AWE64 (which one of the 4 colors shall I take?)
# w98SE . P3 450 . 768MB . QDI440BX . V3 AGP . 3dfx 6MB . AWE64 . GUS Pico 2.0 . 80GB HDD
# wXP . P3 1G . 512MB . ASUSCUSL2-C . MSI FX 5600 . 3dfx 6MB . Audigy 1 . 80GB HDD plan
# w8.1 . i7 4790K . 32GB . ASUSH97M-Plus . GTX 970 . AC97 . 1TB SSD . 6TB HDD
Reply 1686 of 1694, by polpo
eliot_new wrote on 2025-11-08, 23:11:
Run: pgusinit /cdport 280 /save
This will set the port and then save the settings to the card so it will remember for future start ups. You need to do this so the settings are ready for the MKE driver in config.sys to be loaded, since any settings you change in autoexec.bat will be too late.
Yes, connect to the line in of the AWE64, which should be the blue jack. Make sure to turn up the mixer volume for the line in to make sure you can actually hear it.
Reply 1687 of 1694, by NeoG_
The mythical polpo has returned, does the prophecy say there is a new firmware version cometh?
Reply 1688 of 1694, by polpo
NeoG_ wrote on 2025-11-09, 10:33:
Not any time in the near future. I'm currently busy getting PicoIDE ready for launch: https://picoide.com/
The attachment picoide_evt2_angle.jpg is no longer available
Reply 1689 of 1694, by eliot_new
Ok, I will boot now Win98SE and look, whether I have this software "mixer" installed along with the AWE64 drivers. In case I don't find it, I will try these .exe files from Phil:
https://www.philscomputerlab.com/creative-labs-drivers.html
Reply 1690 of 1694, by polpo
eliot_new wrote on 2025-11-09, 18:05:
I recommend using UNISOUND to init the AWE64 and set the mixer volume: UNISOUND - Universal ISA PnP Sound Card Driver for DOS v0.82a
It's a lot easier to get working than messing with the Creative drivers. Just set your BLASTER variable appropriately and run UNISOUND, adding the /VL99 option to set the line-in volume to 99 (adjust down if it's too loud, but the PicoGUS output is pretty quiet so you probably want it as high as possible).
Reply 1691 of 1694, by Mr.Hunt
Polpo, Hello! Could you please tell me, will picoide have the ability to control from dos?
Reply 1692 of 1694, by carlostex
Mr.Hunt wrote on 2025-11-11, 13:49:
Wondering about that too, if it is possible with some ATAPI commands or so change the loaded image. This way loading a game via a batch file becomes very convenient.
Reply 1693 of 1694, by weedeewee
carlostex wrote on 2025-11-12, 21:42:
According to polpo, a dos utility is planned.
Do not ask Why !
Reply 1694 of 1694, by appiah4
polpo wrote on 2025-11-09, 14:31:
Oh wow, so cool!
