teeeeeegz wrote on 2025-11-11, 13:35:
All caps look fantastic on this mobo (V58XA) with exception to this particular one in the pics.
Can you show us a picture of your board?
Just because the caps looks good doesn't mean that they are. Certain cheaper brands have been known to fail without showing any visual signs. And some brands are just know to fail... so knowing what's on your board can help us determine if that gloom & doom will come your way.
I wanted to get a second opinion whether this is bad corrosion, especially with the underside pic of the board?
No, it's just leftover flux from whoever changed and/or resoldered that cap back on the board, as the others mentioned here.
Its trace on the bottom side does look a bit "murdered" though 🤣. Probably still connected OK, however, as the solder blobs on the top side appear to be in good shape.
If so, any tips / brand of cap I should replace it with, recommendations on how i could repair it, and whether I could fire up the mobo for the first time in 18-20 years just to see if it works fine?
If nothing looks obviously bad, fire it up and hope for the best.
Just beware that while it is very *uncommon*, it still IS possible for an electrolytic cap to go POP after this many years, especially if it hasn't seen any use at all. So my suggestion is to keep your head/face not directly above the motherboard. In particular, the small caps that don't have vents are the ones that can fly like a projectile if they decided to pop. But again, the good news is, this is very very UNcommon. As for the big caps - they can't really pop, since they have vents. If anything goes wrong with those, they'll just fizzle their electrolyte away.
My other recommendation: do not leave the board running unattended - at least for the first 5-10 hours of run time. If a cap goes bad, you'll want to catch it / see it, and shut stuff down when you do. Again, while it's UNcommon that damage will result from caps going bad, it can happen... and the likelyhood of that increases as the equipment is longer used with the bad caps.
I also pulled 3 power supplies out of storage, one from 2011 (gigabyte 300w) had almost every mid-sized cap bulging with brown stuff on top - pic 3, a second from 2006 (shaw 550w) had only one suspect cap with shiny stuff on top - pic 4, and a third from 1999 (EVE 250w) that looked perfect on the inside - pic 5.
Looking at these PSU's made me feel quite concerned about this particular mobo issue.
The Gigabyte PSU is actually not that terrible of a PSU - it's a fairly modern 2-transistor forward converter made by FSP (judging by the "SPI" markings on the transformers.) It's just not really a 300 Watt PSU, that's all. More like 150 Watts to 180 Watts tops, considering those small heatsinks and the 330 uF primary caps. Also, being a more modern forward converter design, I'm not sure how suitable it would be for an old PC that has bigger draw from the 5V rail (e.g. anything Pentium 3 and older or Athlon/XP and older.) A 5V-heavy PC (like Athlon/XP) could even possibly make the 12V rail go too high. A more ideal use case for such a PSU would be something like a low-power 2nd/3rd/4th gen Celeron or i3 PC with onboard or low-power video card (under 60 Watts.). That is, if you get it fixed (recapped), of course... which shouldn't be too hard to do. Just replace all of the electrolytic caps (except the two big 200V 330 uF ones) and it should be good to go again. In particular, such work is especially good if you want practice with your soldering, as PSUs are much easier to work on (solder) than motherboards.
In regards to the Shaw "550W" PSU and the shiny stuff on one of the caps: that looks like solder splat. In other words, the factory was sloppy with the soldering. But I didn't need a picture to tell you this. Most "Shaw" PSUs are pretty crap with completely fictional power ratings on their label. I can bet my entire retro PC collection that the "550W" unit you have will, in fact, NOT be capable to reach anywhere near 550 Watts of power... except for a brief moment when it blows up trying to pull anything North of 250-300 Watts. I see a KA7500 IC on the board, so it's an oldschool half-bridge design with likely the standard cheap parts... so not really good for much.
Lastly, the 250 Watt "EVE" PSU from 1999: that actually looks quite OK!
I can't quite tell who the manufacturer is, but it looks to be a solid 200 Watt all-day-long PSU, with 250W probably being the peak rating. More importantly, the manufacturer didn't skimp on any of the parts that matter here:
- the AC input filter is complete and mostly OK (I'll nick it some points here for using 2kV ceramic caps instead of proper Y2 class caps and a MPP cap in place of a proper X2 class cap)
- the number and size of the electrolytic capacitors on the output rails seem appropriate for the power rating of the PSU
- speaking of caps, the electrlytic caps are by PCE-TUR, which while not great, are far from the worst out there (hey, Enermax used them quite a bit too!)
- output toroids look appropriately sized
- good size heatsinks
- main PCB and fan use removable connectors, which makes disassembly of the PSU much easier - basically a nice-to-have for when doing regular cleaning maintenance.
Oh, and unlike the Gigabyte and the Shoddy Shaw, this PSU *will* be more than happy to power a 5V-hungry PC. My experience with old and decent quality PSUs from that era is that they have a pretty solid 5V rail. If you are concerned about it, or particularly about the condition of its electrolytic caps, you can recap this PSU too. Just make sure you do so with quality Japanese cap brands, otherwise it probably won't be worth it. Again, despite PCE-TUR not being that great, they are still miles better than the no-name junk sold on Amazon, AliExp, and to the most extent, eBay too.
FWIW, a good fit for PCE-TUR, spec-wise, is usually Nichicon PW, PS, PM, and HE, or Rubycon YXJ or United Chemicon LXZ, LXV, LXY, and KY/KYB. Also Panasonic FC and FK... in case anyone even cares about the details. 😁
I also haven't used a soldering iron in 15 years 😀
No worries, it's like riding a bike - you'll pick it back up... maybe 😁
Again, though, if you do want to practice on your soldering, start by recapping that Gigabyte 300W PSU. PSUs are much easier to solder onto compared to motherboards.
