First post, by PaddyWi
I am looking for a decent power supply for my retro build (P2, P3 or P4).
Here, FSP is widely mentioned.
Will this power supply be any good? I can get it for 26 Euros new oem.
FORTRON FSP400-62PFG 400W 20+4-PIN.
First, it depends on what system you are going to use it with. For a Socket A system with 5V CPU VRM it most likely isn’t, because that PSU is already designed more for 12V loads. This PSU is most likely from late 2000s or early 2010s.
If you don’t require 5V heavy operation or something ike 6-pin AUX power connector that more or less disappeared after ATX1.2, generally any modern quality PSU should work just fine for your needs. Only thing you need to consider if you need -5V which is missing from more modern PSUs. There are things such as voltage blaster that can ”create” -5V, so it isn’t actually a dealbreaker. And the lack of -5V is an issue with few scenarios and with 80s or early 90s hardware.
FSP in genral is a quality brand, but not all of their PSUs have been particularly good. And with old used PSUs there is always the matter of questionable reliability. I personally have recapped my early 2000s PSUs due to potential capacitor reliability issues. But specs wise for P2, P3 and P4 it should work fine, unless you have some P4 850 mobo which requires 6-pin AUX and which this PSU lacks.
Thanks a lot.
Since you are from Europe, do you know a place to get a decent one from?
First, there are too many options for you to choose, if you adopt the modern PSU route. Search here and you will find many threads for suggested models and then you can search your computer stores or used market places for such unit.
I personally use vintage PSUs recapped, but I have been using Corsair CX450M on a bench and with some builds. It is handy on bench due to its semi-modular design so you don't have unnecessarily many cables on the way. I don't know if it is available as new anymore, it is probably 6-7 years ago when I got it. And this is not to say that it is worth to try to hunt down that specific PSU, because there are countless of options and you can buy a modern PSU from pretty much any computer store. Another thing to note with modern PSUs is that they don't necessarily have floppy power connectors and have limited number of 4-pin molex connectors, so you may need to use adapters and splitters, but you can get those with few pennies.
Using old used PSUs doesn't necessarily mean that they will immediately blow up on you and kill your hardware, but especially many early to mid mid 2000s PSUs suffer from capacitor problems. Also, with used PSUs you usually don't know how many hours they have been used or how they have been stored, both of which affect the reliability of the unit. In the end it is a choice between reliability and compatibility with older hardware. Some builds, like most beefy Socket A systems, are notoriously challenging for modern PSUs. In most other cases you can use modern PSUs just fine if you take the limitations I mentioned in consideration.
PaddyWi wrote on 2025-11-15, 09:57:Will this power supply be any good? I can get it for 26 Euros new oem.
For Pentium 4 and Athlon XP *with* 4-pin 12V power - YES.
For anything else that draws CPU power from the 5V rail - maybe, maybe not.
FSP is generally pretty good, but I do hold my reservations against some of their PSUs. Namely, their ATX 2.xx and newer PSUs can do quite poorly with a PC that doesn't draw enough constant power from the 12V rail, essentially making the 5V rail dip quite a bit and the 12V rail go high a little further than the 5% spec. Here's a useful thread on the matter (skipping to the conclusions in page 4, in case you don't want to read it all):
[SOLVED] PSU Fortron/FSP ATX-350PNF with problematic +5 & +12V voltages
And the older ones that are from the "transition era" (2003-2004 - i.e. when more motherboards started powering the CPU VRM from 12V rail rather than 5V rail - mainly Pentium 4 and onwards) often came with somewhat problematic 5VSB circuit designs (2-transistor self-oscillating circuit) inside the PSU, which could sometimes go over-voltage on the 5VSB and take out your motherboard with it. Also, those older FSPs are quite prone to developing bad caps, so I can't recommend them unless you're comfortable with doing a recap.
All that said, since I can't find any reviews with internal build pictures of the model you mentioned, we can't really know how the 3.3V and 5V rails are derived in this unit. On most modern mid-range PSUs, the 3.3V and 5V rails are now quite often derived by way of DC-DC modules from the 12V rail, meaning the 3.3V and 5V rails will have pretty solid regulation regardless of what load you put on the 12V rail. So if the FSP400-62PFG uses DC-DC for the 3.3V and 5V rail generation, then it should be fine for a Pentium II and 3 -class PCs and only might struggle with the more power-hungry Athlon/XP builds. But if that FSP400-62PFG uses the same or similar group regulation method like the ATX-xxxPNF PSUs, then it probably won't do to well (or at all) even with a low-power PII/P3 PC.
Like CharlieFoxtrot, I also do my own PSU recaps/rebuilds of old PSUs, so I can't quite give you exact advice on what to get.
In general, if you want as cheap as possible and aren't afraid of DIY / soldering / recapping yourself, then getting an old but well-built retro PSU may be the way to go. I personally like the Dell / HiPro / Chicony HP-P2507FP3 250 Watt PSUs as they are quite roomy on the secondary side and very easy to recap. They are from the transition era (mid 2000's) so they can be used with both 5V-heavy and 12V-heavy PCs... so they are kind of universal and have pretty solid regulation. You can also often get them for cheap on the used market too. Their slightly newer siblings, the HP-P3017F3 (300 Watt) models are slightly more capable on the 12V rail and not as capable on the 5V rail... but still pretty rock-solid PSUs and still pretty recap-friendly.
Alternatively, you should spend a little more and get something new with DC-DC regulation modules on the 3.3V and 5V rail. Just look up reviews of some modern PSUs and see what's available in the market where you are. I personally haven't bought a new PSU since 2005, so I am quite a bit out-of-date of what's currently available... and the market is always changing too.
