First post, by PurpleOzone
I have a near-mint AT&T Globalyst 200 that came with a Citizen W1D drive. I replaced the belt, but I must have knocked the head out of alignment, as it struggled to read anything and would always fail at dir a:.
I’ve read every post I could find about this drive and spent over five hours trying to realign the heads. I used ImageDisk 1.2 and carefully adjusted the head positions by hand after disassembling and reassembling the unit.
Right now, it works with some floppies: it reads up to track 58 in the best cases, but anything beyond that fails on head 1, while head 0 reads everything.
I also tried using an oscilloscope (I’m a total newbie) to measure the test points and hopefully improve the alignment, but I couldn’t get any meaningful signal out of it.
My question is: has anyone successfully re-aligned this drive, and what process or approach did you use?
I know there’s the OpenFlops alternative, but I’d really like to get this drive working. It feels so close.
