First post, by douglar
- l33t
Sorry if this isn't the correct spot to post this but XUB r630 came out during the holidays.
https://xtideuniversalbios.org/timeline
- Changed the g_szPCFlashSuccessful string in XTIDECFG to reflect the reality - it turns out ANY key was limited to just ENTER or ESC.
- Removed the NEC V-specific optimization I added in r602 because NEC's documentation completely fails to mention that the ROL4 instruction also changes the high nibble of AL. Huge thanks to vcfed-member dreNorteR for discovering this and also for suggesting an optimization to the physical address conversion code in IdeTransfer.asm.
- Made some changes to the OUTPUT_AL_TO_IDE_REGISTER and OUTPUT_AL_TO_IDE_CONTROL_BLOCK_REGISTER macros as an optimization. This saves 15+12 bytes in builds without MODULE_8BIT_IDE (e.g. the PS/2 builds).
- Other minor optimizations and cleanups.
