Reply 40 of 40, by Thermalwrong
Prez wrote on 2025-11-17, 19:59:
So i'm not wrong, maybe you just have to MOVE the actual resistor below its actual place and it would be okay ?
Since it's a pull-down resistor it might have a pretty high value like 4.7k ohms, because a pull-down at low resistance is really not common and is very likely bad practise.
I'm going to try out this modification soon too, I like my Tecra 8200 especially since it can do pixel perfect integer scaling of VGA res, but it's not very compatible with DOS games so far.
Thank you very much for sharing this with well detailed pictures and info theeuwke 😀
