First post, by MrD
Hello! I've been working on a nice 2010s-style graphical dashboard interface for MS-DOS, as I'm surprised nobody has made one yet. It's simply a grid of selectable pictures in the vein of LaunchBox, the Xbox dashboard, the XMB, tablet devices and so on. It's designed to be very kid friendly (you can't even edit the menu from inside the program), and 'fool proof' for the most part.
Screenshots:
https://www.mrdictionary.net/dosdash/download … t20240404_1.png
https://www.mrdictionary.net/dosdash/download … t20240404_2.png
Here is the introduction from the readme:
dosdash is an easy-to-use, family friendly graphical menu program for IBM PC-compatible computers running MS-DOS. It provides a […]
dosdash is an easy-to-use, family friendly graphical menu program for IBM PC-compatible computers running MS-DOS. It provides a familiar 'dashboard' style interface, giving you simple quick access to all your games.
dosdash displays a grid of beautiful image tiles representing the games on your MS-DOS system. You can navigate the grid using the keyboard or gamepad. Over 200 games can be set up in the grid.
In addition to a standard 'Action' for each tile, you can give each tile a set of its own extra Actions that will be shown in a sidebar menu. You can use this to provide ways to access sound card setup programs for games that need them, or ways to access extra episodes or mods of games without using multiple tiles.
For example, you can have a tile for Duke Nukem 3D which launches the main game when selected. In its Actions menu, you could have additional items for 'Setup Sound' and 'Launch Build'. For your Quake tile, you could have seperate actions for 'Quake', 'Dimension of the Past', 'Dimension of the Machine', 'Shrak for Quake', 'Malice: 23rd Century Ultraconversion for Quake' and so on. Or, you could choose to give each Quake total conversion its own graphical tile. The layout and content of your menu is up to you.
dosdash unloads itself completely from memory when launching a game, so does not take up any conventional memory when launching a game.
dosdash can be ran from the commandline, or included in your AUTOEXEC.BAT to provide a self-contained friendly menu experience.
dosdash is designed for use on real MS-DOS computers. However, if you prefer, you can install dosdash within DOSBox, if you prefer to have a single DOSBox configuration for all your games instead of multiple configurations.
You can launch Windows 3.11 from dosdash if you like.
System Requirements:
- 80286, 80386, 80486, or Pentium CPU or compatible (e.g. Cyrix)
- Hard drive
- Keyboard
- VGA graphics card (*)
- MS-DOS (only tested with 6.22, may work with older versions or compatibles)
- Optional: Ad Lib sound card for menu beeps (and compatibles, such as the Sound Blaster series)
- Optional: gameport joystick or gamepad (reads first 3 buttons)
Note: dosdash uses 'unchained mode', which is a special feature of VGA graphics cards used by games such as Doom, Epic Pinball and Jazz Jackrabbit (and many others) to enable hardware accelerated tear-free graphics, screen scrolling, static status bars and pixel group writes. If you have a VGA graphics card, it's highly likely that it will support unchained mode. In short, if your system is capable of playing MS-DOS games, dosdash should almost certainly run!
Here is a link to download dosdash:
https://www.mrdictionary.net/dosdash/downloads/DOSDASH.ZIP
The images are stored as base64 encoded (and compressed) plain text in a text file, with the intention that users can create their own icons and share them on forums and so on. I haven't quite figured out how it will all work out in practice. 😀 For example, it may turn out that this tile size (which is compiled in) isn't comfortable for users after all.
The colours can be specified in the INI file.
This is not the absolute finished product, and there may be errors. Please don't run it on a system with important data. This is a debug build with assertions, so in the unlikely event that something does go wrong, it should print out an error. Please copy the error or a screenshot into this thread and I will look into it. If it does crash while in real MS-DOS, please restart your computer instead of attempting to continue working.
Please reply with any comments or suggestions.
Current issues:
- The Ad Lib patches are very boring, but I put them in there to give some feedback. I may make them more interesting but they're a very low priority.
- I was perhaps going to add a 'kid safe' mode where Escape didn't immediately quit (it could be something less intuitive like Shift-Esc?).
- I have no real-world measurements of how fast the menu actually is on real systems. I know it works on a Pentium with a CRT monitor and a standard generic PCI card.
- The GENERATE.HTM is not very friendly in isolation. It needs a 76x36 image, and recolours images dragged into it to fit the palette in PALETTE.PNG.
- I've made the custom gamepad routine the default now. Please test both gamepad_enabled '1' and '2' with a real game port joystick!
- (fixed as of 2024-04-06) The DASHRUN gopher system doesn't work if, for some reason, you decided to install dosdash to the root of a drive. The software mis-identifies which directory to CD to when returning to dosdash. It tries to use CD C: instead of CD C:\ because the trailing slash should always be absent... except in the case of navigating to a drive root.
Reply 1 of 17, by MrD
Here's a different screenshot showing some possible icons: https://i.imgur.com/3KwB2A5.png
And here are the corresponding GRAPHICs if you'd like to try them out.
Get Lost ---GRAPHIC--- CAAAAZIIAAAAAAAAAAAAGSCAAAAAAAAAAAAO2AABAAAAAAAAAADtgAAQAAAAAAAAAB2wySAAADtg AAAAgAAAAdsZJ2wCAAO2AAAABAAA […]
Get Lost
---GRAPHIC---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---ENDGAME---
Halloween Harry
---GRAPHIC---
CJQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAFFAAElAAAAAAFFAAElKKAACSgAAAAAKKAACS
0UAABJQAAAAAUUAAAFlFFFlFFElAAAAACihZQopZRRQLLABZaKssAFlooBJRRQCSgCigCywALLRb
LABZaKCywD6IAstFssA+iAWWigCS0UAAAAFlgD6EAWWAPogFlooLLAPopMAstFssA+iALLRQAAAA
ABZYBSfoIBZYBSfogFlooWWAPopMAsqAPopMAstFWUUUBZQooACygIBSfoIAUn6IAstFFlgH0KTA
LKgH0UlALKQAWWihZUACyhRbKKLZSAAWWAUl9BAFJfRALLRRZYB9FJQCyoB9FJgAssA+iALLRSyw
A+hAAWWACywAfQIBZYApP0CAKT9EAstFFlgH0UmALKgH0UmAfRAD6KTALKEA+gEA+iAH0QA+ik/Q
IBZUApP0CAKT9EAstFFlgH0UmAWVAH0Un6CAPopMAA+kA+hAPoIApP0QBSfopP0UlAApP0Un6EAp
P0QBZaKssAfBSYAPgUn4CAPgpMAfBAHwQB8IA+Ck/BAPgIB8EApPwAKT8FJfApL4IBZaKssA+AAp
PwUl8EA+CkwB8FJgHwQB8IA+Ck/BSfgKT8EApPwUl8ApPwQCkvggFJ+CAWWirLAPgAKT8AUn4AUm
AfCAfAIB8KS+ACAKT8AUlAKT8EAUl8FJ+CAWWirLAOgpIOgAAFJgFJ6EA6EA6EA6FJgFJ6BSXQIA
pPQAKT0CAKT0AgFloqywDoKTAA6ApI6Ckh0FJgDoIB0IB0EAUnoEApPQIApIdBSUApPQIApLoCAW
Wi2WAOapMAspAOapJABSUAHNCkuaUlAFJIApJAAKTzQpLmoAUlzSALKgHNUlALKgDm0lACyoALKg
HNCkwCkkAAAsoQCk80IBSeagApLmkAsqAchSYAsqAchSYACykACkhAAAAApIQBSeQQCywBSeQQCy
oByFJgFlotlgHIUmAWWAftALKQD9oAP2gCywD9gQB+wIA/aAD9oBSeQQCyoBSXIQCyoApKAWWi2W
AKSgFlgH7QAP2gB+xAD9pGP2gH7SMftAJH+0AftI4BSSALKgCkoAstFssAFloqywAWWAfsAgD9pG
/aAP2BI4B+wJHAEj/YkcABZaKssAFlopZRRRZQgH7SMP2gH7AQD9pGP2gH7SMftACR/tI4AsoUUW
UUUAAWWAftAA/aAftIx+0A/aAD9oB+0AH7QCywB+0AWWigAAABZYBI0AspAJGgEjQASNAJGgFlQC
RoBI0AsqASNALKgEjQCy0UAAAAFlgAstFssAAsqAAWVAALKgAsqACy0UAASUAKKLKKKWUCirKBRV
lAoqyiirKKKJKAAACigAAAAAAACSgAAAUUAAAAAAABJQAAACigAAAAAAAkoAAAAAAAAAAAAAAAAA
AAAAAAAAAAA
---ENDGAME---
Interpose
---GRAPHIC---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---ENDGAME---
Interpose X-Mas Greetings
---GRAPHIC---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---ENDGAME---
Scorched Earth
---GRAPHIC---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---ENDGAME---
Theme Park
---GRAPHIC---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---ENDGAME---
D/Generation
---GRAPHIC---
BAAH/pMAAAFJ/8AAAH/AAAQAAAf/JAAA/8AAAH/W2AAAJJtv/AAABSf+O22wO2/4pMAAABku3/wA
dvJQAAAACSUkIAAAAAACk23JNt2//AAAAKTkm2dv/u222SUmSQAAAH/7e2ZJSYAAAAAAJJbckBSY
AAAAGS7f/AAyUAAABSf+7eSKSC25J2/+yUAAAH/yUAAAGS/8AAAH/tsAAHbgAP/AAABbf+21tgAH
/AyUAAAGSAgAf/t5IIAAAFJgAAZKAApMAAAH/yQAAP/AAAB/wAAEAAAH/pIGS/+2pIFt/8AAAH/k
kAZLbP+Hb22SgBJP/AAAB/zbZJAABbdt/0AAAAACSZIW2kwAAAduAAAA7cAAAH/Dt7YAH/QAAAdv
/g21tgAA20AAABJMl2/+DbZKSQAAAAbaABJMl2/+Dt5KSQAAAH/bYB/wDbQAAAduAAAAAAB24AAA
DtwAAAf8AABAAAB/+2A//bAf9AAAB/4AJJScl2/+yVtkkAD/wAAAf/t22AZIAIAdv/wAAAbYMlAA
JJktt2/+7cAAAFJgAAAKTAAAB/8kAAD/wAAAf8AABAAAB/4AAf/t5KSQAUn/wAAAf/tySABJO3/w
21tgAAAGS/4DbQC27b/g7cAAABbckLbAALbku3/0AAAAAADJQAAAAAAtu2/8AAAAAkltyW2f/bZI
/8AAACSW3Jbbt/9tslSYAf+AAAAHb/4A7e2yX/tskgDbQAAAApOSbbt/8AQAAAAAKTkm2/5AAABt
hkoAAAyUAAAH/yUkgAAAyUAAAH/yQAAdv/wAAAf8AABAAAB/4AAAD/wAAAf928kgAAAAAGSgAAAK
TAAAB/8kAAD/wAAAf8AABAAAB/8lSQABkv/AAABSYAAACkwAAAC27bt/8B29tbYAAAA23/A7b/gb
aAAAB/+3kpJAAASS29v/wAAAf+kwAAAUn/wAAAZL/u3kgA23b/7JQAAAKTtv+AA20AAAAC25IBSY
AAAAZKAAAAyUAAAH/bYAAf9AAAB/wba2wAAP/AAAAkmS7f/BtrbJIAAAAGSgAkmS7f/B28lJIAAA
B/9tkgO3/wHbyUAAAH/pMAAAAAA
---ENDGAME---
Command & Conquer
---GRAPHIC---
CAAAAAAAAAAAAAAAAAAAKJ/f82sA2P+JBAAAAAAAtna/xkYAom1+v5dW2wA2PVY2AMb1W1gC0f5/
+zANr/y0QAtnaMjADG9p1oApHabGAdX89U2NtgAbX/h/oBjf1/gbGAPr+SAPz/iSQDI///f/tQDt
f8xsAO1/xADa/82sAtv/f2Afn/fl+v86sAMb/ztZHq7Wkf5+urker+SkQDqvz/qRRP8LZANr//9/
+1AO1/zIwBRP+GRgDY///f9SJJ/nVgHV/LY5H8v9tYA/X/f6ADq/51YAbXq/XY238n+2L/H/2MA6
3//xAP8f/awBtv+yP6//+gDY///f3/f22/l1YB1fz+rZAMb/vz/YA/3/fmADq/789WAGM/LYv9+d
j/f8ZH/f/swDtf/tP/aP/2n/7UAf9/oBtf+tsA2P+bF/uq/PVgHV/P+tkApH+/P6gDa///Orjdjj
LZ+fq2Nsxv5f7G9X/JJ2f+7UA/3//UA/3/2tt/+R/+N23//0AyP/P1/v+/MA2P+bGAfkdWAdn/Nj
jPz/nVgCQfn/fk/3VgGN/J/hsYB/v//oBkf+yMA/3/Wj/f/awD/9r/wDbf//SD/f9/gUS2fr89WA
Wj9P9+YB+f8D80SADY9X8mxgC0dX8jGQCkf52oA/ySQDtf79bH/f/rQDtf/tQDtf//Y3tf79SSAO
r+WNpHV/OxgDY/ltYB1fz1RsYABIKQQAJBJIAJBAAAZH/ttANt/9rANt/2RgAAAAAAAAAABJLakk
ApP/pEApFtUSAAAAAAAAAAAAUi2/620SAAAAAAAAAAAAGR/z//4pEAAAAAAAAAAAAf9/trsdr1aR
AAAAAAAAAAAAKJ/i0QAkhAAAAAAAASSkFtZFsW2dbtP0/wH5P9sYJAOr+QDqtrscjkMbbbTSBRKQ
kkAAABJBSKStoY3Ihsdrkdifk2NsgDq/7a5EDGrbbFoUiiSQCAAAAAAAApH5dWADq/6kQAAAAAAA
AAAANj/vz2cjjci/P+tkAAAAAAAAAAACkdX8v8fp/rZAAAAAAAAAAAALR+QttokkAAAAAAAAAAAB
RPz+vyfr8wAAAAAAAkloSSABRLQkEAFEpCAEkpCSQCSfn/fkfX8pJAAAUgKJSJJAJBRAgACidr/f
8tsAZH8/4/PVkkAfX8urAGR/z8wDY/78nV+vV6P5yMA2PV+uRgFo/PV+tEgH5dV9fz/vzALZ/v6/
x1YAFo/4MjAOr/h+RSIB+f9+f9sYBjf8/MA6v5fWkQC0dXYNjAOr+f91YBbP8UiAdU6Ox6v52sAt
n+P1/v+7MAH+/7/W2kbWkWz/PzsaRbPr+f11YB2f9+f8olo/zqyD6/lsYAYzqdVAOr/m1gFo/L60
iAbHq/nYyRQJBALb/v//oBSP//kkgCkf8tsAHV/356sAMb/vz/bR1f9+X+/ON/Lq0TqmMgBjPyQD
q/5sYBaOqUiAdX8v8PzALb//82O1/z8yCAKT//82MAGx/JADG/78/qkdX/LZ1f9+er+djJNg6Gxg
B1f8/MA6v5bGASTqvzSIB+f8/PV7Pa2sAtv//z//5sYAH5/xscb1bZSP1+XVxux/L/dWAfn/KRAP
y6rYwDGdTq/na2zY/78/7qwDq/nq7WkYz8v9RIB/f82sgohALb/n56v+dWABSPz+vy/X+xsA2P+A
/MkgH5/X5xkAtn16HU6MAtH5P8fktEAxn56v5P8/MAf7/g/UAtv+JB+f87MABseq+vVtEAWjq/k6
uRgBseqtEAYzYkAdX/PyGNgBjfz/h1ZBAHV/3afrtf7awCkfkgFE/PV/NsgAEkgACQQAAADY/k6r
GQAJJbCkQAAAAAAAAAAEgtGM6skgAAAAAAAAAAAADq2yAAAAAAAAAAAAAAAAAAAA
---ENDGAME---
Command & Conquer: Red Alert
---GRAPHIC---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---ENDGAME---
Jazz Jackrabbit
---GRAPHIC---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---ENDGAME---
Mixed-Up Mother Goose
---GRAPHIC---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---ENDGAME---
Wheel of Fortune
---GRAPHIC---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---ENDGAME---
Windows 3.11 for Workgroups
---GRAPHIC---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---ENDGAME---
Raptor: Call of the Shadows
---GRAPHIC---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---ENDGAME---
Worms
---GRAPHIC---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---ENDGAME---
Tyrian
---GRAPHIC---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---ENDGAME---
Tyrian 2000
---GRAPHIC---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---ENDGAME---
Jazz Jackrabbit Text
---GRAPHIC---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---ENDGAME---
Doom
---GRAPHIC---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---ENDGAME---
Doom II: Hell on Earth
---GRAPHIC---
CAfAAP5AAAD2QI9gP4Bm/gfyAAF3gA9kCPZgAAZt8D+QADN3eAD2QI9mAABm9hd/gfyABm9hd4AP
ZAj2YBAABm9h1bv8D+QAZvYXeAD2QI9gD+Bm9h1bv8D+YCALvsF3gA9kCAD4Bm9h1bvUl3BsF3gA
9kCAB8Bm9h1bvjGwC77Bd4AHsgQAPgZvYdW74xsAzewXeAA9gAH8ZvYdW71JdwzewXeAAYAABm9h
1bvgEADN7Bd4AD2AAfxm9h1bvUl3DN7Bd4AHsgQAPgZvYdW74xsAu+wXeAD2QIAHwGb2HVu+MbAL
vsF3gA9kCAD4Bm9h1bvUl3BsF3gA9kCPYA/gZvYdW7/A/mAgC77Bd4APZAj2YBAABm9h1bv8D+QA
ZvYXeAD2QI9mAABm9hd/gfyABm9hd4APZAj2YAAGbfA/kAAzd3gA9kCPYD+AZv4H8gABd4APZAgH
wAD+QAAAeyBA+AAfyAAABgPZAh8AA/mAgAAA9mAewfwAMAQAAA9jAAAAIAAA9kC9g/gADAEAAA9k
CD4AAP5gCAAA9kCB8AAH8wBAAA9kCA+H8AAYCAAA9hAgezAAAIAAAewgR7P4AwAIAAAD2QI+AD+B
AAAB7BAj2fwDAACAAPYQID2YAAAEAA9kCAPYfwABgCAA9kCAB8AAH8wBAA9kCAA+AAD+YAgA9gAB
/AADAQAPZAAAAAB/IAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
AAA
---ENDGAME---
Epic Pinball
---GRAPHIC---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---ENDGAME---
Quake
---GRAPHIC---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---ENDGAME---
Reply 2 of 17, by elszgensa
Nice. I don't see me using this a lot since I actually like the command line, but I bet there's enough young'uns out there that don't and just wanna play already and will appreciate this.
Some things I noted:
- The first thing I did was disable sounds, since I don't like my interfaces to go DINGDINGDINGDINGDING while interacting with them. Maybe a "less noisy mode" with sounds just for certain, special actions?
- Unlike everything else, very long menus (like your "press shift on me" example) do not smooth scroll, which was a bit jarring. Then again, one could just refrain from making menus that long... meh.
- A way to control animation speed/disable them entirely would be nice. It felt ever so slightly sluggish. And I mean "felt" since afaict changing focus is instant, it's just the cursor that's lagging.
- Entirely optional, but I think adding a panel showing a snippet of free form text (say, two or three lines below the title) could be useful, for things like genre, year, whatever - avoids having to press shift on every entry.
About the tile size - The current one seems fine to me. But maybe slightly smaller ones in a denser 4x5 grid might be nice too.
Edit:
- Invalid corrupted base64 tile data (I tried corrupted invalid characters and duplicated lines) makes that tile look wonky, which is fine. However, not enough data (but still properly "ENDGAME"-terminated) makes the entire database not load, which isn't. If you expect users to copy tile data via forums etc, someone down the line will mess up.
Reply 3 of 17, by MrD
Thank you elszgensa.
I should possibly make the default created .INI default to no sounds, just like it defaults to no gamepad, because yes it can be annoying and I don't have a frame of reference for the volume (I'm manually poking Ad Lib registers - I was surprised I got it right at all! I don't have a tool like my YM2612 editor yet to tweak the patches to make them pleasant).
Hmm, I am surprised the side menu doesn't smooth scroll. The entire interface is a Mode X screen so when you press Shift it's moving the displayed screen to the side just as it would if you were scrolling a long wide grid horizontally. Are you saying that the animation is slow, or it happens instantly, or it's inconsistent? What system/emulator were you using? Ah you mean the items -within- the menu. Yeah, there's nothing I can do about that because I can't hardware scroll that side bar independently of the body of the screen. The side menu is the closest thing to an 'advanced' feature dosdash has, and you have to have quite a few items to make it scroll (more than nine, off the top of my head? Though the items do wordwrap if you've noticed 😀 ), so dosdash 'power users' might forgive it being less glossy an interface than the main tiles. 😜
I think I should expose cursor speed in the INI. As it is, I picked a speed that was a little slower than one I'd normally choose, since I like things to be snappy, but users might find sudden scrolling jolts disorienting.
Having the freeform text or fields was something I debated a lot. I know someone who swears by the Kodi media player for example, and that system has so many different views for looking at tiles, sorting and so on. The two problems I might have with that is that the database gets more and more messy to scroll through (it's not a perfect system as it is...) and also font rendering is awkward in Mode X.
I considered smaller tiles (but then I'd be treading on the toes of more desktop-like interfaces where the icons are square) and larger tiles (Xbox 360 NXE style four-in-a-row was an option, but I wanted more than four games on screen). This layout is more intentionally Glance-like, and the size was chosen to get a lot of tiles on screen but also have a 4x5 grid slightly overhang to suggest to the user that scrolling was possible. I was also sort-of channeling the interface to Putt Putt and Fatty Bear's Activity Pack, which I had as a kid, though I only noticed the resemblance when I was done. Edit - I don't recall the reason why the interface is 320x200 instead of 320x240, which would have allowed for more tiles. Perhaps I did a calculation at some point and worked out that would get me 9 tiles vertically in video RAM without resorting to page tricks like Jazz does (and my own platform engine does).
Not having sorting for example was a combination of imitating Glance, laziness and simplicity. It's supposed to be more like Super Mario All-Stars (again, four games in a row) than a full management program.
Reply 4 of 17, by MrD
What sort of frame rate are you getting, and on what system?
I've tried it for myself for the first time on a real Win 98 system with a Geforce FX5200 AGP 128MB and an Athlon XP 2500+ and it's running -terribly- heh. It's supposed to be 60fps, not 15fps... Haven't got a clue why it's doing that. But it does run (function) correctly from windows or the prompt. I'm hoping the slow graphics performance I'm seeing is due to the AGP card's best effort performance at trying to do unchained mode.
Reply 5 of 17, by leileilol
I know nVidia Geforce cards are slow with palette changes so I hope you're not doing that for every frame.
Reply 6 of 17, by MrD
leileilol wrote on 2024-04-09, 05:03:
I thought I was, but I'm not. I'm only changing the palette during the fades into and out of the interface. If the palette doesn't change, it isn't written.
I swapped out the FX5200 for a Trio 32 and it's exactly as slow as it was before. Maybe I'm detecting vertical blanks or changing the screen address at the wrong time.
Reply 7 of 17, by dukeofurl
Really cool idea! Would be perfect for if you were trying to configure a gaming pc for kids, or someone who didn't grow up with dos but still wants to play the games.
Reply 8 of 17, by VileR
Looking good! My impulse would be to swap the font for something more tailored to low-res, which wouldn't require quite this much anti-aliasing, but that's just me.
Also: +1 for featuring Get Lost. 😀
Reply 9 of 17, by MrD
You're right VileR, the font isn't perfect. I was working on a different Mode X platformer engine with text captions and reused the font rendering and the rasteriser from there. I'm hoping that as I improve dosdash, putting a new hand drawn .chr in there will work seamlessly rather than blowing everything up. As it is, its legible enough. It originally used 8x8 bios fonts as a placeholder. Also, the limited character set reduces memory usage but prevents any use of accented characters. I may change this, but I suspect that allowing those characters will have frustrating consequences as the characters travel from the generator htm to a text editor and then into dos. I see you have some font tools on your github so that's a good place for me to start 😀
Reply 10 of 17, by MrD
I've gotten to the bottom of the 15fps issue, and it's something that I'd actually already accommodated for! 😁
If you're trying dosdash on real hardware and the menu cursor moves too slow, change gamepad_enabled to 0 (no gamepad reading at all) or 2 (custom gamepad reading). By default dosdash uses the BIOS gamepad reading interrupt, which I was told could be slow. In DOSBox and PCem of course it's an emulated hardware feature so it can be arbitrarily fast. However, if the BIOS call to read the gamepad is implemented, then if you don't have a gamepad (or don't have a sound/IBM GCA card even), then it'll sit there for a long time reading the port waiting for flags to clear that will never be cleared. I don't know how accurate 2 is on hardware yet, this is one of the things that we're currently testing here.
The cursor movement still feels a little delayed, but I think that's the double buffering perhaps, or my LCD monitor. At least it's running at the proper frame rate now.
Reply 11 of 17, by MrD
The gamepad thing being the cause of the slowdown seems to be pretty definite now.
I've uploaded a new version of dosdash which defaults to my reading routine.
If someone with a gamepad or a flightstick could test dosdash on a real DOS machine, and compare performance using gamepad_enabled=0 (then 1, then 2) I'd very much appreciate it!
Any objections to keeping this tile size?
Reply 12 of 17, by MrD
I've now tested dosdash on DOS 4! Seems to work great, though the lack of a full screen text editor makes editing DATABASE.TXT and DOSDASH.INI and DASH.BAT pretty difficult 😉 Anybody running DOS 4 on real hardware tried dosdash?
Reply 13 of 17, by Thraka
I LOVE this menu. Thank you so much! I'm going to start building out some games and stuff. Do you have the source code anywhere? Here are 3 badges for Wing Commander.
Reply 14 of 17, by Thraka
And here are some more for the other expansions.
One thing that would be nice is if I could pass in the path to a database file and have it use that.
Reply 15 of 17, by rfnagel
Sorry for necroing this older thread, but this thing is EXTREMELY cool! I really wish I had something like this back in the day when I was setting up old DOS PCs for my nephew and niece.
Rich ¥Weeds¥ Nagel
http://www.richnagel.net
Reply 16 of 17, by DeFransen
Just found this and it is exactly what I was looking for. 😀
Extra 👍 for self unloading.
But to make it perfect I would have some feature requests:
  • configurable background image
  • customizable cell size - when you have just few items it just looks better with bigger cells
  • completely hide status bar - for simple starter menus this is not necessary
Reply 17 of 17, by RetroLizard
Can the menu be customized to look different, by any chance?
