Fdisk not properly setting up my hard drives.
First post, by palyon1981
This is for a retro PC build I started this past week, the specs are as follows:
Tyan S1856S motherboard, 64MB ram, Voodoo5 5500 AGP, CompactFlash to IDE adapter, Intel Celeron 400MHz.
Basically, Fdisk is not "properly seeing" drives, whether it be a physical 3.5" IDE drive or the CompactFlash to IDE.
Both are seen properly when viewed in the BIOS, currently v1.16, have tried to update to newer versions, but am thrown errors when I attempt to do so.
The CompactFlash card is 32gb, and presently I have it restricted to 2016 MB in the BIOS.
It's absolutely frustrating, I've tried everything to get Fdisk to properly format so I can install Windows 98 on it. Have also tried to boot other operating systems, but all to no avail.
Reply 1 of 20, by Dan386DX
Are you using FDISK in DOS 7.1 (from the Windows 98 CD) or the FDISK included with DOS 6.22?
What exact message are you getting when you choose option 1 to create a primary partition?
90s PC: IBM 6x86 120Mhz. 128MB/6GB. ATI Rage Pro 3D.
Boring modern PC: R9 3900X, RX 7800XT. 32GB/1TB.
Fixer upper project: NEC Powermate 486SX/25. 16MB/400MB.
Reply 2 of 20, by RetroLizard
Socket 370 or Slot 1 board?
Are you enabling large disk support when you first run fdisk and it asks you?
Reply 3 of 20, by palyon1981
Dan386DX wrote on 2025-11-21, 06:31:
It doesn't really give an exact error or warning, it acts like the partition was created, says verifying the partitions, and tells me restart after applying the changes. Naturally I do, and I go back into DOS from Win98 SE cd, try to format C:, invalid drive specification. Go back into Fdisk (not applying any changes, just to verify things) and back to square one, no partitions shown on the disk.
I don't have access to MS-DOS 6.22 just MS-DOS 7.1 from the Win98 SE cd.
RetroLizard wrote on 2025-11-21, 06:33:
Socket 370 board, not Slot 1, and yes enabling large disk support
Reply 4 of 20, by RetroLizard
Hm. What does the bios setup utility say about the hard drive? I'd suspect either an incorrectly configured hard drive in the bios, a bad IDE cable, or a faulty cf-ide adapter.
Reply 5 of 20, by palyon1981
Well, like I said, I'm using custom sizes in the bios to try and get it to work. And also I have both CF-IDE as well as some physical IDE drives.
I actually made a bit of a breakthrough, kind of. I have two 30-year-old drives which still work. One (640mb) had Win 3.1 and that booted up fine, trying to install 98 on it, but I think the drive has some bad sectors, as it's locking up at around 30% for file copying.
And another 1gb drive, which has Windows 98 installed on it, but can't get it to boot. So at least that tells me it's a drive configuration issue in the BIOS. If I can get into Win98 at all, I can hopefully do a bios update. Tried in DOS, and no dice.
Reply 6 of 20, by wierd_w
I'd hazard that this is a 'bios int13 limitation' related problem, and that either ezdrive (0$, but eats a few kb low memory), or XTIDE XUB (needs suitable controller, nic, or bios card, which costs money) will fix it.
Reply 7 of 20, by Dan386DX
Wonder if it doesn't like the drive geometry.
Also, try fdisk /mbr
ETA: Also, instead of setting custom sizes in the BIOS, consider connecting the drive to a modern PC and running Victoria for Windows to shrink it to desired size. I find it much more compatible.
Reply 8 of 20, by RetroLizard
It's a Socket 370 board. How large are the drives in question that you're trying to use?
Reply 9 of 20, by palyon1981
RetroLizard wrote on 2025-11-21, 22:21:
Nothing crazy really, I've tried with an 8GB CF card, 512MB CF Card, and and a 32GB one too.
Also have an 18.6GB IDE hard drive, no luck with either.
As I've said several times, basically just trying to get into Windows to:
A) Update BIOS - as no progress with DOS.
B) To see how the performance is.
I only just got this board in the last week, and long story short, I was supposed to have a different board (and different cpu socket), but the seller on ebay screwed up royally.
Reply 10 of 20, by RetroLizard
Your board should be able to easily handle 32GB hard drives no problem.
Do you have any other ide cables you can try?
What adapter are you using for your CF cards?
I'd try to let auto detect configure the hard drive(s) in the bios settings and see if fdisk is happier with that.
Reply 11 of 20, by palyon1981
RetroLizard wrote on 2025-11-21, 23:13:
Your board should be able to easily handle 32GB hard drives no problem. […]
Yeah I do have other cables, have tried pretty much all of them, same results. I have tried the auto-detect option too, it ends up detecting the 32gb as 8gb or so.
Reply 12 of 20, by RetroLizard
Okay. I think I see what you're trying to do.
Do you have a burnable disc you can put the bios update file on, or something?
Reply 13 of 20, by palyon1981
For the CF to IDE cards, I have both of these:
https://amazon.com/dp/B000T9QQP0
https://amazon.com/dp/B097XS4SXP
Reply 14 of 20, by palyon1981
One other thing I will say, the CF card I'm using isn't "true" 32gb. It's actually a microsd to compactflash, since CF cards can be pretty pricey.
Reply 15 of 20, by jmarsh
palyon1981 wrote on 2025-11-22, 04:18:
That's probably your problem.
Compactflash cards work in native IDE mode. They can essentially function exactly the same as an IDE HDD.
SD cards are completely different and the adapters to make them appear as compactflash cards are garbage.
Reply 16 of 20, by palyon1981
Dan386DX wrote on 2025-11-21, 21:59:
How do I resize the disk/partitions? I can't find it anywhere in the program.
Reply 17 of 20, by RetroLizard
You specify the partition size when you first make it in fdisk.
Also I agree with the sd card adapter thing. It's not worth the hassle if you can't get it to work easily, and older tech is already finicky enough.
Edit: nevermind. I have no knowledge on Victoria for Windows. Realistically, though, any formatting tool will work as long as it lets you format the drive with FAT32.
Reply 18 of 20, by palyon1981
Small update. I was finally able to get Windows 98 installed on the system. Victoria for Windows made things a lot simpler. It also gives you the CHS count that I needed, to punch into the the bios for the drive to work correctly, and for the record, I'm talking about a 20gb Seagate IDE drive.
Going to try my luck on Monday with an SSD and Sata to IDE adapter, hopefully that will work well too.
Reply 19 of 20, by RetroLizard
Auto detection should configure the drive(s) correctly as long as they're not too big for the bios to handle on a Socket 370 board. Manual configuration for hard drives was no longer necessary in the late 90s.
