First post, by Joeyxp2
I've been trying to run this game with DOSBox but like many other users, I kept receiving the infamous message when running either the installation or game files:
ERROR: Not enough system handles available!
At first, I believed that the game was actually broken but a short perusal of the DOS database made me think otherwise. Someone claimed that this solution would work:
This game runs if the DOS variable "FILES" is set in the config.sys file (that you can create in the folder you mount as C:
I set it to 200, but probably any regular value will do, as long as it's there for the game to check.
Could I ask how exactly one does this?
Reply 1 of 2, by Qbix
Rank DOSBox Author
DOSBox Author
start dosbox
mount the C drive you want
echo FILES=200 >>config.sys
start the installation
Water flows down the stream
Reply 2 of 2, by Joeyxp2
Thanks, it works perfectly now! My only qualm is that SVGA mode still makes the game quite lethargic.
