First post, by kupa97
I have a DFI LANParty UT nF4 Ultra-D with over 40 bad capacitors and I need help buying the right caps to replace them with. I have included a color-coded photo of every single bulging capacitor on this motherboard. All bad caps are Chemi-Con KZG.
I would like to replace these electrolytic caps with polymer, so far I've found the KEMET A750MS108M1CAAE013 1000uF 16v; not sure if that one would work.
Which specifications should I most be paying attention to when replacing electrolytic caps with poly ones? All these numbers are hurting my brain.
