RetroPCCupboard wrote on 2025-11-29, 11:38:I have this passive GPU: […]
The attachment 20251129_105533.jpg is no longer available
It's a 1gb card. Most of the 8500 GTs I see are 256mb or 512mb.
I am hesitant to throw it out, as I like the look of it. But I know it is a very under powered card for games of it's era. What, if anything, would you use this GPU for?
i would say its usable, ive got an 8400gs 512mb i've kept hold of, i only really use it for boards that dont have onboard video.
i know the 8600gt performance wise comes under a 7900gtx, so the 8500gt will come under that. infact ive just checked the 8500gt specs and it seems to be a beefed up 8400gs, with a larger bus twice the ram and ddr3 as opposed to ddr2.
the 8600gt is the minimum requirement for games like Tomb raider 2013 and max payne 3 some of thoise cards only have 256mb of vram, so it would be interesting to see how the 8500gt handles those especially with 1gb, though you may still be looking at around 30fps on lower settings at 1280x720.
on my 7950gt, Batman AA makes around 45fps, mass effect trilogy 30fps, dead space trilogy i think was around 30fps, all on lower settings at 1280x720, Doom 3 maxed out at 720 was 55fps, also i was using a low end 2.6ghz core2duo which isnt the best.
i would say it would be perfect for a win2000/xp gaming build up to 2006, though you may be surprised by the fact it will run much later games, depending on the type of game.
ive found there are games released in the last couple of years that run on my 7950gt under DX9, some pretty good, your card with the extra vram and later features will probably give good performance especially if you pair it with a decent cpu. i would try it out with windows 7 x64 for the majority of games, and windows 10 for newer releases and see how it does.
