Celeron 266 an interesting CPU
Reply 20 of 63, by MattRocks
pixel_workbench wrote on 2025-12-01, 04:54:
I ran some gaming benchmarks, and a cache-less Celeron needs to reach 450mhz just to equal the performance of a Celeron 300A at stock, so yeah, it was bad. But for some reason it's not in demand the same way other historical flops are, like a fx5800 or a 2900xt.
The cache-less Celeron was not too bad. It was the later on-die-cache Celeron that was too good.
The cache-less Covington Celeron was never designed to compete with Workstation CPUs because they occupied different product tiers. Any confusion emerges from Intel historically focusing on the Workstation and Enterprise tiers..
Office / Value tier:
Cyrix 6x86
Cyrix MX
Cyrix MII
Celeron <- this the product in question
IDT WinChip
Cyrix M3
Workstation / Performance tier:
Pentium
Pentium MMX
Pentium II
Pentium III
Enterprise / Server tier:
Pentium Pro
Pentium II Xeon
Pentium III Xeon
These tiers are very clear. The important nuance is that hobbyists transcend tiers by picking whatever delivers most bang for buck, and throughout history hobbyists generally did not choose a budget office CPU to chase gaming performance. Intel entered the budget Office tier in 1998 with very clear established marketing: "Pentium inside" is what hobbyists should be seeking, not something else!
From a tier perspective the oddball is not the original Celeron - that Celeron fits unambiguously in that budget office tier alongside Cyrix processors (good for MS Office, poor for Quake, rubbish at Adobe Premiere Pro). And, as expected, hobbyists immediately noted that Intel's new budget office CPU performed exactly like a budget office CPU.
The mistake came later. All Celerons were CPUs that supported out-of-order instructions, a feature that Intel itself had argued meant they didn't need a cache at all - so why add a cache to the budget Office tier? And, why add a cache that runs cool?
For hobbyists, adding a small cool cache to the Celeron instantly blurred the boundary between Office tier and Workstation tier. And, it didn't stop there because hobbyists found a way to overclock the 566MHz Celeron to 1GHz when Intel's premium enterprise CPU with bigger hotter cache topped out at 800MHz.
For a brief moment the tiers collapsed - it takes a very special kind of thinking to believe Intel intended the Celeron to collapse the product tiers that Intel had spent decades crafting.
Note: I intentionally omit AMD from this recount because AMD were on a mission to force errors at Intel.
Reply 21 of 63, by H3nrik V!
Grzyb wrote on 2025-12-01, 05:16:
Oh yeah, it seems that the 1st generation Celerons were actually double-castrated... The lack of L2 cache is obvious. But they w […]
Disruptor wrote on 2025-11-30, 20:35:
At least they are good overclockers.
Like Mendocinos.
But they were probably also underclocked - I believe the technology was designed for 100 MHz FSB, but they were artifically specced as 66 MHz FSB.
I don't believe they were made for 100MHz FSB as their P2 counterparts that were at the same time, were also 66 MHz FSB IIRC (P2 233-333)
Reply 22 of 63, by H3nrik V!
MattRocks wrote on 2025-12-01, 06:42:
I have yet to see a 566 running at 1 GHz except if liquid N2 cooled or something.
You may be thinking of the 566A, based on the Coppermine-128 core, they were usually pretty easy to get to 850 at least with 100 FSB, and probably more. But Covington/Mendocinos are near impossible to get there. I have nine [9] Mendocino 400s, that I've binned to find 2 that would go 600 - not one was able to do it stable.
Reply 23 of 63, by MattRocks
You are right, it was a Coppermine-based Celeron. I built one for my brother (following the instructions of a momentarily famous Japanese tinkerer) and my brother still has that box, meaning I might be able borrow it - or he might be protective.
It was a ~500MHz CPU at 1GHz with stock cooling (probably 566). You needed to cut pins and short pins. I think I shorted the pins on the (socket to slot) adapter rather than on the CPU itself, and I remember using sellotape on the pins instead of irreversibly cutting them. I went the extra mile to keep the modification non-destructive but today I wouldn't want to disassemble it because the sellotape might have failed, and the copper wires (wherever they are) might be held in place by pressure alone.
Reply 24 of 63, by Grzyb
H3nrik V! wrote on 2025-12-01, 06:50:
I just had a look, and...
May 1997 - Pentium II (Klamath), 350 nm, 66 MHz FSB
January 1998 - Pentium II (Deschutes), 250 nm, 66 MHz FSB
April 1998 - Pentium II (Deschutes), 250 nm, 100 MHz FSB
April 1998 - Celeron (Covington), 250 nm, 66 MHz FSB
Covington's release date was clearly the same as the 100 MHz Deschutes variant's!
Reportedly, the success rate of 66->100 FSB overclocking was 100%.
Can't be absolutely sure, but I'm inclined to believe that Covington was designed for the 100.
Nie rzucim ziemi, skąd nasz root!
Reply 25 of 63, by PC@LIVE
MattRocks wrote on 2025-12-01, 00:32:
You have confused Socket 7 with Super Socket 7. […]
PC@LIVE wrote on 2025-12-01, 00:21:
.. even if what you wrote is true, both the K6-2 and the Cyrix M II, were actually competitors of the P.MMX...
Socket 7: Pentium MMX competed directly with AMD K6 and Cyrix MX - these all ran on Intel VX and TX motherboards with 66MHz FSB and SIMM memory banks.
Super Socket 7: K6-2 is clearly a later generation with 100MHz FSB and DIMM memory banks - there was no matching Intel motherboard and the P.MMX had been discontinued.
Socket 7 chipset designs: Led by Intel.
Super Socket 7 chipset designs: Led by AMD (implemented by VIA, ALI, SiS).
Upgrade path: You could use all Socket 7 era CPUs and expansion cards on a Super Socket 7 motherboard, but comparing K6-2 3DNow to P.MMX makes no historical sense because they launched one year apart and on different platforms with very different instruction sets and different performance envelopes.
By many here, some believe that Super7 exists, in reality they are all S.7, no one prevents you from putting a P.MMX at 250 with FSB 100 and Multi 2.5X, at that point what happens?
This without going to get a Tillamok, which from the factory went to 266 or even 300, for me they can be compared with the K6-2 and the Cyrix M II, but if there is the belief that this is not the case, I can't add anything else.
Indeed, I would say that it was AMD and Cyrix, who confused the ideas, because when Intel abandoned the 486 with the DX4-100, they released the 5X86-P75 and the 5X86-1Xx, both had comparable performance to the P75, which was like an incompatible socket, so ...
AMD 286-16 287-10 4MB
AMD 386SX-33 4MB
AMD 386DX-40 Intel 387 8MB
Cyrix 486DLC-40 IIT387-40 8MB
486DX2-66 +many others
P60 48MB
iDX4-100 32MB
AMD 5X86-133 16MB VLB CL5429 2MB
AMD K62+ 550 SOYO 5EMA+ +many others
Reply 26 of 63, by H3nrik V!
Grzyb wrote on 2025-12-01, 07:44:
I just had a look, and... […]
I stand corrected. Apparently the retro goggles needs a cleanup regarding time line 🤣 maybe I got that wrong because nobody owned the 100FSB P2s at the time, because they were crazily expensive 🤷‍♂️
I have 2 Covington 266 and 2 Covington 300 - all run at 100FSB, albeit not all at default voltage 😀 That's why the Abit BH6 was so popular back then.
Reply 27 of 63, by MattRocks
PC@LIVE wrote on 2025-12-01, 07:47:
By many here, some believe that Super7 exists, in reality they are all S.7, no one prevents you from putting a P.MMX at 250 with […]
Mechanical socket compatibility does not define market competition.
Running a Pentium MMX on a Super Socket 7 board is no more meaningful than:
  • Pentium 75 on a Super7 board, or
  • K6-2 into an Intel TX chipset board.
These combinations fit, but that doesn’t make them competitors. A pedal bike fits on an F1 circuit too — that doesn’t make it an F1 competitor.
The simple historical facts are:
  • P.MMX is a performance CPU discontinued in 1997.
  • K6-2 is a midrange CPU launched mid-1998.
K6-2 and P.MMX:
  • Do not overlap in time.
  • Do not overlap in price segment.
  • Do not overlap in performance class.
  • Do not overlap in technology (floating point SIMD extensions, µm CMOS process).
  • Do not overlap in platform (AGP, 100MHz FSB, PC-100 SDRAM).
When new, there was zero competition between K6-2 and P.MMX, or competes in the same way that a Celeron Covington competes with a Pentium III.
Reply 28 of 63, by pixel_workbench
The cache-less Celeron was not too bad. It was the later on-die-cache Celeron that was too good. […]
Cyrix 6x86
Cyrix MX
Cyrix MII
IDT WinChip
Cyrix M3
Pentium
Pentium MMX
Pentium II
Pentium III
Pentium Pro
Pentium II Xeon
Pentium III Xeon
Intel's marketing was BS as usual, I would argue that an out of order architecture was more dependent on cache, given how disabling the L1 cache on a P2 or P3 instantly drops it to the level of a slow 386, whereas the Pentium MMX behaves more like a 486 when the L1 cache is disabled.
What Intel actually wanted was a piece of the budget and mainstream system market, because they abandoned socket 7, and many people weren't willing to shell out for a high end expensive P2 system. So they stripped down the P2 in the cheapest and simplest possible manner by removing L2 cache, and figured people would be too stupid to realize what a terrible performer it was. Why would anyone buy a crippled Celeron system when you could get the AMD K6-2?
The fact of Celeron 300A being too good was simply a byproduct of overclocking, and only applicable to the lower clocked versions. Once they got to 366mhz and higher, stable operation at 100mhz fsb was a lot less common, so it remained as a good budget cpu, and what the Celeron should have been all along.
My Videos | Website
P2 400 unlocked / Asus P3B-F / Voodoo3 3k / MX300 + YMF718
Reply 29 of 63, by SPBHM
I can't really hate on those Celerons when they were so much cheaper than PII, like 1/3, 1/4 the price sometimes,
I never had one, but I got my 266 experience with my PII 400, disable l2, reduce FSB to 66 and there you go, free Celeron 266!
on a side note I tried to google the Celeron 266 review which was available like an year ago, but anandtech seems to be all gone, so many reviews of old parts gone 🙁
Reply 30 of 63, by AlessandroB
pixel_workbench wrote on 2025-12-01, 13:30:
Intel's marketing was BS as usual, I would argue that an out of order architecture was more dependent on cache, given how disab […]
Cyrix 6x86
Cyrix MX
Cyrix MII
IDT WinChip
Cyrix M3
Pentium
Pentium MMX
Pentium II
Pentium III
Pentium Pro
Pentium II Xeon
Pentium III Xeon
Rumors over the years have it that Intel was so brazen they produced crap and thought their stupid customers would buy it. I don't have the details, but I think that at the time, for office/general use, the Celeron 266 was fast enough, and that slot 1 motherboards were more forward-thinking, giving the impression that they could be upgraded, unlike the Super Socket 7, which, after all, is still Socket 7 and couldn't have gone much further.
Reply 31 of 63, by MattRocks
Cyrix 6x86
Cyrix MX
Cyrix MII
IDT WinChip
Cyrix M3
Pentium
Pentium MMX
Pentium II
Pentium III
Pentium Pro
Pentium II Xeon
Pentium III Xeon
What Intel removed from Covington was the L2 cache, not L1 cache.
I agree, Intel sought a slice of the budget office market and Intel never intended the office Covington to perform like a power user Pentium II.
Bare with me. Think of the NetBurst architecture. Intel promised the dream with NetBurst. Intel promised new heights in performance. Intel made clear everyone wants NetBurst! And then, when the excited new buyers unwrapped it and set it up.. it sucked.
Now think back to the Celeron. Intel made no big performance promise with Covington. Intel made clear the Covington targeted the slowest 20% of the PC market - and nobody should want to play games the slowest 20% of PCs! The promise was even typed onto Intel's retail packaging, "Designed for the Basic PC ".
There was no mention of 3D gaming. There was no mention of performance. There was no mention of anything exotic at all - just that it would deliver the slowest 20% of PCs. There was no bad marketing!
In that light the Covington wasn’t a bad soldier. It was a deliberately basic soldier and it diligently performed its basic duties at basic speed - it behaved exactly as a next generation basic product must, which is to not upstage the previous generation flagship. That meant the Pentium 233 MMX.
Now think of GPUs. Simply compare GeForce4 MX and GeForce 3. See how the next generation basic model quietly takes up its position guarding the rear - and that is exactly what Covington did! To say Covington is bad is to say GeForce MX is bad - they are bad, and they are supposed to be bad!
The actual "bad soldier" was the Mendocino because it broke ranks and wiped out half of Intel's roadmap. But, if the Mendocino was so dangerous, why did it ever launch? Because AMD 3Dnow changed the rules - it was cheap and exciting and wiped the floor with basic Covington.
For those who play chess, 3Dnow was "check!" Intel's response, the Mendocino, was a forced error. Adding 128KB on-die L2 was the cheap necessary response to an immediate problem. Intel didn’t want to launch a budget office chip that would destroy the Pentium II and Pentium III - it just had to.
And, Intel's sacrifice was AMD's well earned game board positioning.
Reply 32 of 63, by H3nrik V!
MattRocks wrote on 2025-12-01, 15:18:
Wasn't the Mendocino as much an early test vehicle for actually getting L2 cache on chip? Concepts for the Coppermine may very well already have been on the roadmap at that time?
Reply 33 of 63, by MattRocks
H3nrik V! wrote on 2025-12-01, 15:25:
Yes, Mendocino was the testbed for on-die L2 cache. But no, Intel didn’t intend for Mendocino to be the depth charge under their own product tiers.
The Mendocino L2 cache had far higher bandwidth than the Pentium II L2 cache - that is the record. The budget $150 CPU beat the premium $400 CPU from the same vendor - that is the record.
How can any imaginative retelling present that record as being part of an intended roadmap? Can you imagine a CEO chanting, “Let’s create a budget CPU that demolishes our premium CPUs!”, “Let’s destroy our shareholder's return on investment!”
Or can you imagine a simple elegant explanation -the Mendocino was a forced error in response to AMD 3Dnow?
Reply 34 of 63, by pixel_workbench
What Intel removed from Covington was the L2 cache, not L1 cache. […]
Cyrix 6x86
Cyrix MX
Cyrix MII
IDT WinChip
Cyrix M3
Pentium
Pentium MMX
Pentium II
Pentium III
Pentium Pro
Pentium II Xeon
Pentium III Xeon
Plenty of kids growing up in the 1990's wanted to play games but could not convince their parents to shell out $2000+ for a brand new P2 system. Or even adults who wanted to play games but the money was tight. The argument that a person on a budget has no interest in gaming is some kind of Intel marketing mumbo jumbo.
If a user just wanted a basic office PC, there were plenty of cheap P1, Cyrix or even old 486 systems to be had, all cheaper than a brand new Celeron 266 system. Considering all the options of 1997-1998, the cache-less Celeron was more like a desperate attempt by Intel to sell a new product in the budget segment, without having an actual competitive product that was planned all along to compete in that market segment.
My Videos | Website
Reply 35 of 63, by Living
the hate went not for the processor itself, but for the bundle that acompannied the Covington. Like the K6-2, C3, Celeron willamette, etc. Nearly all came with the cheapest and bottom of the barrel parts, thus, making the experience a nightmare half of the time.
of all the low end processors, ONLY the K6-2 came SOMETIMES with decent motherboards and mid range components. Mendocino was 95% of the time paired with shit too.
Reply 36 of 63, by rmay635703
Like Mendocinos.
Intel would have never done it but if the L2 cacheless chips would have been sold with motherboards that had AGP and cheap onboard burst L2 or a faster than 66mhz FSB combined with cl2 pc100 or pc133 sdram (not fully mainstream then but 83 and even 90mhz FSBS were available and stable)
You then WOULD have actually had a perculiar and semi-compelling chip.
PC100 combined with a better intel chipset that actually could take advantage of sdram would have been a net positive.
The other possibility that Intel would have never supported was to remove L2 but boost L1 to 64k
L1 boost’s performance much more than even onchip L2 and would have “almost” made it tolerable.
Celeron should have always released as either socket 8 or 370 and skipped the slot.
Reply 37 of 63, by MattRocks
pixel_workbench wrote on 2025-12-01, 16:24:
I agree there is a budget gamer market, but budget gamers don’t spend the premium of buying a new computer that performs in the bottom 20%.
And my position is proven by default because gamers didn’t buy a new WinChip PC in the 1990s. And that low spec new PC market is the exact market that Intel promised to hit with the original Celeron.
I see no marketing fluff - Intel promised the Celeron would deliver low performance, for offices that needed only low performance with warranty and support. Like the WinChip!
The same pattern has played out many times. Netbooks are a case in point - nobody buys a new Netbook to play new games.
Budget gamers buy last year’s midrange computers instead - cheaper, slightly more headroom, slightly less efficient, somewhat more matured drivers, and less warranty. At the time that would have been a MMX.
There is a business case study here - don’t be all things to all people. If you are Ferrari, you will struggle to sell a Mini. The 1990s Intel brand was probably wasn’t associated with budget CPUs, but that is exactly what Intel wanted to change when they launched “not a Pentium!”
Reply 38 of 63, by H3nrik V!
The thing is; aimed at budget PCs or not - the FPU of the Covington was just as capable as that of a Pentium II, even without the cache. That, combined with the overclockability made the Covington a pretty popular gaming CPU ...
Reply 39 of 63, by MattRocks
H3nrik V! wrote on 2025-12-01, 19:06:
I don’t remember it being a popular gaming CPU.
I remember it being overlocked with curiosity, and it is a curiosity because its performance is dependent on steady OoOE - something MMX didn't have. For the sake of curiosity, much like K6-2 and P4 pair better with different VPU/GPU, the ideal VPU/GPU pairing for a cache-less Celeron is probably different - or the same but for different reasons.
