First post, by muon
Hi.
One friend of mine has that 486 motherboard: Aquarius Systems - BCOM UMC-486A.
This board has a problem with the cache system: it is not working properly. I changed the 8kx8 SRAM cache chips (UM -> MOSEL) but it didn't fix the issue.
Perhaps the TAGs chips are faulty. And that's is my question. The board use UM61416k-20 ( 16kx 8 -> https://wellgainelectronics.com/sram/10729-um … m61416k-20.html ).
Do you know equivalents chips for that reference?
Another thing that worries me is that I searched for more information about this motherboard and couldn't find anything, but there are some pictures (https://theretroweb.com/motherboards/s/aquari … ystems-umc-486a) with the same cache configuration (64k - 8kx8 chips) but the TAG chips are HM6288P, which are not 16kx8 but 16kx4.
I'm a bit lost. Any ideas?
Thanks in advanced
