Okay, small update. […]
Ozzuneoj wrote on 2025-08-17, 02:26:Ohhh boy. […]
Ohhh boy.
An older friend of mine brought me a couple of computers he's had laying around for a while. One is from 2007, and one is from 2013. To put it mildly, these things were overkill at the time.
When he opened the trunk of his SUV I couldn't believe how MASSIVE these things were.
To give some perspective without giving it all away: The one from 2007 is an OEM system with its original 1000 Watt power supply, and it has two video cards in SLI. The one from 2013 is a custom prebuilt that was built with... get this... 64GB of RAM, two 512GB SSDs, a Bluray Burner and a Corsair AX1200i 1200W 80 Plus Platinum (!) PSU... yes, built that way in 2013. It also had two GPUs in SLI, though he said it never quite worked right with both, so one had been taken out and put in storage somewhere for a while (he will get it to me when he finds it).
To temper expectations: Neither one has top of the line GPUs for the time, sadly, but they are both really unique and (as far as I can tell) somewhat rare systems these days.
They are quite dusty from many years of use, so I want to get them cleaned up before doing their photo shoots. I will post pictures and more detailed specs later.
Also, these are two of the largest computers I own. The 2013 one is by far the largest tower I've ever seen in person, and I own some full towers from the early 90s and had an early 2000s Gateway server\workstation chassis for a while as well. This is bigger than all of them.
Stay tuned. 😮
Okay, small update.
I did some cleaning on the 2013 system. When I started seeing some weird bluish green crud down in the massive (and unecessary) bottom "chamber" in this case, I remembered what my friend told me a while back. He said when he bought the computer they only gave water cooling as an option, even though he didn't want it. Eventually, something did actually fail and it leaked all over the place and killed the motherboard. They replaced the motherboard and he used the computer for years and then gave it to a relative when he bought a new machine.
At some point it stopped booting and he took it back from the relative. He assumed the processor had been damaged by the old motherboard and finally just stopped working. I know this is pretty uncommon (especially for high end gear chips like a Socket 2011 Ivy Bridge CPU), so I was hoping it was something more easily fixable.
Sooo... after getting the machine all cleaned up and pulling out the Corsair AX1200i PSU (absolutely awesome PSU) for inspection, I decided to give it a go. The motherboard (Asus P9X79-E WS) would give a 00 code and a blue light near the CPU socket. I googled it and the number one suggestion was to use the BIOS Flashback feature to reflash the latest BIOS. I cannot believe how EASY it was to do this! I just put the file on an old FAT32 drive, named it P9X79EWS.cap, stuck the drive into the flashback port on the PC, pressed the BIOS flashback button for 3 seconds and the light started blinking. When it stopped blinking 5-10 minutes later, I turned the system on and it is now booting to the BIOS just fine!!
This thing is a BEAST by the way.
The case is a CyberpowerPC badged AZZA Genesis 9000B. It is reversible and arrived to me with the motherboard upside-down and the case opening on the opposite panel of a normal ATX system. You can pull the motherboard+ card tray out completely, flip it around and then make it a standard ATX layout. It also has incredibly huge fans in the top. Honestly, I'm not a big fan of the case compared to what I had at the time (CoolerMaster CM 690 II Advanced). Fiddly mechanisms, surprisingly cramped spaces (despite it's insane size) and massive chunks of useless plastic that hinder airflow. Still, it is a unique and interesting design. Very very 2010s.
I have attached some pictures of what I have done so far. It is just flopped onto the floor for now. In the pictures it is about 3-4 inches shorter because I have the bottom plastic panel removed (I had to hose out the dust and water cooling crud). It stands around 26" tall. 😮
It has an EVGA GTX 770 4GB (with a second one that I will get eventually), 64GB of XPG DDR3-1866 CL10 RAM ("only" 16GB installed currently... some of the heatsinks fell off too), an i7 4930K and 2x 512GB Adata SX900 SSDs.
I will post more later as I make progress... probably in it's own thread.
So yeah... this is easily the most beastly machine I have ever been given in a non-working state.
