First post, by FullYes
Good day to you all!
I have the following machine:
Soltek SL-75KAV, KT133A chipset
2 x 256Mb PC133 SDRAM, CL2
Athlon XP 2600+ Barton CPU (date code 0311, so unlocked
Q12 (latest) bios which I have patched with bios patcher to recognise the CPU correctly
550W EzCool PSU (40A on 5v)
Gigabyte FX5900XT
AWE64 CT4500 - not installed during testing.
Timeline of events:
I installed the Barton after removing the previous CPU: Athlon XP 2000 Palomino. System POSTed no problem, but I’m limited to 1666MHz - confirming the CPU is unlocked as original multiplier is 11.5x which would limit me to 1533MHz if it was locked. It didn’t recognise the CPU. But it worked fine. Everything was working properly/normally at this point
Made the pin mod to the motherboard by bridging the relevant 2 pins on the back of the motherboard PCB. I only did the mod to the 5th multiplier pin, as this is the only one I need to worry about on this board as the other jumpers are controlled by dip switches (which can also be disabled for auto-configuration.)
After the mod I set the dip switches to give me a 5x multiplier=13x with the mod - Nice and conservative.
Reconnected PSU etc: No post
Cleared CMOS / removed battery: No post
Tried reducing FSB to 100MHz and set multiplier jumper to auto (disabling dip switches) which should have given me 19x100 (since 11.5=19x with the pin mod)- No post
Re-enabled the dip switches and tried powering on again. This time it Posted! and informed me I had an “unknown CPU” at 1300MHz. This is correct as that is how I had set the dip switches.
Power cycle. No post again!
So it will only post if I perform the following procedure. It’s repeatable and reliably doing this;
Turn off PSU and press the power button to discharge any capacitance remaining in the system
Set dip switches jumper to auto/off
Power on. Wait 10 seconds. Power off
Set dip switches jumpers to manual/on
Power on. POST successfully
Now I knew how to get it to post, I was able to set the multiplier to what I wanted and I’ve had it posting up to an 18x multiplier (2400MHz) So the mod has worked, and I’m able to run tests like prime95, memtest86+ etc at up to around 2150MHz with a small bump in FSB on the 16x multi or a bigger bump in FSB on the 15x multi and it’s completely stable. Soft resets also work, reset button or ctrl+alt+del but a power cycle means I need to pull the power and mess with the dip switch enable/disable jumper.
I patched the bios at this point, but it made no difference
I’ve contacted a few people on the forum who’ve had this board in the past, but so far I’ve not spoken to anyone who has successfully done this mod to this board
Anyone got any ideas, it would be appreciated. Many thanks!
System 1: K6-3+ 600MHz! MS-5158 (430TX), Voodoo3, AWE64
System 2: Athlon XP-M 2800+ SL-75KAV (KT133A) FX5200
System 3: 775i65g (work in progress) FX5900XT
System 4: i7-2600k, P8P67-M, GTX 460
