WD90C30-LR Jumper settings
Reply 20 of 27, by H.W.Necromancer
Hallo, I would be also very grateful for jumper description of this card. I have the same and it has issues in some boards and I think it needs some jumper changes. The jumper manual seems to be lost in time..
Thank you in advance for any help!
maxtherabbit wrote on 2025-09-26, 00:18:
uniQ wrote on 2025-09-22, 07:57:
maxtherabbit wrote on 2025-09-20, 13:46:
I have this same card and I did document the jumpers if anyone still cares about that.
Nice offer, thanks! I would be interested. 😀
I didn't forget about this, just haven't had a chance to dig out the card yet
Reply 21 of 27, by maxtherabbit
OK I'll try to get it out tomorrow. My recollection is that all the jumpers control video modes, and none would affect compatibility but I'll check
Reply 22 of 27, by H.W.Necromancer
EDIT: I solved the issue yesteday - it is a very special incompatibility - my UMC chipset + any sound card + faster VGA + CF card. I have removed the CF and used an old HDD instead and everything works fine.
I am still checking this interesting VGA card - but it is not a souirce od my issue. The CF card do somehow mess on the bus... Funny.
Just to explain:
It might be like that. Maybe there is simply a compatibility issue quite comon in those ancient times.
I have noticed a similar behavior on a 286 "TwinHead" based board in the past.
Now I am testing this board:
https://theretroweb.com/motherboards/s/powertech-mb459
I made it fully working (battery damaged, wrong cache chips, dirt) with one bug - distorted sound (music OK) in pure DOS Games (Prince, WOlf 3D..), surprisingly everything stable and ok in DOS4GW based DOOM and DOOM2. !!
Considered the fact doom is running in the protected mode and it is very demanding, pusing such a 486 setup to its limit, I highly doubt there is a HW problem. I was playing like an hour...😀
All benchmarks went ok too - speedsys, even memtest, CacheCHK etc...
This WDC and one older TVGA9000 (the one with the older square Trident DAC) are causing issues - and was afik doing the same at the above mentioned 286 board. (but both work elsewhere)
In both cases using a RealTek, or another ISA VGA solved all the issues.
No matter what you set in the bios - the issue was there even with disabled L1, L2 and BUS running 6,25Mhz (so pretty slow). Still the same. (Moving cards in the slots has no effect too)
Immediately after replacing the VGA - all GOOD.
I have been informed on the RetroWeb Discord that my assumption might be righ - cards are figting for some signal - such as IO CHRDY. (??)
Why I assume this:
- it needs to be something SoundCard needs extensively.
- it is glitching with all kinds of various sound cards
- it DOES NOT glitch in the Sound Card setup software - which is static and text mode only - all tests sound good
- HOWEVER if I play WOlf 3D my snd effects are distorted AND my graphics is glitching - visible "noise" at the edge where you see your ammo, lives etc. while the distorted sound plays. More movement. More glitiching.
I have seen the same with the above mentioned 286.
If I remember this 286 even worked with a later rev of TVGA9000 (internal DAC). I also know some TVGA9000 have turbo/normal jumpers somehow influencing the behavior towards bus.
- dont know if WDC is like that..(?)
For sure I can use a different VGA and I know this UMC chipset is senstive and the board is cheap ass thing - but still it is an interesting thing to study.
It might be an interesting issue for the other retro-freaks too 😀
maxtherabbit wrote on 2025-12-07, 23:06:
Reply 23 of 27, by H.W.Necromancer
H.W.Necromancer wrote on 2025-12-08, 15:41:
EDIT: I solved the issue yesteday - it is a very special incompatibility - my UMC chipset + any sound card + faster VGA + CF ca […]
I am still checking this interesting VGA card - but it is not a source od my issue. The CF card do somehow mess on the bus... Funny. I will keep my post here, just adding an explanation this is not a VGA timing issue - or not only VGA.
But OK - there were no CF cards in 1994...
Just to explain:
Why I assume this:
Reply 24 of 27, by maxtherabbit
JP1:
R1/R2 Control 800x600 Mode
R1 closed = 72Hz
R2 closed = 60Hz
Both open = 56Hz
R3/R4 Control 1024x768 Mode
R3 closed = 70Hz (progressive)
R4 closed = 60Hz (progressive)
Both open = interlaced
R5 Control Analog/TTL output
Open = analog
Closed = TTL (not usable with standard card design)
JP2 Control 0-wait state
Closed = enable zero wait
Open = disable zero wait
JP2 Control Color/B&W autodetect
Closed = pull down detect pin to ground
Reply 25 of 27, by maxtherabbit
The attachment 20251209_144404.jpg is no longer available
Pic of my card
Reply 26 of 27, by H.W.Necromancer
Thank you very much!
The TTL output is fot the card which has 9pin output too? Or what is this about?
maxtherabbit wrote on 2025-12-09, 19:43:
JP1: R1/R2 Control 800x600 Mode R1 closed = 72Hz R2 closed = 60Hz Both open = 56Hz […]
JP1:
R1 closed = 72Hz
R2 closed = 60Hz
Both open = 56Hz
Open = analog
Reply 27 of 27, by maxtherabbit
H.W.Necromancer wrote on 2025-12-09, 19:57:
I presume so yes, I figured out what the setting is by toning out the pin on the jumper block and then reading the ASIC datasheet to see its function. My guess is the ASIC supports alternate output pins for TTL mode and these cards simply didn't implement it
