First post, by wbahnassi
Hello guys, I got me a nice ATX case that used to house a Pentium II Slot 1 mobo. I wanted to replace this with another mobo I have that holds a P3 1.2Ghz Tualatin CPU on it (socket 370). Unfortunately, the Tualatin heatsink/fan cooler I have (ThermalTake Volcano 7) came too high to fit in the ATX case (the PSU is located over that area).
I've replaced the cooler with one of those puny Intel aluminum heatsink/fan coolers, but the result is not cool (pun intended). With the TT cooler, the CPU temps remained in the 30 degrees Celsius range. Now it's reaching 50 degrees after some moderate Win2K usage.. so I'm looking for advice on low-profile coolers suitable for Tualatin 1.2Ghz (not Celeron).. or if delidding would be a good idea here?
I also have a Voodoo 3 2000 installed on the mobo, and for that, I added a small fan over the GPU's heatsink, and also installed a big fan on the case's front to bring in cool air into the case. Hopefully this would help a little with the toasty voltage regulator on the card, and keep the entire inner space of the case forcing the flow of fresh air.
Turbo XT 12MHz, EGA, MFM HDD
Intel 386 DX-33, Speedstar 24X, SB 1.5, 1x CD
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
IBM BlueLightning 100MHz, CL5428, SB16, 4x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, RTX2060
Reply 2 of 10, by RetroPCCupboard
I havent tried it, but I have been looking at getting this one:
https://www.startech.com/en-gb/computer-parts … P4-sgvSxNk28mxy
I have read that the fan is noisy, so expect to replace it with a Noctua or similar. Just want it for the copper material and dense fin structure.
It does say that its for CPUs up to 1ghz, so maybe it isnt good enough for your usecase
BTW, could please let me know what software you use to check CPU temp.
Reply 3 of 10, by wbahnassi
Paadam wrote on 2025-10-08, 03:58:
You could replace fan on the TT with thinner version maybe?
This fan is the normal front-side case fan size. But I feel even if I find a fan half of this thickness, it won't be enough. It will have very little clearance between it and the PSU. It's the heatsink that is really quite high.
RetroPCCupboard wrote on 2025-10-08, 04:02:
I havent tried it, but I have been looking at getting this one: […]
It's an interesting cooler. Definitely the heatsink is better than the puny Intel one I have currently.. Perhaps this with delidding could be enough?
For temperature measurement, I just go to the Health Monitor in the BIOS and check the numbers. It shows the CPU temperature and fan speeds and voltages. It's not as convenient as a realtime program that runs in Windows... but at least it seems trust-worthy.
Reply 4 of 10, by Ozzuneoj
If the case requires the PSU to be mounted sideways so that it covers the CPU cooler, it is possible that the PSU fan is actually fighting the CPU fan and creating heat issues that way. A PSU will almost always exhaust air out of the case, and a CPU fan blows down toward the CPU. If they are near each other, airflow will suffer quite a bit.
It kind of stinks that the fan on the intel cooler cannot be flipped around. Still, whichever cooler you end up using, you may get better temps by flipping the CPU fan around so that it is blowing out away from the cooler. Normally you wouldn't want to run one this way, but if there is an intake fan on the computer then you may get better airflow and lower temps with the PSU pulling all of the heat directly out of the case. A lot of OEM systems were actually built this way with a duct and an otherwise passively cooled Pentium II\III. It's worth a shot at least and costs nothing to do.
Also, it is worth mentioning that CPUs from this era don't change temperature quite as much under load as later chips, so if it's 50C in Windows it may still be fine under a gaming load. I don't think delidding would be helpful at all unless you are trying for extreme overclocking and are planning to use a different case with support for larger coolers.
EDIT: Alternatively, if there's a small gap between the PSU and the side panel you may be able to flip the PSU around as well so that it is at least not fighting against the CPU fan.
Reply 5 of 10, by paradigital
My Tualatin 1.4 (on PowerLeap IP3/T slot 1 adapter) is cooled by one of those Startech copper coolers, as are my dual P3 1GHz CPUs.
They seem to do a good enough job.
Reply 6 of 10, by wbahnassi
Update here: was really lucky to find a fan that fits on the ThermalTake cooler, except it's very thin. It's also made out of transparent blue plastic to match the heatsink.. how appropriate. It's quite strong and quiet too.
With this installed, the board and CPU fit very easily within the case. The CPU temperature remained at 37 degrees tops after prolonged use. That's quite a drop from 50 with the stupid Intel fan.
Reply 7 of 10, by myne
In my experience from the era, the temperature was not really an issue if it wasn't insane (100+) outside of benchmarkers who would tolerate questionable stability for that golden run.
Sound was my issue back then.
Many sounded like vacuum cleaners
I built:
Reply 8 of 10, by smtkr
paradigital wrote on 2025-10-08, 06:24:
I can also vouch for that startech copper cooler on a Tualatin. It's a very good cooler.
Reply 9 of 10, by wbahnassi
I guess copper is the key here. The ThermalTake also has a copper core.
Reply 10 of 10, by bofh.fromhell
AFAIK the CPU does not have an internal temp sensor (only a very crude one to throttle on overtemp) I would not read to much into what the sensor reports.
Most likely the sensor is in the socket (hopefully) making contact with the underside of the CPU, which obviously is not ideal.
Accurate CPU temp reading is a fairly recent thing, and (not counting rare server CPU's) I don't think any consumer CPU before Intels Core CPU's had them.
Now I'm not 100% about the Tualatin, but the P3's built in thermal protection could only be read as "are you throttling yes/no" and not as a temp value.
