First post, by Virtua
i'm playing through a bunch of games on my retro computer and i feel like it's not performing as well as it should. giants: citizen kabuto plays poorly, as does max payne and even unreal if i enable detailed textures. am i wrong in thinking this machine should be more than capable for games from this era?
asus k8v-mx
amd athlon 64 3000+
ati radeon 9600 xt
creative sound blaster audigy 2 zs
there are a couple of things i'm unsure of. firstly, agp fast write is disabled despite enabling this setting in the bios. secondly - and this may be related to the first issue - my board is not strictly an asus k8v-mx, but a k8v-mx/s by fujitsu siemens, aka the d1711. it was a bit difficult to track down updates for the board but i updated the bios to the latest. i've also tried a few versions of the via 4-in-1 drivers for the board, and am currently using the catalyst v6.2 driver. not sure what else i could potentially try, so if anyone has any suggestions i'd be willing to experiment
i've been installing v2.1 of the unofficial service pack so i haven't tried a windows install without it yet but that will probably be my next attempt. i also want to point out that i'm not exactly trying to push the computer to its limits. i've been using a crt that looks real nice at 800 x 600 @ 85hz so, if anything, i want to believe that i'm well within my limits. unless i'm wrong...
win 10 : x570-a pro • ryzen 5900x • geforce rtx 3070 • sound blaster x ae-5 plus
win 98 : k8-vm800 • athlon 3000+ • radeon 9600 • sound blaster live! 5.1
Reply 1 of 11, by RandomStranger
I don't know Giants: Citizen Kabuto, the other two games should run well even on a PC half this fast with maxed out graphics in higher resolution than what your are using. This should be a triple-digit-frame-rate PC for those games.
Reply 2 of 11, by Virtua
thanks for the confirmation. i have a vague memory of playing half-life 2 with my 9600 xt (the card even came with a code for the game) back in 2004 with acceptable framerates so i was a bit confused by how this current computer is running. not sure what the problem could be. my first thought is the board but it's a stab in the dark
Reply 3 of 11, by Joseph_Joestar
Virtua wrote on 2022-12-23, 12:26:
Updating the BIOS to the latest version is likely what caused the performance drop. See this thread for more details. With that board, you want to stick with the earliest possible BIOS version, something like v0112.
Don't use unofficial service packs. Apply this Microsoft Security Update CD instead. If you need USB flash stick access then install Nusb 3.3 as well. Don't use the newer Nusb 3.6 because that version messes with Win98 system files.
My retro builds
Reply 4 of 11, by Virtua
thank you for the help! will try everything suggested, but reading through the link you provided i see that you've personally experienced almost identical issues to me, including agp texture acceleration being disabled under dxdiag. that was something i noticed the other day but slipped my mind until i saw your post
Reply 5 of 11, by AlexZ
There is another thread related to this issue - Not Another Ultimate Windows 98 Build
My MSI K8T Neo V has the same problem in Windows 98. Fortunately I never intended it being used as a Windows 98 machine. Solving this issue will need someone to fix VIA AGP driver to initialize correctly. Most likely it completely fails to initialize and AGP ends up functioning as a faster PCI.
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Turion 64 ML-37@2.2Ghz,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2ZS
Phenom II X4 955,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,32GB,GeForce GTX 980 Ti
Reply 6 of 11, by Virtua
i flashed the board's bios to the absolute earliest and it worked... somewhat. performance is definitely better in all games but still not as great as i expected. max payne still has performance issues even at 800 x 600 with anti-aliasing disabled. agp texture acceleration under dxdiag is now enabled but i still can't get agp fast write to work, though i can't imagine that would make a huge difference. i downloaded every bios release from the official site so i don't mind trying different versions but to avoid this headache altogether i may try a different board
Reply 7 of 11, by Shader_BiH
Virtua wrote on 2022-12-24, 20:02:
I suppose these issues occur only in Windows 98? I just got an MaxData PC with the same board... K8V-MX/S, but I can't find any BIOS files for it anywhere, where did you manage to find them?
Reply 8 of 11, by shevalier
Shader_BiH wrote on 2025-12-12, 16:46:
Officially, this motherboard is called Fujitsu Siemens Computers D1711 and should be installed in Scenico n (or p) 320.
https://webdownloads4.ts.fujitsu.com/download … _10_1081096.PDF
And Fujitsu didn't really release BIOS updates that often, especially if it didn't think there were any stability issues.
I would recommend creating a separate thread.
Upload your BIOS.
Other (happy) owners (if there are any) will share their versions of the file.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 9 of 11, by Shader_BiH
shevalier wrote on 2025-12-12, 18:18:
Officially, this motherboard is called Fujitsu Siemens Computers D1711 and should be installed in Scenico n (or p) 320. https:// […]
Upload your BIOS.
Thank you for the info shevalier. 😀 I was just trying to determine in what models was that board installed... even AI was confused with that. They seem to be SFF models of bigger SCENIC series with "less advanced" chipset. I also have a 1.06 revision board, but I plan to run XP SP1 on that machine, not Win 98, so maybe I won't even need to change it. For some reason Fujitsu Siemens global support site stoped providing these, or at least I can't find them. There are some microcode updates, but that's something else... I think... Nevertheless I'd like to have the files in my archive just in case I decide for different config later on. I will make a new thread once I set it up. Thanks again!
Reply 10 of 11, by NeoG_
Max Payne also has an issue where movement is jerky when the framerate gets too high, see if forcing vsync helps
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
Reply 11 of 11, by Ydee
IIRC, some issues with ATI Radeon cards and VIA chipsets were solved by forcing AGP 4x in BIOS setup.
