DaveDDS wrote on 2025-12-09, 04:05:
... My usual approach ... the original ImageDisk system used a 37-Pin 'D' connector ...
Ok, I happened to come across these this morning (while looking for something else of course), and thought it might be a good idea to post them in case anyone wants to better understand which I did to interface to many different floppy drives and types:
On the left is a cable I made up to go inside a system case, and make the changable drive easily accessable via a connector on the back of the system:
You can see a mainboard floppy cable connector at the top, near the middle are 3.5" and 5.25" drive connectors with "twists" around them to make them drive A: and a the bottom a card slot cover with a 37-pin 'D' connector.
Top center is the external cable, with a 'D' connector to fit the one in the system, and a 5.25" floppy connector at the other end (I used 5.25" because thats the most common in vintage systems).
Below that are several adapters I used for various drives:
5.25" -> 3.5"
5.25" -> 8"
5.25 power to 3.5 power (I only brought out one 5.25" extended power cable)
I didn't show the 8" power setup, originally it was a seperate supply as 8" drives need 24v and have a unique connector, but later it was just an external (isolated) 12v supply with a switch to put it in series with the PC 12v.
My power "adapter" which I used for all drives, also had a switch so I could shut off power to the drives completely while changing them. If anyone wants I can post a pic. of it and details on how it's wired.
-- On the right is a cable I made up for a "modern" system which only implemented selects for 1 (A:) floppy driver (who would ever want two floppy drives right!)
You can see at the mainboard end, an add-in reversable small "flying" connector which let me easily swap select and motor-ON between A: (the one that worked) and B: (unimplemented) - this let me make either drive connector A:
Note that I didn't move the "twists" to the center in this case, because I could already make either end drive A:
And... I didn't make this accessable from outside - this was a system I didn't use that much for ImageDisk, and it had an easily removable side cover, so I would just pull off the cover, switch A: to the end of the cable, and attach whatever drive I wanted to use.
https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChw can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small filetransfer(w/o netSW)via Lan/Lpt/Com
