First post, by ltning
- Member
Hola,
I have the this OPTi LB ET4000 (https://theretroweb.com/expansioncards/s/unkn … wn-et4000ax-olb) and recently got it to work after a lot of fiddling with the RAM (the connections are flakey, despite repeated re-seating). It is quite fast - got to >80 on 3dbench and ~1750 doom realticks (dosbench package) when running at 42.something bus speed and a Cyrix 4x CPU.
However, it has a few problems: No VESA at all in the BIOS (duh), and Open Cubic Player has trouble with all its text modes - the font is repeated 1.5x vertically for each line.
I tried today to replace the VGA BIOS with a slightly newer one, and while it solved the font problems, it resulted in only 256KB video RAM being detected. With 256KB there isn't much of graphics that will work :D
Anyone got a suggestions?
Wbr
/Eirik
The Floppy Museum - on a floppy, on a 286: http://floppy.museum
286-24/4MB/ET4kW32/GUS+SBPro2
386DX-40/20MB/CL5434 ISA/GUSExtreme
486BL-100/32MB/ET4kW32p VLB/GUSPnP/AWELegacy
~ love over gold ~
