TexElec Quad-Flop (FDC) and Windows 95
Reply 100 of 123, by wierd_w
Timings seems more likely.
mr bios wants to run more tightly. Try increasing the ram access waitstates a little with caching on.
Or, changing the cache mode, if it is set to write thru, to write back.
Reply 102 of 123, by Vipersan
Not really buddy..unless timing adjustments are buried deep and I haven't discovered them yet..
There are 14 pages in the bios ...I'll post them up for you to look at..
Reply 103 of 123, by Vipersan
Reply 104 of 123, by Vipersan
..last 4
Reply 105 of 123, by weedeewee
Vipersan wrote on 2025-12-15, 16:36:
PC150012 😀
side note, which I'm unsure if it's sorta bypassed by using a amd k6/2, the 430TX chipset only caches up to 64M of memory.
Anything higher will suffer some slowdown.
anyway... play around with the first three settings if you feel like it, yes, even the EDO/FPM timing.
I don't know if they might have an effect on the SDRAM you seem to be using.
Do not ask Why !
Reply 106 of 123, by Vipersan
weedeewee wrote on 2025-12-15, 18:33:
PC150012 :-) […]
PC150012 😀
At this point I have nothing to lose by trying...
No wait state tweaking...and unsure if the fpm edo setting would be relevant...but hey..It took me this long and a lot of waiting..just to discover disabling the cpu cache gets results.
Is it possible or even likely that this industrial setting mrbios was never written or modified to be used with K6-III.
who knows..
certainly not me
Reply 107 of 123, by weedeewee
Vipersan wrote on 2025-12-15, 19:28:
At this point I have nothing to lose by trying... No wait state tweaking...and unsure if the fpm edo setting would be relevant.. […]
PC150012 :-) […]
PC150012 😀
who knows..
certainly not me
K6-III ? mmh I only see it reporting a K6/200. no idea though.
MR Bios's tend to have just the settings that one needs, but it tends to support/drive the hardware better from the start, like the 4 floppy drive support.
This in contrast to the AMI bios's where with the use of the correct program, like the old amisetup? (i think that's what it was called), you could change so many settings, some would work, others wouldn't do a thing.
What CPU are you actually running on that board?
also, try running the speedsys benchmark. the graph bottom right should tell you something about memory/cache throughput. Compare them with cache enabled and disabled.
Do not ask Why !
Reply 108 of 123, by Vipersan
You have me wondering now....
I have 2 of these mobos...one is in a desktop running win98se with my rare graphics card ...a voodoo 5500 pci.
I thought they both were fitted with the same cpu...but it may well be I am wrong..
I'll find out for sure..
cheers
checkit was less than helpful ..it claims it to be an 80486
doh!
Reply 109 of 123, by Vipersan
Looks like I had this cpu mixed up with another one..
It is indeed a lowly K6 @200m ...cpuZ confirmed it.
A K6-III would be overkill for this system anyhoo.
Had to pop the original bios back in in order to run win98 and cpuz..so will have a play around with those memory settings tomorrow.
Reply 110 of 123, by bbuchholtz
My CPU is an AMD K6-III+ and I don't need to disable internal cache.
Here's a few pictures of my BIOS settings. Let me know if you need anything else.
Any possibility you're mixing high and low density memory? I always try to ensure that my memory is as matched as possible. As a test, can you try removing the high density DIMM (has only 8 or 9 chips)?
Another test... Try using an add-in IDE/SATA/SCSI card and install DOS on that. Just in case the MRBIOS isn't playing nice with the onboard IDE.
-Brian
Reply 111 of 123, by Vipersan
Now I remember why I removed my K6-III..
I found it and wanted to try it.
but 3 of the pins at the extreme edge where the corner is clear (location corner) are black-ish instead of gold..
In a previous life this cpu had been exposed to something corrosive.. and so far I've found no way to clean those pins.
The CPU works just fine until placed under pressure from a heat sink..
since other chips work fine I'm not blaming the socket atm...but it looks like the gold plating on those pins has gone.
I wonder if acetic acid (vinegar) would help ?
Reply 112 of 123, by Vipersan
That appears to have worked...my K6-III is currently working with a block heat sink and fan.
small paintbrush > vinegar > Iso alcohol.
But it isn't a K6-III+
This afternoon I'll try it with mrbios.
There are variations involving cpu cache ...so _may_ be relevant.
Reply 113 of 123, by Vipersan
Sadly still fails with mrbios
Time to accept defeat ?
Cant get into dos on the 2gb CF card ..unless I disable CPU cache..
another oddity I noticed
..tried to run win 98se all floppy drives disabled.
MrBios recognises The Transcend 64 gb CF ...but only at 8gb ?
Needless to say it doesn't boot 98
Another thing I noticed..looking at Brians bios screens....external cache is recognised and listed (image ending 148)
Mr bios in my case never does...even though as you can see from my cpuz picture..external L2 cache does exist.
Looking at what passes for my mobo manual...should external cache be larger ??
Reply 114 of 123, by bbuchholtz
I recently found this link:
https://docs.google.com/spreadsheets/d/1vtPso … yPGXZOp8ZeyuFf8
This could be useful for research and troubleshooting. You'll want to be in the "Intel" section.
You can use this in one of two ways. This is a good way to try finding another BIOS that may be compatible with your board. I try to match chipset, clockgen and I/O chips. I've had moderate success with this approach.
Alternatively, this could be a useful guide for acquiring a different motherboard.
-Brian
Reply 115 of 123, by Vipersan
bbuchholtz wrote on 2025-12-16, 15:05:
I recently found this link: https://docs.google.com/spreadsheets/d/1vtPso … yPGXZOp8ZeyuFf8 […]
-Brian
Cheers for the link Brian...some more 'light reading' 🤣
Reply 116 of 123, by weedeewee
FYI
vipersan mrbios version & date is 3.45 09/08/98
AMD K6-III release date... 02/99
bbuchholtz mrbios version & date is 3.46 04/22/99
Do not ask Why !
Reply 117 of 123, by Vipersan
Thanx for that Weedeewee...
I have spare chips so I'll give any relevant version a try.
As long as I have the ziff socket in the pc ..swapping bios isn't much of an issue.
Reply 118 of 123, by Vipersan
Interesting that it is claimed that a very similar mobo to mine is supported by mrbios..
mine being a biostar MB-8500TTD
I wonder what the difference would be to a Biostar MB-8500TAC ? (Triton VX)
..and a MB-8500 TUC rev2 (Triton HX)
...also In that list is a BiosStar MB-8500TEC Ver .2 and version .3 (Triton VX)
I can't find the TTD varient specifically listed .
So ..If I want to stick with Biostar...
MB-8500 TEC TAC TUC and TVD are specifically mentioned in that list as supported by mrbios.
I guess I just have to keep the list handy and keep scouring fleabay for something to pop up at an affordable price.
That said...there are many non biostar mobos on the list.
Reply 119 of 123, by bbuchholtz
While the model number is similar, they have different chipsets. Your board's chipset is 430TX.
The BIOS is had suggested to you was for a different make and model. But, it had the same chipset, clockgen and I/O chips.
-Brian
