Torn between using these 2 Systems
First post, by C0deHunter
Hello all,
I have built two systems:
System 1
MS-DOS 7.1
Win98SE
Windows 2000 Professional
Albatron PX865PEL-800
Pentium 4 (2800MHz)
Northwood (82865G)
512MB DDR
GeForce FX5200
Sound Blaster Audigy 2 ZS (up to EAX 4.0 support)
and
System 2
XP
Vista
Windows 7 Ultimate x64
ASRock H77M (Ivy Bridge)
Core i5 3470s (2900MHz)
8GB DDR3-1600
GeForce GTX 980Ti (the last good GPU that has crisp support for CRTs!)
Samsung 17" SyncMaster MB1763
Sound Blaster X-Fi Titanium (EMU20K2) (up to EAX 5.0 support, however very *few* games even support 5.0)(also supposedly it is backward compatible with EAX 1, 2, 3)
Both systems are connected to the same CRT monitor, keyboard and mouse (and don't have a KVM handy at the moment)
My goal is to play the following Win9X-Win2K-XP era games, but since it is a long list, I have attached a screen capture of it instead.
Also there is another screen shot of the Windows 7 era games list (the so called 'Games for Windows' unified games, and some newer games that require Windows 7)
Questions:
1) I am seriously torn and need to get your opinion on which system to use?
2) For Windows 7, it is obvious that I am going to use for said games
3) But my real concern is choosing either the Win9X/2K or XP systems, as I hate using a KVM to constantly switch between System 1 (Win9X-2K) and System 2 (XP-Win7)
4) As you can see I have done an exhaustive research and made a note of the EAX and DirectX (or OpenGL) version of the said games as well. And my goal is to enjoy the EAX games specifically, because back in the day, I never really bothered with noticing or utilizing them, even though I am sure that have own an Audigy 2ZS)
ISSUES:
When I played the original Splinter Cell on Win7 (I know, old game) the Audio radio button in the settings for EAX was grayed out, but when I played on XP, I could toggle EAX on and off. (which I am sure can be done on my Win98/2K System 1)
I really appreciate your insights and opinions.
PIII-800E | Abit BH-6 | GeForce FX 5200 | 64MB SD-RAM PC100 | AWE64 Gold | Sound Canvas 55 MKII | SoftMPU | 16GBGB Transcend CF as C:\ and 64GB Transcend CF D:\ (Games) | OS: MS-DOS 7.1-Win98SE-WinME-Win2K Pro (multi-OS menu Using System Commander 2K)
Reply 1 of 22, by RetroLizard
Do any of those specifically require Windows 7 to play? If not, you're probably better sticking with XP for System 2.
Reply 2 of 22, by C0deHunter
RetroLizard wrote on 2025-12-15, 19:03:
Only the ones that are listed on the attached 'Win7 Games' screenshot image.
In my opinion, a few select EAX 5.0 games does warrant me to use Windows 7 and its X-Fi Titanium, whereas I get up to EAX 4.0 support with Audigy 2ZS inside my Win98/2K (System 2) machine.
Reply 3 of 22, by RetroLizard
Unreal Tournament 2004, I know isn't a Windows 7 game. Neither is the original Crysis. Or Half-Life 2.
I'd see how many of them are playable on Windows XP first before deciding.
Reply 4 of 22, by C0deHunter
I have applied and installed the Windows 2000 Extended Kernel 3.0e
(from https://retrosystemsrevival.blogspot.com)
https://retrosystemsrevival.blogspot.com/2020 … kernel-30e.html
Which has essentially turned my Win2K machine into an XP one.
Reply 5 of 22, by Ozzuneoj
C0deHunter wrote on 2025-12-15, 18:19:
Hello all, I have built two systems: […]
Hello all,
System 1
MS-DOS 7.1
Win98SE
8GB DDR3-1600
and
System 2
XP
Vista
Pentium 4 (2800MHz)
Northwood (82865G)
512MB DDR
GeForce FX5200
Questions:
ISSUES:
I'm guessing you've got the operating systems swapped in your lists of specs...?
If not, they should be. I don't imagine a 980 Ti is too useful in Windows 98SE, and likewise an FX 5200 in Windows 7. Also, the Audigy 2ZS should be in the slower Win9x system and the X-Fi in the Windows XP\7 system.
Reply 6 of 22, by C0deHunter
My bad! I just corrected my mistake! Yes, that is correct: Audigy 2 in Win98, and X-Fi in XP/7 machine.
Reply 7 of 22, by Joseph_Joestar
That Pentium 4 system with a GeForce FX 5200 is too weak to comfortably play EAX 5.0 games. For reference, we're talking about titles such as Quake 4, Prey, Colin McRae Dirt, Mass Effect and so on. Take a look at the EAX games list on the Vogons Wiki to see which games support each EAX version.
As for EAX on Vista and up, only games which access EAX via OpenAL will work there natively. For everything else, you need a wrapper such as Creative's ALchemy.
My retro builds
Reply 8 of 22, by C0deHunter
Wow! The almighty Joseph_Joestar has blessed me with his insight! I am humbled!
OK, yes that is the reason that I *occasionally* will be playing Windows 7 era games on the System 2 (Win7)
I should rephrase my request:
Should I use the XP OS (on the same machine as Win7, which conveniently gives me the option to also play Windows 7 games using my multi-OS menu at system startup), or switch to Win98/Win2K machine?
Reply 9 of 22, by RetroLizard
I think skip doing multiboot (XP and 7 have a big overlap in compatible games, after all) and just choose 7 for system 2.
98SE for System 1; 2000 has problems with some games.
Reply 10 of 22, by Ozzuneoj
C0deHunter wrote on 2025-12-15, 19:32:
Joseph_Joestar wrote on 2025-12-15, 19:48:
C0deHunter wrote on 2025-12-15, 20:10:
Wow! The almighty Joseph_Joestar has blessed me with his insight! I am humbled! […]
The issue is that the list still shows the sound cards on the wrong systems... but Codehunter already restated which systems they are going in as quoted here. In other words, I don't know why you guys are arguing about an obvious typo. 😅
EDIT: I see it's been fixed now. Crisis averted. You're both welcome. 😆
Reply 11 of 22, by C0deHunter
What is this 'OpenAL' or a 'EAX Unified' drivers and where would I find them for certain games, on their websites?
Reply 12 of 22, by BinaryDemon
So buy the KVM and keep both. Seems like the only solution without massive compromise.
Reply 13 of 22, by Joseph_Joestar
C0deHunter wrote on 2025-12-16, 08:46:
The latest EAX Unified standalone installer can be found here. And Creative's last official version of OpenAL is here.
Back in the day, games which used these shipped them on the disc, usually as just DLL files.
My retro builds
Reply 14 of 22, by C0deHunter
Joseph_Joestar wrote on 2025-12-16, 08:59:
Many thanks! I just grab them and install them then?
Reply 15 of 22, by Joseph_Joestar
C0deHunter wrote on 2025-12-16, 10:53:
Yes.
Just be sure to install EAX Unified and OpenAL after your sound card drivers, and not the other way around. The reason being, some driver CDs contain older versions of these files.
My retro builds
Reply 16 of 22, by C0deHunter
Many thanks for your kind inputs:
1) What is the real benefit of keeping the X-Fi Titanium (EMU20K2) in my XP machine, and not replacing it with Audigy 2ZS (EMU10K2)? Would EAX 5.0 support would be that important to warrant not using ZS 2 on my XP machine?
2) Also what does Win9X / Win2K OS offer that Windows XP OS does not? It seems that XP was THE replacement (at least its 32bit variant) for anything from 1998 up until 2009ish?
3) Would I be better off to keep the XP/Win7 machine only, and simply install Win9X/Win2K era games on XP, and all other 'newer' 7 era games ('Games for Windows, Live, etc.) on Windows 7?
4) If I keep both systems, how can I install Creative Alchemy on Windows 7 machine? Is there is separate installer for Alchemy?
Many thanks I really appreciate it!
Reply 17 of 22, by RetroLizard
It really depends on if you want them to be playable out of the box or if you want to spend extra time with applying patches and fixes just to get the games to work.
Reply 18 of 22, by C0deHunter
Since this thread was originally about the EAX game under various OS, and since I just found out about the amazing EAX Appreciation Thread:
EAX appreciation thread
I have couple of extra questions:
I am sure for my XP setup, I have installed DanielK's Audigy driver pack, therefore I am missing some of the awesome Creative Labs applications that come on the Windows XP Drivers. Well, I decided to download the Sound Blaster X-Fi PCIe WinXP/Vista posted on VOGON for my X-Fi Titanium (EMU20K2).
Is this the correct drivers?
Joseph_Joestar mentions in this thread
Re: EAX appreciation thread
"My rule of thumb is, if a game is made before 2001, play it under Win9x. For anything newer than that, use WinXP."
Which clearly makes me to use my System 1 for 2001 games and under, and System 2 for XP Games (2003 and newer)
The question is what about between 2001 and 2003 games?
Reply 19 of 22, by Joseph_Joestar
C0deHunter wrote on 2025-12-20, 08:18:
Check my guide for setting up the X-Fi Titanium under WinXP. As mentioned there, it's best to use an older driver version, since the latest ones have issues with OpenAL games.
Those should work fine on the X-Fi.
My retro builds
