First post, by LeFlash
- Member
Hello,
i can't get the gigabit-interface get working on my E3000.
prtdiag lists is, dmesg lists it, but ifconfig fails.
Some sun experts here?
Bus FreqBrd Type MHz Slot Name Model--- ---- ---- ---------- ---------------------------- --------------------1 SBus 25 0 cgsix SUNW,501-23251 SBus 25 1 QLGC,isp/sd (block) QLGC,ISP1000U1 SBus 25 2 network SUNW,sbus-gem1 SBus 25 3 SUNW,hme1 SBus 25 3 SUNW,fas/sd (block)1 SBus 25 13 SUNW,socal/sf (scsi-3) 501-30603 PCI 33 On-Board SUNW,hme-pci108e,1001 SUNW,cheerio3 PCI 33 On-Board SUNW,isptwo/sd (block) QLGC,ISP1040B3 PCI 33 pci-slot 1 ethernet-pci1186,4b01Mar 7 06:22:21 e3000 ge: [ID 580805 kern.info] SUNW,sbus-gem1: SUNW,sbus-gem (Rev Id = 0) FoundMar 7 06:22:21 e3000 ge: [ID 580805 kern.info] SUNW,sbus-gem1: Local Ethernet address = 8:0:20:c5:1b:cbMar 7 06:22:21 e3000 sbus: [ID 349649 kern.info] ge1 at sbus0: SBus0 slot 0x2 offset 0x100000 and slot 0x2 offset 0x200000 SBus level 4 sparc9 ipl 7Mar 7 06:22:21 e3000 genunix: [ID 936769 kern.info] ge1 is /sbus@2,0/network@2,100000root@e3000#add_drv geDriver (ge) is already installed.root@e3000#ifconfig ge1ifconfig: status: SIOCGLIFFLAGS: ge1: no such interfaceroot@e3000#ifconfig ge0ifconfig: status: SIOCGLIFFLAGS: ge0: no such interface
