Reply 560 of 606, by SoftCat
Could you tell me which emulator is best for testing EGA scrolling in 0Dh and 0Eh modes? I want to do this for each of four video RAM sizes: 64 KB, 128 KB, 192 KB, and 256 KB.
UniPCemu supports EGA/VGA as well as it's possible (to the cycle rendering level, and even supports SVGA to that level and more features than any other known emulators on the Tseng chipsets), more accurate than any other emulators.
Then again, right now, current commits have some unknown CPU issues (Windows 3.x not booting anymore in 32-bit mode), but 16-bit mode probably still works (on 3.1 and lower). MS-DOS also seems to run fine still (even with Virtual memory managers and EMS managers like EMM386).
No clue yet as what's causing WFW 3.11 to crash during boot. All I see is a single page fault in protected mode CPL 0 before the crash happens, which is on some EIP address (being not present in any PTE/PDE combination). That shouldn't happen from what I know? So right now, at least 9x/3.x in 32-bit mode doesn't boot (16-bit mode still boots, like 3.1/3.0 and MS-DOS itself ofc).
I get through the installation wizard without issues, but when booting the OS, I see a single page fault on CPL 0 that crashes the sub-OS (sub because MS-DOS is effectively the main OS) back to text mode and hanging.
Edit: Hmm, odd. Windows 3.1 fails in 386 enhanced mode as well (like 3.11), while protected mode boots to the desktop and then doesn't respond to mouse/keyboard.
Edit: OK. Tried again without EMM386 and using /s switch. It runs fine now somehow.
Edit: And 3.0 also crashes with /3 parameter. Interesting.
Edit: So does 3.0 in standard mode (triple fault causing a reboot). Odd.
Edit: Real mode does boot properly though. Inputting any number in calc.exe gives me a defeault inputted value of "-0." (without quotes). Inputting any number gives me a "Result is too large for". Paintbrush seems to run fine.
UniPCemu Git repository
Is it correct to simply assume that the EGA has 256 KB of video RAM and not worry about cases with a smaller volume?
SoftCat wrote on 2025-12-14, 22:58:Is it correct to simply assume that the EGA has 256 KB of video RAM and not worry about cases with a smaller volume?
No, it's not. There were EGA cards with just 64K in the wild. I guess 128K and 192K (two or three banks of 64K each) are quite rare. I've seen a YouTube video about someone playing with retro EGA cards, and one of the cards failed to display a couple of games correctly because it only had 64K of RAM installed.
Furthermore, if you target keen-like infinite scrolling, I think there is a control bit that makes the video RAM wrap around at 64K instead of 256K, but you can't have infinite scroll while you use 128K or 192K. If there is a 64K wrap-around mode you can use that mode on 128K or 192K cards as well and just use them like 64K cards.
mkarcher wrote on 2025-12-14, 23:03:No, it's not. There were EGA cards with just 64K in the wild. I guess 128K and 192K (two or three banks of 64K each) are quite rare. I've seen a YouTube video about someone playing with retro EGA cards, and one of the cards failed to display a couple of games correctly because it only had 64K of RAM installed.
Got it, thank you very much!
If the card has 64 KB and I'm using mode 0xE, the video buffer will occupy addresses 0xA000:0x0000 -- 0xA000:0x3E7F. What happens if I write starting at address 0xA000:0x4000?
SoftCat wrote on 2025-12-14, 23:17:Got it, thank you very much!
I'm talking about the original EGA design that used 4 memory banks of 16K x 32 (using 8 chips of 16K x 4 per bank). In that design, a write to A000:4000 will be sent to the second bank, and as there are no chips in that bank, the write will end up ignored. The newer EGA clones having a single bank of 64K x 32 always have 256KB of RAM, so this question does not apply to them.
Furthermore, if you are exploring 64K EGA generally, you should be aware that mode 0F/10h are degraded to 4-color modes using odd/even mode. You only use bits 0 and 2 of the color numbers. You need to enable both planes 0 and 1 to write bit 0 and both planes 2 and 3 to write bit 2 of the color number. Even ISA bus addresses end up in planes 0 and 2, while odd ISA bus addresses end up in planes 1 and 3 (the other planes are automatically masked in odd/even mode writes, even if they are enabled in the map mask register). The ISA adresses 0 to 3FFF map to the even locations in EGA RAM, and thanks to a special control bit set in those modes, ISA address bit 14 is mapped to EGA address bit 0, so starting at ISA address 4000, you will access the odd locations of EGA RAM. The CRTC is accessing the RAM in word mode with 16 pixels per 32-bit unit and also address wrap at 4000 to match the ISA interface.
SoftCat wrote on 2025-12-14, 23:17:mkarcher wrote on 2025-12-14, 23:03:No, it's not. There were EGA cards with just 64K in the wild. I guess 128K and 192K (two or three banks of 64K each) are quite rare. I've seen a YouTube video about someone playing with retro EGA cards, and one of the cards failed to display a couple of games correctly because it only had 64K of RAM installed.
From what I know about the EGA/VGA chipset, first 64K wrapping is applied (when the bit is enabled only), then the resulting address is directly addressed on the VRAM chips. When it's past the final address of the installed VRAM, the memory chip simply floats the bus on reads and doesn't respond on writes. So reads result in FFh being read and writes are effectively ignored. The memory itself is chains like plane 0 byte 0, plane 1 byte 0, plane 2 byte 0, plane 3 byte 0, plane 0 byte 1 etc. Basically modulo 4 is the plane and every 4 bytes a next byte on the four parallel planes.
So if only 64KB of memory is installed, that's only on addresses 0-3FFFh, 4000+ floating the bus (or doing nothing on writes). If the wrapping is applied, the 64KB of memory (0-3FFFh in 32-bit memory) will repeat accross the 256KB memory address space.
mkarcher wrote on 2025-12-15, 06:26:I'm talking about the original EGA design that used 4 memory banks of 16K x 32 (using 8 chips of 16K x 4 per bank). In that design, a write to A000:4000 will be sent to the second bank, and as there are no chips in that bank, the write will end up ignored. The newer EGA clones having a single bank of 64K x 32 always have 256KB of RAM, so this question does not apply to them.
Thank you very much for your detailed answer!
As far as I know, mode 0Fh is 4-color in any case. It's designed for use with a monochrome monitor.
If, with 64 KB of video RAM on an EGA graphics card, the video buffer contents were repeated four times in segment 0A000h for mode 0Eh, then infinite scrolling would work exactly the same as with 256 KB of video RAM.
And on SVGA, infinite scrolling would simply loop at 512 KB or 1024 KB. It's all rather complicated.
superfury wrote on 2025-12-15, 12:57:From what I know about the EGA/VGA chipset, first 64K wrapping is applied (when the bit is enabled only), then the resulting address is directly addressed on the VRAM chips. When it's past the final address of the installed VRAM, the memory chip simply floats the bus on reads and doesn't respond on writes. So reads result in FFh being read and writes are effectively ignored. The memory itself is chains like plane 0 byte 0, plane 1 byte 0, plane 2 byte 0, plane 3 byte 0, plane 0 byte 1 etc. Basically modulo 4 is the plane and every 4 bytes a next byte on the four parallel planes.
Thank you very much for the clarification!
Can you tell me how to loop scrolling on an EGA video card with 64 KB of video RAM?
Is it possible to loop scrolling on an SVGA video card with a smaller amount of video RAM?
SoftCat wrote on 2025-12-16, 21:17:Can you tell me how to loop scrolling on an EGA video card with 64 KB of video RAM?
While I previously claimed that the bit likely exists, I'm actually unsure whether you can have the CRTC address counter wrap around at 16K (the CRTC address counter counts 32-bit units of video RAM, so 16K in that counter is 64KB of RAM). I will check documentation and report back what I find.
SVGA cards typically have a "VGA compatibility" bit (often as "extensions enable" bit). If VGA compatibility is on, that is extensions are disabled, wrapping is supposed to happen at 256KB (64K of the CRTC address counter). Not all VGA cards implement this aspect of VGA compatibility, though, and that's why Commander Keen 4 and later have the "SVGA compatibility mode", that adds some overhead, but avoids relying on the 256KB wraparound. A very notable SVGA chipset that does not implement the 256KB wraparound is the Tseng Labs ET4000 series.
mkarcher wrote on 2025-12-16, 22:53:While I previously claimed that the bit likely exists, I'm actually unsure whether you can have the CRTC address counter wrap around at 16K (the CRTC address counter counts 32-bit units of video RAM, so 16K in that counter is 64KB of RAM). I will check documentation and report back what I find.
Great, thanks!
It would be nice to have a 64 KB (16 KB x 32 bit) loop on VGA and SVGA. This would create a unified scrolling method for EGA and higher.
I hate to attempt to derail what is an interesting conversation but I might kindly ask this thread remain on topic for MartyPC?
MartyPC: A cycle-accurate IBM PC/XT emulator | https://github.com/dbalsom/martypc
GloriousCow wrote on 2025-12-18, 18:20:I hate to attempt to derail what is an interesting conversation but I might kindly ask this thread remain on topic for MartyPC?
Okay. If you don't need this information for more accurate EGA emulation, I won't write about it here anymore.
SoftCat wrote on 2025-12-18, 19:11:GloriousCow wrote on 2025-12-18, 18:20:I hate to attempt to derail what is an interesting conversation but I might kindly ask this thread remain on topic for MartyPC?
This is honestly pretty cool information and deserving of a topic of its own. Wasn't there already one about the intricacies of EGA?
The thing is, it doesn't matter if i need it or not. everyone can use it. the technical discussions here on VOGONS are gifts to posterity. I had a lot of assistance from old VOGONs threads in building MartyPC. but burying a technical discussion about EGA in a "MartyPC" thread just makes it harder to find. VOGONS is an absolute treasure mine of good information - like this discussion, but it is best if it is searchable and indexable, and a thread with an appropriately titled topic is the best way to accomplish that.
the fact that I get notifications every time this thread is responded to is the other thing. I want to be able to respond if people have questions about MartyPC. On the other hand, I'm not a moderator and I can't tell you what not to do.
it's not that i'm not interested in more accurate video card emulation. i recently made a digital logic simulation of the CGA card, partly to improve MartyPC.
https://github.com/dbalsom/cga_sim
Slightly related to MartyPC itself: did you encounter 'active' display (or VRAM aperture) issues on EGA in (MDA) monochrome mode? When running with the Generic Super PC/Turbo XT BIOS and XT-IDE BIOS I only get proper display from the XT-IDE outputs, while all others (the BIOS and MS-DOS 6.22 w/ boot menu) don't put any text on the screen until I execute the "mode mono" command (executed blindly by observing the hard disk for booting, F5 to skip the boot menu (or enter(CR) in my case, as it's first option is a generic minimal setup on my testing disk images).
The switches seem to be read reversed from (S)VGA in the EGA BIOS. So the bit values are:
- 0x4: Monochrome monitor (EGA)
- 0x2: Monochrome monitor (VGA)
- 0x6: Enhanced EGA 5154 monitor or color (S)VGA monitor
- 0x7: 5154 in normal mode
- 0x8: 5153 CGA monitor
That EGA monochrome monitor case seems to be the only one going wrong?
Or does it require something special for monochrome EGA (MDA?) monitors?
superfury wrote on 2025-12-18, 20:56:Slightly related to MartyPC itself: did you encounter 'active' display (or VRAM aperture) issues on EGA in (MDA) monochrome mode […]
That EGA monochrome monitor case seems to be the only one going wrong?Or does it require something special for monochrome EGA (MDA?) monitors?
I'm afraid I never really implemented monochrome support for the EGA, because dealing with the 9-dot character timings annoyed me at the time as I had (what i thought to be) a nice optimized 64-bit, 8-pixel-at-time drawing pipeline. I did eventually figure that out for VGA but never back ported it to EGA.
Here's what I have for DIP switches, for what its worth. These are the physical switch states. They read inverted as closing the switch pulls the circuit to ground.
pub const EGA_DIP_SWITCH_EGA: u8 = 0b1001; // EGA 'enhanced color'
pub const EGA_DIP_SWITCH_MDA: u8 = 0b1011; // MDA emulation
pub const EGA_DIP_SWITCH_NORMAL: u8 = 0b1000; // EGA 'normal color'
pub const EGA_DIP_SWITCH_CGA: u8 = 0b0111; // EGA on CGA monitor
GloriousCow wrote on 2025-12-18, 20:21:The thing is, it doesn't matter if i need it or not. everyone can use it. the technical discussions here on VOGONS are gifts t […]
I get it.
Why not use, for example, a cute young cow like this as your avatar? I think it would be better than a dead skull.
SoftCat wrote on 2025-12-19, 00:35:I get it.
because i am neither young nor cute 😀
GloriousCow wrote on 2025-12-18, 23:04:I'm afraid I never really implemented monochrome support for the EGA, because dealing with the 9-dot character timings annoyed m […]
9-dot characters require a 72-bit processor.
