First post, by afshin6760
- Newbie
Hi ,
I’m planning a setup where I have a modern GPU (e.g., RTX 5050) for gaming, but want to use a CRT monitor via an older secondary GPU (e.g., Radeon R56) because DP→VGA adapters don’t give proper refresh rates above 60Hz.
I’m wondering:
1. Is this setup actually feasible?
2. Could it cause any bottleneck or conflict between the GPUs?
3. Does the modern GPU need to have a monitor connected for mirroring/output, or can the CRT run entirely on the old GPU independently?
Thanks for any insights!
Update: Success with RTX 4060 + i3-13100 + H610M-K (VGA Output)
I wanted to confirm that you can use a modern dedicated GPU (like my RTX 4060) while keeping your monitor connected to the motherboard's VGA port. This is perfect for those using CRT monitors.
How I did it:
Plugged the CRT monitor directly into the motherboard's VGA port (using the i3-13100's iGPU).
In Windows 11, I went to Settings > System > Display > Graphics.
Under "Custom options for apps," I selected my games and set them to "High Performance" (NVIDIA GeForce RTX 4060).
Result: The games render using the RTX 4060's power, but the frames are passed through the iGPU to the VGA output. It works flawlessly with no noticeable lag, And before this, I had selected the igpu multi monitor and image output option in the bios and set its memory to 128mb.
🛑 Some DirectX games below 11 do not work with this method but do work using dgvoodoo.
🧩Things I know that might be useful to someone else:
1) 2 Nvidia cards together can probably cause problems
2) If the second card is AMD you can probably use VSR as well
3) 2-slot motherboards usually control the second GPU slot with a chip, not the CPU, so it could possibly cause a stator problem or something similar
4) The issue is not just the image. For example, my old laptop with a VGA port has a really blurry image, and my motherboard with a VGA one is much clearer.
