First post, by s.mouse
Hey all,
I always knew the 440BX is an excellent chipset however I’ve been curious to see just how much faster it was compared to SiS and VIA's initial offerings. I had some time so decided to try and find out. Results aren’t too surprising but some interesting things can be concluded from my small sample size of boards. A Pentium II 450Mhz was used for all benchmarks. I know there are later Via chipsets but I was curious to see how the first round a chipsets compared from 1998
Motherboards:
-Chaintech 6BTML representing Intels 440BX
-Superpower SP-6XS and Chaintech 6SSA2 representing SiS 5600
-Gigabyte GA-6VX representing VIAs Apollo pro
Video Cards:
-Asus V3800U Nvidia TNT2 Ultra,
-STB voodoo 3 2000 AGP,
-2 x STB black magic Voodoo 2 12mb
-Drivers: All benchmarks 800x600, Glide used for 3dfx benchmarks where available, Via 4.35 chipset, Sis v1.0 chipsets. Asus 6.31c V3800U for TNT2, Voodoo 3 4.12.01.0666 and Voodoo 2 FastVoodoo2 4.6, no sound card
Conclusions
-440BX has superior performance especially the AGP implementation.
-Using a 3dfx AGP card all chipset performance is arguably acceptable but drops off when using an Nvidia card especially with direct 3d for some reason
-The VIAs AGP implementation appears faster than the SIS chipset however the SIS PCI implementation seems to be faster so performed better than the VIA with voodoo 2’s.
-Motherboard implementation of chipset can make a huge difference, The 2 SiS boards benchmark discrepancy is huge. The Chaintech board is far slower and has far less options in bios to tweak. Speedsys memory bandwidth is also majorly lower. Unfortunately I only had time to benchmark voodoo 2's with the Chintech sis 5600 but from memory the AGP performance with a voodoo 3 was very similar to the voodoo 2 sli - abysmal
Interesting notes
-The Sis 5600 has the IDE controller integrated into the north bridge in contrast with the 440BX and Apollo pro being contained in the south bridge
-I’ve been using the SiS board with Voodoo 2’s for a couple of months now and found its been quite stable and performance using the pci voodoo 2’s is only marginally slower than the 440BX
-There is a slot 1 ALI chipset which is scarce and performance isn't well documented, wonder how it performs
The attachment Charts.jpg is no longer available
The attachment Data.jpg is no longer available
The attachment moboss.jpg is no longer available
The attachment GFX cardss.jpg is no longer available
