Reply 40 of 79, by danifunker
I tried doing a few things and didn't see any audio issues in windows 98 with any disc swaps recently. I think some recent code changes made it too fast for Windows 98 to see the disc change though, but either way-- can you try this build out when you can? Note you'll need to be logged into github to perform the download. This is a "dev" version.
https://github.com/danifunker/usbode-circle/a … uns/20016432101
Should be available in about 10 minutes. I'm heading to bed now. Thanks again for your help with troubleshooting and testing this. I actually had no idea that re-loading the same disc a few time could fix the issue, so that helped me in trying to get this thing working.
