First post, by theelf
- Oldbie
Hi, love NeoGeoCD emulator for DOS, the problem is only option NeoCD have some problems, first, not having a frameskip option kills playability on slower PCs, second many graphics problem, for example in World Heroes series, and last one, a fiex 44100hz for ADPCM that kills older PCs. Fixed Samurai Spirits RPG too, that have glitches in text and menus
I add 1 frameskip, then 30fps instead of 60fps, tested in pentium, 150 work great, still smoth scroll because no odd skip and perfectly playable, and add 40 and 50fps options too. I was playing in my pentium at 133mhz, with PCM at 11khz and 30fps is very playable
Removed the loading screen, since modern CDrom, HHD or even CD emulation like PicoGUS is too fast, and the screen was annoying, i replalce with just a fade to black
I recommend no vsync (because slowdown) and use a 320x240 120hz video mode, is possible to create with vbe software, first load scitech UniVBE Vesa 3 UniVBE 6.53 and 6.7 support for S3 Trio3D/2X cards
The modeline work in my screen for 320x240 120hz is this
device_video_modeline pc_mult60_320x240 12.576 320 328 376 392 240 235 246 272 -hsync -vsync # H 31440 [Hz], V 60 [Hz]
With 120hz no need to vsync and still smoth even at 30fps
Enjoy!!
