Possible defective PSU
First post, by Retro-o
Evening folks,
System:
Socket 7: AMD K2 266MHz
128Mb RAM
Graphics: S3 Virge DX/GX 4Mb RAM
Sound: AWE 64
O/S: Win98SE
Looking to pick your brains guys, my old WIN98 PC was running fine and now when I start it up the monitor remains on standby (no signal) and the CPU fan won't spin. PSU fan is spinning. I thought it may be a RAM issue, but I've tried swapping around all three RAM boards in different slots, one RAM only, then two RAM etc... but no joy. I don't think it's the RAM causing the issue. PC does beep on and off when there's no RAM present. I've tried clearing the CMOS and I've put a new battery in the motherboard which was reading 3.3V so all good there.
I've just checked the PSU with a volt meter. The connecter for the motherboard has twelve wires, six split between two connectors P8 & P9. P8 yellow wire reads 11.7V - good , the red reads 5V - good, but the orange reads 5V instead of 3.3V - not so good. I've been told this is most likely the cause and I need a new PSU - Just looking to pick your brains too see if you think that this is indeed the issue or are there any other things I could check / try first. I've attached some pics of my PSU.
Regards
Colin.
Reply 1 of 14, by RetroLizard
I'm not as experienced with power supplies like others might be, but I don't even see 3.3V listed on the power supply as one of the rails available.
Reply 2 of 14, by paradigital
RetroLizard wrote on 2025-12-20, 23:51:
Correct, AT doesn’t have a 3.3v typically. The orange wire is Power OK, which should be 5v.
Reply 3 of 14, by tehsiggi
Orange being 3.3V was not a thing until ATX came up. Your PSU is AT, meaning the orange wire is for power good (PG) which signals the mainboard that all voltage rails are within specification.
See: https://pinoutguide.com/Power/MotherboardPower_pinout.shtml
It will be 5V if PG is true, meaning all voltages are good.
From your measurements the PSU main rails appear to be fine. You can check the negative ones as well, but I don't feel like the PSU is at fault here.
AGP Card Real Power Consumption
AGP Power monitor - diagnostic hardware tool
Graphics card repair collection
Reply 4 of 14, by Retro-o
Thanks for all the help and information so far folks. Sounds then like the PSU is good. Does anyone have any ideas a s may be causing the non start up issues?
Reply 5 of 14, by RetroLizard
Can you show us pictures of the whole computer?
Reply 6 of 14, by paradigital
First steps for me would be check the motherboard for shorted voltage rails and visibly dead/suspect caps.
Reply 7 of 14, by shevalier
Retro-o wrote on 2025-12-20, 22:50:
System:
Socket 7:
As far as I know, Socket 7 motherboards did not have CPU fan control.
It seems very likely that the +12V is either disappearing somewhere on the board or decreasing significantly under load.
Check the PSU voltage with the board turned on.
The +12V should go to the CPU PWM controller. If it is not there, then the indirect sign will be the lack of CPU fan rotation.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 8 of 14, by kotel
So the mainboard powers on after you turn on the AT PSU, but you get no video output. This seems like a dead GPU (which works barely enough to get detected but not enough to display). Although the CPU fan not spinning concerns me.
Are you sure the Vio and Vcore of the CPU was set correctly? Those tend to run at 3.3V Voltage I\O (although they can also work with 3.5Vio) and around 2.2V Vcore. Also check if the FSB and multiplier jumpers were set correctly.
Post photos of the PC as others said, alongside the mainboard model.
Also you can try turning on the mainboard with just the CPU and RAM. Check if it beeps about a missing GPU (usually 1 long and 3 short).
POST card is very helpful for these cases (see attachment). They're cheap on ebay, amazon or aliexpress.
I couldn't save them, but that doesn't mean I can't save myself!
Ready yourself!
Reply 9 of 14, by Retro-o
Good Morning,
Apologies for not replying sooner, I work away and haven't had the chance to work on this. I've uploaded a few pictures of the motherboard as requested.
Since my last post I've managed to get a hold of another 'working' AT & ATX PSU. The AT PSU did the same, powered up, power to the CPU fan but nothing else. Interestingly the ATX PSU did the same but also powered up the HDD which kicked into life. Sadly though that was it and the boot sequence / monitor didn't kick in.
Another observation has been that after leaving the power on for a short while, the CPU isn't heating up, neither is anything else on the board apart from the chip that I've highlighted in the yellow circle which is burning hot.
As recommended I've purchased a PC Diagnostic card. Plugging this in to the PCI slots causes the red L.E.D's for the +/- voltage to light up but nothing is showing on the Digit display. The same happens when plugging into the ISA slots.
Look forward to hearing everyone's thoughts and what the next step may be.
Reply 10 of 14, by Retro-o
Here's another picture of the motherboard and the diagnostic card.
Reply 11 of 14, by MikeSG
How long does the circled chip take to become burning hot?
Does the speaker still beep without RAM? Does it beep without a video card?
Have you tried another video card?
Also from my experience when RAM slots or PCI sockets are oxidised (signal is intermittant) they make no warning beeps. Cleaning with isopropyl alcohol & a toothbrush can fix that.
Reply 12 of 14, by mkarcher
Retro-o wrote on 2026-03-02, 09:44:
Do not try to use the card in an ISA slot! The less serious issue is that the ISA interface on that card is only half implemented, if at all, but the more serious issue is that the card is too short to be firmly oriented in an ISA slot, and there is at least one story of a mainboard killed by a copy of that card here on VOGONs. It's fine to use the card in a PCI-slot, though.
Reply 13 of 14, by cyclone3d
That chip that is getting ing burning hot is part of the chipset. It should not be getting super hot... Maybe barely warm, but that is it.
My guess is that it is fried.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 14 of 14, by Unknown_K
I have had a few boards where the chipset chip got very hot because it shorted internally. If your power supply voltages are out of whack that chip will short first.
Here is the data sheet for the chip:
https://dosdays.co.uk/media/ali/M1543_Datasheet.pdf
