Battle of the platforms: socket 754!
Reply 540 of 837, by nd22
The video card used for all 4 systems is the Ati radeon X1950 PRO 512mb that I presented in the beginning. So all 4 platforms have the exact same card!
System 1: nforce3 250GB
Athlon 64 3400
2*1gb DDR400 at 3-3-3-8 CR1T
Abit NF8
WD raptor 150gb
Radeon X1950 PRO
Reply 541 of 837, by nd22
System 2: nforce4
Athlon 64 3400
Abit NV8
Radeon X1950 PRO
Kingston 960gb A400 for system
WD raptor 74gb for storage tests
Reply 542 of 837, by nd22
System 3: ULI M1689
Athlon 64 3400
Abit KU8
Radeon X1950 PRO
Kingston A400 240gb for the system
WD raptor 74gb for hard drive tests
Reply 543 of 837, by nd22
System 4: VIA K8T800 PRO
Athlon 64 3400
Abit KV8 PRO
Radeon X1950 PRO
WD raptor 74gb
Reply 544 of 837, by nd22
As you have seen in the screenshots I used Radeon 10.2 drivers for NVIDIA and VIA systems. However in the case of ULI I had to use OMEGA drivers - latest version - because the system would lock up with any bridged AGP radeons. Tested with X1650 PRO and X1950 PRO. In addition AGP secondary latency timer in the BIOS has to be set to the highest value for the system to boot XP after you installed the omega drivers!
Reply 545 of 837, by AlexZ
With X1950 PRO AGP Quake 4 and FEAR should be playable also on AGP systems as period correct reviews show it to be significantly more powerful than 7600 GT / 7800 GS. It is enough also for NFS Most Wanted 2005, but without full screen anti-aliasing.
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Turion 64 MT-40@2.4Ghz,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2ZS
Phenom II X4 955,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,32GB,GeForce GTX 980 Ti
Reply 546 of 837, by nd22
Before going into chapter 1 I will talk about the problems encountered with radeon cards with the Rialto chip.
Every single NVIDIA card installed without a single problem - be it native AGP such as geforce 5500 or with the HSI bridge such as geforce 7600gt/7800gs. Every single driver - 93.71, 175.19, 197.77 also installed just fine. There are no errors or BSOD's with nvidia video cards; they all work just fine in all the systems.
Now with native AGP radeon cards such as 9600xt that I used when first configuring the systems and installing Windows, the drivers and all the software there were no problems encountered. Stability testing - Pcmark 2005 in a loop - was also fine. No BSOD, no benchmark errors. However with bridged AGP cards I met countless times when the system hang, crashed to desktop for no reason and no entry in the event viewer and subpar performance! I tried several versions from different "drivers family": 6.xx, 7.xx, 8.xx. 9.xx, 10.2, omega. Each time the solution was either something completely unrelated to the graphics card: change the SATA port of the raptor drive for the VIA system!!! for example; or simply installing XP from scratch with the same hardware configuration and it just worked!!!; OR trying all the driver versions i wrote above.
In the end I managed to test all the systems with the official radeon 10.2 drivers - the latest for X1k series that have the best performance after installing and configuring the systems 5 times each!
Also as you have seen in the screenshots I used Raptor 74gb for all the systems - so XP installed all over again - I did not uninstalled nvidia drivers and installed radeon ones - different hard drives so no conflicts between nvidia and radeon drivers.
ULI system is a special case that i already talked about.
Reply 547 of 837, by AlexZ
Problems with AGP cars with PCIe bridge are not limited to ATI. I have 3x GeForce 7600 GT AGP and 2 of them made by MSI didn't like one AGP board which was stable with other cards. I got artifacts while running 3d mark and eventual system crash. The cards didn't show artifacts in BIOS setup. Cards that do that are 99% defective, but if the problem is only in 3d mark then there is hope. These 2 AGP cards ran fine in another socket 462 board. It's best to buy these expensive cards together with board.
Reply 548 of 837, by nd22
I never got any problems with nvidia cards, native AGP or with bridge chips. They just work - on early boards such as VH6/KT7 with a bunch of drivers tested 7600gt still worked, in my old topic when I tested socket A leadtek 7600gt worked in every single board with every single driver!
Reply 549 of 837, by nd22
This is the memory test from Everest with Athlon 64 and the 4 test platforms: there is no difference between Clawhammer and Newcastle.
Reply 550 of 837, by nd22
No back to the results with AGP and PCI-express with the radeon X1950 pro. For easier viewing I selected a particular theme with a certain variation for each platform. Also the order in which they will appear will always be:
1. NVIDIA nforce3 - Windows XP Luna theme - green variation
2. VIA K8T800 PRO - windows XP Luna theme - blue variation
3. ULI M1689 - Windows XP Luna theme - silver variation
4. NVIDIA nforce4 - Windows XP royal theme.
Reply 551 of 837, by nd22
1. Remember that 3 systems use the 10.2 ATI driver - final and the highest performing one for Radeon X1K series while the ULI system is using the Omega drivers -final version! Clawhammer is the first to go under testing!
First test is Code creatures pro, a DirectX 8 benchmark. We start at default settings: 1024*768 no AA, no sound:
1. nforce3
2. VIA
3. ULI
4. nforce4
Reply 552 of 837, by nd22
2. nforce4 is off to a good start! Next - same settings but with sound this time:
1. nforce3
2. VIA
3. ULI
4. nforce4
Reply 553 of 837, by nd22
3. The only quality setting in Code creatures - besides the resolution - is AA, so we enable it and test:
1. nforce3
2. VIA
3. ULI
4. nforce4
Reply 554 of 837, by nd22
4. Same 1024*768 resolution with AA 4X and with sound this time:
1. nforce3
2. VIA
3. ULI
4. nforce4
Reply 555 of 837, by nd22
5. Increasing the resolution to 1280*1024 and the order do not change, nforce4 remains on top even if by a small margin with VIA close behind:
1. nforce3
2. VIA
3. ULI
4. nforce4
Reply 556 of 837, by nd22
6. Same 1280*1024 AA 4X + sound:
1. nforce3
2. VIA
3. ULI
4. nforce4
Reply 557 of 837, by nd22
7. Last resolution: 1600*1200
1. nforce3
2. VIA
3. ULI
4. nforce4
Reply 558 of 837, by nd22
8. Final and most demanding settings: 1600*1200 AA 4X plus sound:
1. nforce3
2. VIA
3. ULI
4. nforce4
Reply 559 of 837, by nd22
NVIDIA has a good start with nforce4: across all resolutions and settings it came on top even if by the thinnest of margins!
