Slow video performance
Reply 40 of 54, by Amigaz
CTCM reports this:
XMM-Version: 3.00 Internal Revision No. : 3.09 HMA available.
available extended Memory : 64443 KBytes.
Largest Block :64443 KBytes.
64443 KBytes requested . Handle = 43090
from addr.: 00111400
CTCM, translated by Thomas Pabst, copyright ct-Mag. V1.5b/t2
Processor-Timing : i486DX,i487DX,i486DX2,am486DX,am486DX2,am486DX4,am5x86
Processor CPUID : am486/ Typ:00 Fam:04 Mod:0F Stp:04
Clck : 129.2 MHz
internal Bus : 32 Bit between CPU and primary Cache or Memory
FPU : i487-Typ
L1 Cache : 8 KByte,4-way associative
L2 Cache : 16 KByte,4-way associative
Write Strategy L1 : Write Back
Write Strategy L2 : Write Back
Dirty Tag L2 : for Assoziativity > 1 not detectable
Through Put & Bus Performance: Main Memory from 00111400
Best Time for 8K MOVSD (Cache /Page Hits) : 44 mcs - 184.2 MByte/s
average t. for 8K MOVSD (Miss + Hit) : 2507 mcs - 3.3 MByte/s
average t. for 8K MOVSD (if clean) : 1262 mcs - 6.5 MByte/s
average t. for 8K MOVSD (if dirty) : 1287 mcs - 6.4 MByte/s
Main Memory 8K MOVSD (Cache misses) : 2507 mcs - 3.3 MByte/s
average with 16 KB L2-Cache /DOS (640K) : 1290 mcs - 6.4 MByte/s
average with 16 KB L2-Cache /WIN (4M ) : 1287 mcs - 6.4 MByte/s
Reply 41 of 54, by leileilol
I don't use a secondary cache for my 486, besides my only COAST module doesn't really work with my similar motherboard chipset either.
p.s. bump the multiplier to 4x, and try to aggressively time your memory as low as you can get while not freezing on soft resets and being able to boot. This greatly helps the am5x86 😀
Reply 42 of 54, by Amigaz
p.s. bump the multiplier to 4x 😀
Wouldn't bother with the L2 cache either if it wasn't for that it makes this PC as slow as my 386DX 40mhz 😜
You have a socket 3 mobo with a coaster slot? if so it's fake...have one too...it's a PC chips board...it's completely L2 cacheless
Reply 43 of 54, by Amigaz
Here's a pic of my cache.
Socketed and as you can see the traces go to the UM8881F chipset
Must be broken cache or chipset then and crap mobo design that doesn't detect it's broken and just ignores it like it was a L2 cacheless board?
Reply 44 of 54, by leileilol
there's your wing commander machine 🤣
Reply 45 of 54, by Amigaz
nah, 386DX 33mhz with some cache is the sweet spot for WC1 😁
It runs a tad to fast on my 386DX 40mhz 128k cache
Reply 46 of 54, by samudra
You need to replace the cache with cache from a known working board before going further. This will rule things out.
Maybe this kind of strange behaviour can result if only the tag piece is broken or something similar.
Reply 47 of 54, by Amigaz
Finally solved this pain-in-the-ass issue
in the end it was just a BIOS issue
I fiddled with turning the cache off in the BIOS....booted...turned it on...booted...nothing happened...did the same again turned off/turned on and my L2 cache just worked (?????) 😜
Now my sys performance is just what you can expect...get a nice score of 8.6 in pcplayer with my Diamond Stealth 64 (S3 vision 968) without univbe
Now I have really seen how much inpact a non active L2 cache can have 😮
The results are quite impressive to what I got before, here a speedsys result:
Reply 48 of 54, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Sounds like you should have cleared your CMOS when upgrading the BIOS
1+1=10
Reply 49 of 54, by Amigaz
Thought I did that....these Phoenix bios'es are a mess....it feels like you have 3 different options to clear the BIOS 😕
Reply 50 of 54, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
The most reliable options are to pull out the battery or use a CMOS clear jumper on the board if present...
1+1=10
Reply 51 of 54, by samudra
w00t
I would still remove the battery to clear the CMOS to clear out other stuff that might still be hanging in there.
Reply 52 of 54, by swaaye
nice work there, eh.
Reply 53 of 54, by Amigaz
Was a big relief to me when I found the solution....it was to weird and unlikely that the cache was broken or tampered with
Now I need to find out why I can make the jachine to stay in non turbo mode 😜
Reply 54 of 54, by fillosaurus
Yes, it booted without the cache module. BTW, it has an UMC VIP (VESA-ISA-PCI) chipset and AMD 5x86/133 CPU. No major drop in performance. Only when I disabled internal cache had big speed loss.
Y2K box: AMD Athlon K75 (second generation slot A)@700, ASUS K7M motherboard, 256 MB SDRAM, ATI Radeon 7500+2xVoodoo2 in SLI, SB Live! 5.1, VIA USB 2.0 PCI card, 40 GB Seagate HDD.
WIP: external midi module based on NEC wavetable (Yamaha clone)
