Open source DOS games
Reply 160 of 169, by twiz11
bocke wrote on 2025-12-05, 06:00:
Another link that might've not been mentioned: https://github.com/gladir/7iles […]
A bunch of game clones in Turbo Pascal (games usually also compile with Freepascal). This repo contains only the source, but the author keeps binaries in separate per game repoes. For example: https://github.com/gladir/MONOPOLY-0. Check out his GitHub profile for more: https://github.com/gladir/.
Language: French, but the games are open source so they can be localized to other languages.
License: MIT.
The attachment monopoly.png is no longer available
The attachment freecell.png is no longer available
The attachment solitaire.png is no longer available
The attachment mahjong.png is no longer available
The attachment billiard.png is no longer available
merci gaston! propriété de monopoly hasbro ?
Reply 161 of 169, by twiz11
bocke wrote on 2025-10-07, 14:17:
Paku-Pac is another Pacman clone for MS-DOS. But author is confused about the license as he used two other projects as inspiration (and borrowed some code from): Pacman by Alex James Macpherson (BSD 3-Clause License) and SP1 sprite library tutorial by Jordi Sesmero (no license noted in the source).
If anyone has time to take a look, you can suggest them your opinion. As is, this is kinda tainted (no clear license).
its gplv2 or later
https://github.com/jsmolina/z88dk-tutorial-sp … utils/bas2tap.c
I work on projects and the BSD 3 clause license is compatible with GPL code, which means the binary must be GPL
Reply 162 of 169, by ludicrous_peridot
Hello. Not sure this has been brought up, but Return of Medusa is Open Source since couple months ago: https://github.com/bubeck/rings-of-medusa. Guess, github contents also put it on the free games and Windows versions of DOS games lists 😀
GA-G41M-Combo G41/ICH7 - Core 2 Quad Q9550 - DDR3 1033 - Radeon RX570 - CMI-8738 - X3MB - CM-300 - Saitek ST-30
Beetle/M/i815+ICH2 - Celeron 566Mhz - Opti 924 - YMF740 - MT-100
https://archive.org/details/peridot-26
Reply 163 of 169, by MrFlibble
ludicrous_peridot wrote on 2025-12-23, 00:29:
Nice catch! I thought I knew about this game but it turns out it was something else.
I see the game was developed on Atari ST and then ported to Amiga and DOS. So technically it's the source for a non-DOS version of a game that also appeared on DOS machines.
Happy Holidays, by the way!
DOS Games Archive | Free open source games | RGB Classic Games
Reply 164 of 169, by ludicrous_peridot
Happy Holiday greetings!
Agree. I was just playing the DOS version of Medusa 2 and was very excited to see that it went opensource and hence posted - only it was not the DOS version that did! Oh well, at least it's great that SDL port is also part of the offering.
Reply 165 of 169, by MrFlibble
Looks like the source code of the rather obscure platform game Toxic Bunny could be downloaded from the dev's website here (kudos to @MAZterXP for making me aware of this game). Bu the Wayback Machine sadly did not preserve the actual file.
Very brief Googling has yielded no results for this one, but the devs made an enhanced remake sometime in the early 2010, and there's a mention of an earlier Java port at SourceForge, but I've not been able to locate the port itself yet (if available at all).
Reply 166 of 169, by twiz11
MrFlibble wrote on 2025-12-24, 21:16:
Nice catch! I thought I knew about this game but it turns out it was something else. […]
its not open source, i couldnt find a license header. looks like its just source available as cool as it looks
Reply 167 of 169, by twiz11
MrFlibble wrote on 2025-12-25, 15:19:
the link is broken, i clicked on download and they never indexed the zip file
Reply 168 of 169, by MrFlibble
twiz11 wrote on 2025-12-26, 01:37:
That's why I wrote the source could be downloaded from their site.
I guess I should have expressed myself more clearly. I edited my post to make it clear that the file is not preserved.
Reply 169 of 169, by rico001
BASIC source code for 1985 Archery.exe game. Code post on internet by games creator: Brian Blankenship. It was originally compiled with the BASCOM compiler.DOS BASIC source. They noted It works pretty well running it with GWBASIC under DOSBOX.
