First post, by fool
I have couple of these 109-63000-00 MAC cards + couple of Xpert 2000 Pro 32MB 64-bit cards.
Atiflash didn't want to read flash from MAC card, so though I was clever and replaced flash chip from Xpert 2000 to MAC-one.
Of course it wasn't so easy. As a result I have ATI Xpert 2000 Pro 8MB with 64-bit membus... I think MAC-card uses the whole 128-bit bus and now BIOS configures it to use only 64-bit and sees only half of the onboard 16MB. Clocks were 120/120 in Xpress 2000 Pro and it that seemes to work.
I tried one or two BIOS from http://www.vgamuseum.info/index.php/cpu/item/ … ti-rage-128-pro but none of them worked with my card - no post after flashing.
I have read many threads about the topic and most of them ends without solution. There is register MEM_BUS_WIDTH (0=64bit, 1=128bit). Before I try to locate it from BIOS dump, does someone have a file I could flash test?
Toshiba T8500 desktop
SAM/CS9233 Wavetable Synthesizer daughterboard
Coming: 40-pin 8MB SIMM kit, CS4232 ISA wavetable sound card
Reply 1 of 3, by douglar
I posted a list of ATI add-in boards here-- https://www.vogonswiki.com/index.php/ATI#ATI_ … e_add-in_boards (please send me corrections & additions)
Your board is a "109-63000-00" which I think was named "Xclaim Dual Rage 128 Pro". "Xclaim" was the name for the mac product line. Not sure what the PC name would be.
If you can find a PC bios for a board with a part number like "109-63000-x0", there's a chance it could work, but I'm not finding any revisions of the board other than "-00", which hurts your chances.
The 8 chip SOJ SDRAM config only seems to appear on the Xclaim cards. 109-63000-10 & 109-72700-02
Reply 2 of 3, by Kahenraz
Did you ever get this working? Also, even with the reduced bus width, does the DVI portion work with the new BIOS?
Reply 3 of 3, by douglar
I picked up a 109-A13600-10. It’s a mac 9600xt die shrink with usb over agp and a 4 pad edge connector for extea power. https://theretroweb.com/expansioncards/s/ati- … n-9600xt-mac-g5
It doesn’t PCI enumerate during plug and play, probably because it has the mac rom. Maybe also because the extra power connectors are not attached. Whatever the case, even if I boot using a pci card, the ati flash program can’t see the card, so I can’t try flashing with a pc rom. Any suggestions on how to flash the rom without desoldering the eeprom.
