First post, by AlessandroB
I have this IBM 300GL computer that comes with a Pentium II 350 (which I replaced with a Pentium III 550 but it's seen as a Pentium II 550), 384MB of RAM (maximum supported) but unfortunately it doesn't have an AGP slot. It has an integrated S3 Trio 3D and obviously ISA and PCI slots. According to my calculations, it should be the computer that sits between the 200MHz Pentium and the 2.8GHz Pentium 4. I'd like to use it in my computer fleet... but without an AGP slot, what can I make it do?
Reply 1 of 19, by jh80
It's probably going to overlap a lot with the other two.
You could put something like a PCI Voodoo 3 in there to cover that era of 3dfx games. But the P4 you have can probably do a lot of those games better, and the Voodoo 3 isn't cheap, so not sure how worth it that would be to you.
You could put an ISA sound card in there and throw late-era DOS games at it that the P1 can't quite handle. Games like Build-engine titles that need a beefy CPU at higher resolutions. There are only a few games like that, though, so again, not worth it unless you're really into those games.
Reply 2 of 19, by dionb
It's a great late DOS system; S3 Trio is exactly the kind of AGP card you'd put in a system like that anyway, so fact it's onboard doesn't matter.
Reply 3 of 19, by AlessandroB
Can you give me some examples of games you think it's perfect for? If I only have this computer with DOS, I wouldn't have a computer with Win98 because I have: 286, 386, DX2, Pentium 60 with DOS, Pentium 200 Windows 95 and Pentium 4 Windows XP. I would miss the computer with Win98.
Reply 4 of 19, by RetroPCCupboard
I think I would put a PCI Riva TNT or TNT M64 in there.
https://ebay.us/m/U9lhD5
It should be good for games up to around 1999 or so.
Reply 5 of 19, by PD2JK
Tiberian Sun / Red Alert 2
Baldur's Gate
Jazz Jackrabbit 2
These games don't require a fast 3D accelerator.
has all kinds of stuff
Reply 6 of 19, by Ydee
RetroPCCupboard wrote on 2025-12-27, 09:03:
I'm afraid this one might not work - I had the same one in Compaq Deskpro EN SFF on BX440 and P2 350 and didn't load the picture. Another one works, the Inno3D TNT2 M64.
Reply 7 of 19, by AlessandroB
I need to find a solution that can fill the gap between the P200 and the P4. Keep in mind that I'm not a fan of first-person shooters like Unreal; I only like historical ones like Doom. I much prefer Red Alert (which I played to the point of boredom) but a computer that can run Need for Speed ​​or Screamer 2, or even something more advanced (but still in the same genre), would be very welcome.
Reply 8 of 19, by RetroPCCupboard
Ydee wrote on 2025-12-27, 10:48:
Hmm. Interesting. I wonder why that one in particular has an issue....
Reply 9 of 19, by theelf
This are great machines, a integrated S3 is best option, exelent support in dos, win3.x and win9x
Latest one have integrated ESS 1938 solo1 even being pci, have great and solid dos support, give a try
Reply 10 of 19, by AlessandroB
theelf wrote on 2025-12-27, 12:42:
I installed a Sound Blaster 64 ISA for use in DOS. But it works fine in Windows too. My only concern was whether the difference between the powerful CPU and the underpowered graphics card would make the computer too unbalanced.
Reply 11 of 19, by theelf
AlessandroB wrote on 2025-12-27, 13:16:
S3 cards are best compatibility, even when i build a latest pentium 3 like 1ghz i use S3 cards
Lot of games and software of time have s3 compatibility in mind, like cirrus
And in win9x have good support for ddraw
In DOS or win9x are some of the best, if you want custom resolutions and tv out 15khz
nvidia, like geforce 4mx are great cards too, cheap and still easy to find in PCI, but without win3x drivers are not a option for me. No win3x no fun
Reply 12 of 19, by RetroPCCupboard
Really depends what you are using it for. I am putting an S3 graphics card with my Athlon 1.4Ghz CPU and ISA soundblaster. It is for an overpowered DOS rig. There are some very demanding DOS games that I am hoping to play on it at 640x480 (or higher). Duke Nukem 3D, system Shock etc.
Reply 13 of 19, by dionb
AlessandroB wrote on 2025-12-27, 08:52:
That Pentium 4 would be a better Windows 98 system - remember that Windows 98 was released in 1998 (as was this computer), but only reached maturity with Win98SE in late 1999, and was only really replaced in the consumer space in late 2001 by Windows XP. A P2-350 runs Win98SE itself fine, but would fail badly at running 2001 games designed for Windows 98 - or even 1999 games like Unreal Tournament. They would far prefer that P4; my main Win98SE system has a P3-1400S and GeForce4Ti, which is as fast as a P4-2000 or so and vastly faster than any P2
In fact I upgraded my late DOS system from K6-2 350 to P3-600 as it was a bit slow in Quake, Fallout, GTA and Master of Magic.
In DOS the video system is just a frame buffer and performance is determined purely by how fast it can get stuff from memory to screen. Generally they will be bottlenecked by the bus - so an S3 Trio AGP will be just as fast as an S3 Virge, Voodoo3 or indeed GeForce FX5500 or so.
Reply 14 of 19, by Ydee
RetroPCCupboard wrote on 2025-12-27, 11:38:
As seller say: "...This Riva TNT graphics card only works with PCI slots that have the 3.3v pins connected, it will most likely not work with older socket 7 or socket 4 motherboards with AT power supplies ..."
Reply 15 of 19, by igna78
I think that to properly exploit your IBM 300GL with CPU upgrade to P3 (considering that it already has a good VGA for 2D graphics) you could install a Voodoo1 or Voodoo2 card (perhaps in this case even a pair in SLI): the system would cover a wide range of 3D accelerated games in DOS and Win98.
Reply 16 of 19, by RetroPCCupboard
Ydee wrote on 2025-12-28, 08:13:
But this is a Pentium II system with ATX power supply I think? Wouldn't that be new enough?
Reply 17 of 19, by Ydee
Even my Deskpro was with ATX PSU, but this card was not working.
I have not investigated where is the problem. Moreover, it is interesting that the card works on the same basis, only a much newer production date (2001? I think, Inno3D)
Reply 18 of 19, by RetroPCCupboard
Ydee wrote on 2025-12-28, 09:47:
Interesting. Good to know! I think I will check out some of my older motherboards and PCs and see if they support 3.3v. I have a compaq Pentium MMX PC which is PCI only, but has ATX power.
I think I had a Riva TNT PCI M64 in there at some point, but I took it out, as the CPU wasn't really fast enough to feed the graphics card. My card looks similar to the one I linked, but I have no idea if it is 3.3v PCI.
Reply 19 of 19, by gerry
finding a specific use for a given machine is really an open ended question, its how you decide to deal with components and constraints really. I used to tune machines more, to be for games or applications or programming - but that's a bit like having a theme. as long as there are not big conflicts a PC s a general purpose machine after all. Just do whatever you enjoy with it 😀
