Abit KT7A (KT133A/VIA686B), Athlon XP Mobile 2500+
Reply 380 of 397, by Windows98_guy
Martin85 wrote on 2025-10-27, 11:23:
Also, right now it has a Radeon 9200 with 128MB. What would be a good period correct graphics card? I have many, from banshees, to voodoo1 and 2, Matrox,...
I mean I have a Radeon 9100, so yours is even better... 😁
Reply 381 of 397, by Windows98_guy
Martin85 wrote on 2025-10-27, 19:36:
BTW: the idea (although it may sound crazy) was to have the creative drive II with the CT4860 (so PCI) and maybe also some roland midi (if I manage to get my hands on it). As what concerns the OS, was thinking about windows ME. 😁
I am aware that this combination might bring some headaches, but want to relive the experience I had when I was 16. 😝
I mean if you want Windows ME that's fine, but try to find appropriate drivers that are specifically for Windows ME and not Windows 98 (unless you want the authentic blue screen experience 😁 ). Look at some videos from Phil's Computer Lab if you need more info on setting up.
Reply 382 of 397, by Shiftyy
Ran into another quirk with my KT7A-RAID.
Under DOS 6.22, I was getting quite noticeable and distracting crackling noises from the MK1869 XTREME (ESS ES1869 and Gravis UltraSound PnP) sound card I am using. It was especially noticeable when playing Duke3D.
The FAQ website by Paul that I linked last page was quite useful for resolving this issue.
It suggested disabling Delay Transaction and PCI master Read Caching in the BIOS. This is done by default with newer BIOS revisions. This reduced the crackling by a little but it didn't fix the issue.
The site also suggested reducing the I/O voltage or overclocking the FSB slightly. In my case, reducing the I/O voltage made it much worse but increasing the I/O voltage by one tick (0.10v) pretty much fixed it. It is night and day compared to before. I MAY hear a random crackle sometimes (I'm not sure if I'm imagining it) but that's very rare, whereas before it was crackling multiple times every few seconds.
I also tried increasing the FSB but that seemed to bring back the crackling even with the above fix. So you may need to adjust both the FSB and I/O voltage to sort it out.
So to summarize, with my Barton-M 2500+, I am using 9x multiplier (With the 5-4 PIN mod, so it's actually set to 17x multiplier), 133 FSB, CPU voltage set to 1.65v (May be able to lower it to somewhere between 1.6v-1.65v, but 1.65v is 100% stable so haven't bothered yet), 3.50v I/O voltage and the rest of the BIOS settings are set to what is recommended on Paul's website.
Reply 383 of 397, by mockingbird
Shiftyy wrote on 2026-01-08, 18:26:
I just about wrapped up my years-long KT7A build last night. I also have an MK1869 with the PCMIDI MPU-401 add-on (though not the extreme version). So I thought "Hey, why not add a NIC -- the finest quality of course", so I went with an Intel 82559 PCI card. I immediately started having issues which I thought I solved by specifying a different IRQ for it in the BIOS (it seemed to demand IRQ 11), but then began the application crashing in Windows. I said to myself "heck no, I can live without a NIC in this thing". I can try something else, but honestly, I have front USB ports (from the motherboard header) so I will use those for any serious data transfer like I always do (I do find the VIA USB to be quite good, thought it is only USB 1.x).
Lesson learned -- rumours about VT8363A (and other VIA) bad PCI compatibility are true, and if you don't need it, don't use it. VT82C686B PCI-ISA bridge is excellent OTOH, and I have no issues at all with my MK1869 (albeit I only tested in Windows, and I have no crackling at all). I am running a Thunderbird 1.4Ghz (at 1.3Ghz). I use Thunderbird because I don't want SSE which I think causes issues with nVidia on this platform. Yes, I sacrifice multiplier throttling, but I don't need that. This is strictly for DirectX 8 gaming on Windows and maybe some DOS on the side.
(Decommissioned:)
Reply 384 of 397, by Shiftyy
mockingbird wrote on 2026-01-12, 14:47:
I have an Intel 82558B NIC in mine and it works without any problems.
Here are the PnP settings I use. This will force the MK1869 to use the correct IRQ/DMA settings:
IRQ-9 > Legacy ISA
IRQ-11 > Legacy ISA
IRQ-15 > Legacy ISA
DMA-6 > Legacy ISA
Also disable anything you don't need such as printer or com ports.
Please note that the above settings are for the XTREME version of the MK1869, but I believe it should work the same for the regular variant.
Reply 385 of 397, by Shiftyy
Also make sure that you enable "Force Update ESCD" after making changes to your PnP settings and install the Via 4in1 chipset drivers and the PCI latency patch by George.
I haven't tested the crackling issues in Windows 9x/XP as I'm using the Audigy 2 ZS for EAX support. The MK1869 XTREME is dedicated to DOS 6.22.
Reply 386 of 397, by mockingbird
Shiftyy wrote on 2026-01-13, 00:10:
Thanks, much appreciated, but I don't want to overload this poor VIA platform with too much complexity. Took enough time to get it stable as it is. I will test with a 3Com NIC just to satisfy your curiosity though 😉.
(Decommissioned:)
Reply 387 of 397, by Shiftyy
Fair enough, but I wouldn't declare this board has PCI problems until you have tried all of the above.
Reply 388 of 397, by mockingbird
Shiftyy wrote on 2026-01-13, 00:50:
So my report with the 3Com (3C905CX-TX-M) is that it works perfectly fine for me on the KT7A, as opposed to the Intel 82559. I will leave it in. Thanks.
(Decommissioned:)
Reply 389 of 397, by swaaye
With 686B, I would be most concerned about silent disk corruption. Maybe using a PCI disk controller would be a workaround. I would probably try to come up with a way to stress and verify the storage subsystem under load (with a game runnning.)
Reply 390 of 397, by Falcosoft
swaaye wrote on 2026-01-16, 19:27:
I have been using an Abit KT7A v1.3 for more than 20 years and I have never experienced disk corruption. I have DOS 6.22 and Win98 SE on the 1st 2 GB FAT16 partition as well as Win XP (SP 0) on the 2nd ~75 GB NTFS partition.
The system also has an SB Live 5.1 but I have the PCI Latency Patch by George E. Breese installed. If I remember correctly such disk corruption could only be reproduced by copying big chunk of data between the 2 IDE channels.
But I also have another disk on the 2nd IDE channel with Tiny Win Vista installed and I copied data between the 2 channels many times without problems.
The attachment Win98.png is no longer available
The attachment WinXP.png is no longer available
Website, Youtube
VST Midi Driver Midi Mapper
Reply 391 of 397, by swaaye
Well maybe you should explore the possibility in depth. It would be interesting. Although so many things can cause disk corruption with Windows 9x. Maybe running an NT OS even prevents the problem.
That's quite the run with a KT7A. I still have the Abit BF6 that I bought in 1999 but it gets used only maybe a few hours a year. I recapped it around 15 years ago! Among the Abit 440BX boards was also the BE6-II, which is the BF6 but with an onboard Highpoint HPT366. A friend had one of those boards. That Highpoint chip was definitely best avoided.
Reply 392 of 397, by Shiftyy
I have been using the HighPoint HPT370 controller on my KT7A-RAID for my data drives. I assume this lets me avoid the 686B issues without needing to waste a PCI slot on a disk controller?
Reply 393 of 397, by swaaye
Shiftyy wrote on 2026-01-17, 04:11:
If the HPT370 works well for you then sure. I think the 370 was fairly solid.
Reply 394 of 397, by Shiftyy
swaaye wrote on 2026-01-17, 04:31:
My only complaint would be it's running a bit slow. Speed tests showed it maxing out at around 60-70MB sec. Being UDMA100 it should be closer to 100MB sec. Though the issue could be the StarTech IDE to SATA adapter I'm using.
The slower speeds doesn't matter in the end.
Reply 395 of 397, by Falcosoft
Shiftyy wrote on 2026-01-17, 05:54:
The same is true for the integrated UDMA100 IDE controller. it is maxing around ~70 MB/sec. The limiting factor is definitely not the HDD since I tried a 256 GB Samsung 860 EVO with the help of a SATA2IDE adapter
(https://www.aliexpress.com/item/1005006917394 … .61761802eDjOA6)
And it produced the same result.
Website, Youtube
Reply 396 of 397, by swaaye
I think the max you can practically move over PCI is 90-100MB/s so that's not so bad. Even running a SSD on UDMA 33 is a great experience on these old systems. The SSD benefit is mostly the ultra fast random read/write performance and access time compared to a HDD.
Reply 397 of 397, by stanwebber
aren't the via 4-in-1 drivers supposed to nerf things slightly so the 686b ide corruption becomes a non-issue?
the hpt-37x has always been a solid performer for me running stripes on 3 separate mfr boards under all flavors of windows. linux compatibility is not so well served, but there are fixes for its quirks if you dig for them.
