Reply 20 of 79, by marxveix
Thanks to you for making this wrapper and all its fixes!
I gladly will test more games,just when is the question.
Manx TT Super Bike fps seems better from screenshot, than some other game. Once i shared XGL200 version that works faster, later on maybe its possible look how this glidetodx6d3d wrapper version gets more fps at its limited 3dfx game support, if its possible to do and take some hints from it.
NFS2SE is totally playable at Rage XL AGP with it and no OC, all max settings just some small ingame screen issues, that you fixed already in your alpha versions. F2 better car look looks better with its shadow at back of the car and most parts look good. Later XGL200 builds gets slower and no visible visual improvements for me. I can share drivers that i use and xgl200 i use.
dgvoodoo setup does not open and i may need dx9 first or some extra files for Win95. Some games start with it, like pandemonium 1 with its glide.dll. Better to install Win98se and try it again. Your Glide2CIF wrapper gets better by every new release and if the game testing helps, i am happy to help more and more, Thank you!
Speed issue can be 3DCIF vs D3D thing? Some games are faster with D3D and slower with 3DCIF.
Turok 1 is one such game, it has its own dll file and it did not get any updated version of it @ CIF.
3DCIF can be and usually is fast, at Tomb Raider example and with 800x600 resolution @30fps.
Not all Game have option to lower the resolution of the Game and 640x480 or 512x384 is good.
I have used also 400x300 and its not that low, but sweet spot is 512 or 640 for me at ATi Rage3.
I use 5.40/2611min or barebone drivers at the moment and i have updated view files tothemax.
I am sure its tiny bit better than driver 2548,that you have used for your glide2cif game testing.
I will try your new glide2cif wrapper version out, thank you!
1. Manx TT Super Bike has 20 to 30 fps with Rage XL AGP and my Celeron PC (latest glide2cif alpha at the moment - for me its v4)
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / GLUT / DVD : ATi RagePro drivers and software
33+MiniGL / OpenGL Win 9x dll files for all ATi-Rage3 based cards : ATi RagePro OpenGL files
