First post, by midgard
Hi all
I'm going to rebuild my PIII 450Mhz slot 1 retro machine based on P2B-S that i'm using for Dos, Windows98 gaming.
I have most parts laying around to build either one below. Which one would you go for?
I do love playing around with ISA cards and SCSI so i'm biased towards the 440BX. Alternative #1 is based on what i run today. CPU gets upgraded here.
My build today is rock solid in i would like to keep it that way.
Alternative #1
Case: Cheiftec Dragon (beige)
MB: Asus P2B-S (good v-regulator, low voltage supported)
CPU: Pentium III Coppermine 850/100mhz FSB, 370 + MSI Slotket V2
PSU: Seasonic Focus 850W
SND: ESS Solo-1 or Sound Blaster 16 ISA on hand
HDD1: IBM UltraIII 68pin 9,1GB (SCSI)
HDD2: 80GB (PATA)
CD1: Pioneer Slot-in DVD (PATA)
CD2 Plextor Plexwriter SCSI
Network: 10/100 3Com
Other: CF>PATA, Gotek
+ Stability (440BX)
+ ISA
+ SCSI
- Speed
- 100Mhz FSB (yes i know, overclockable)
Alternative #2
Case: Chieftec Dragon (beige)
MB: Asus TUSL2-C v1.4
CPU: Pentium III-S 1,4Ghz/133 Tulatin
SND: ESS Solo-1
HDD1: 80GB (PATA)
Network: 3Com 10/100
Other: CF->PATA, Gotek
+ Speed
+ true 133mhz FSB
+ Socket 370 (no slotkets)
- No ISA
- 512MB Ram limit
- No 440BX
What would you do? If you own both? Which one do you love the most?
Are there any gotchas with PSU 5V rail if i'm going for the Tulatin?
Thanks.
Reply 1 of 9, by Jasin Natael
I went i815/Tualatin and compromised on the PCI sound card for my "main" Win98 rig.
The 512MB ram limit isn't really a problem in Win9x.
Vortex has basic DOS compatibility, but I have other machines for that.
The FSB/UDMA and other little niceties and just the fact that it is no hassle and just works was worth it for me.
I relegated my 440BX system running a Nehemiah and SB16 and Geforce3, it's still plenty fast for most things but can slow down when needed.
My 2 cents
Reply 2 of 9, by midgard
Yes the lack of ISA is the biggest gotcha here. SCSI i can always add if i were to go Tulatin.
With that said, ESS Solo-1 has been great for most everything i throwned at it. Should be sufficient but not true OPL.
How do you find the stability of the Tulatin?
Jasin Natael wrote on 2025-12-31, 20:57:
I went i815/Tualatin and compromised on the PCI sound card for my "main" Win98 rig. The 512MB ram limit isn't really a problem […]
My 2 cents
Reply 3 of 9, by NeoG_
midgard wrote on 2025-12-31, 20:44:
I would suggest just upgrading the CPU, epecially if you want to keep high DOS compatibility you'll also want to keep the ISA slots. If you haven't bought the CPU yet you can probably find a 1000Mhz 100FSB chip as well. 850+ P3 is going to be fine for almost anything you want to do on win98.
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
Reply 4 of 9, by midgard
NeoG_ wrote on 2025-12-31, 22:18:
Yes, i need to choose path. I do own a TUSL2-C and a P2B-S so i boils down to either buy a fast Coppermine or a fast Tulatin CPU.
Dos compability and i know the P2B-S is rock solid so i’m leaning that way right now even if owning the fastest Pentium III ever is tempting.
Reply 5 of 9, by Jasin Natael
midgard wrote on 2025-12-31, 21:28:
Yes the lack of ISA is the biggest gotcha here. SCSI i can always add if i were to go Tulatin. […]
My 2 cents
Stability is as fine as any other CPU of the era, if Coppermine is stable for you then I see no reason why Tualatin shouldn't be.
My chip is a 1266 pin modded version, as my board doesn't natively support Tualatin chips. I've had no issues.
Reply 6 of 9, by gerry
i'd choose stability to be honest. If you mean to use it for DOS and 9x software (meaning you kinds of stop around 2001/2) the the p3-850 is more than enough.
There is an assumption there, that you'll play later games and use later applications on some other machine. if that is true then the extra speed from the second option isn't really needed
Reply 7 of 9, by midgard
gerry wrote on 2026-01-02, 14:54:
Yeah that’s a good point. Later means Windows XP and XP has SMP-support, so something like a Athlon64 x2 or Core2Quad would probably be better anyways. Also many XP-games could be made to run on Win11 which defeats the purpose really.
I will probably rebuild my old silver-modded dual Athlon XP rig some day but that would probably be as far as i am willing to go, ever. That MSI K7 Master mobo is very rare though. It ran hot as hell. Had to be run without sidepanels or instant overheat. I think i mostly want to rebuild that just to see if 2003 me did something wrong there. Mayby overvolt, dunno.
Reply 8 of 9, by TheIpex
I'm going through pretty much the same process: 440BX vs i815, Coppermine vs Tualatin. I've also been testing the MSI V2 Slotket with a pin-modded Tualatin CPU in the 440BX board (MSI MS-6163 Pro).
It's stable with the right AGP card; others don't like the overclocked FSB.
I suppose the question is do you really need Tualatin levels of performance for what you plan to do with this PC. Are there any Windows 98 games that an 850-1000MHz Coppermine won't handle well but a Tualatin will? I don't believe so, but I do understand the allure of having the fastest PIII. Not an easy decision.
Intel 486DX2 66MHz
Intel Pentium MMX 233MHz
Intel Pentium III-S 1400MHz
Reply 9 of 9, by midgard
TheIpex wrote on 2026-01-03, 03:37:
Yes, Coppermine goes higher than 850mhz problem is the cost. 850mhz is still ”affordable”
I think the whole point is, as cool as having the last Pentium III is. It’s not worth it. Only reason i consider it is because i happen to have a TUSL2-C in great shape laying around.
Tulatin sits in the transitition period between Windows 98 and Windows XP. Like Coppermine it’s too fast for DOS and too slow for Windows XP. It does lack compability (ISA) compared to Coppermine which is the dealbreaker.
I think the only reason to go Tulatin would be to hotrod it to run on a 440bx like you did, or go VIA chipset to get ISA but that has it’s own issues.
I think with all said i will build something around my trusty Asus P2B-S. Put the fastest Coppermine i can find on it and be happy. The 450mhz Katmai isn’t really holding be back anyway so.
Asus CUBX-E would be endgame. No slotkets to deal with. If i find one for a reasonable price i will gladly pick one up.
