First post, by cydvog
hi, i cant find drivers for AG3450 - HD 3450 - agp, for windows xp 32 bit.
amd driver database has driver but its beta and im unsure to use it.
https://www.amd.com/en/support/downloads/driv … on-hd-3450.html
are there any drivers for this card ? thanks.!
Reply 1 of 10, by NeoG_
https://disk.yandex.com/d/vfgML2Vm3TR4mw/11.x … ly_agp/win_xp32
Try Catalyst 11.5, it should work better than 13.1 for HD3xxx
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
Reply 2 of 10, by marxveix
NeoG_ wrote on 2026-01-02, 08:16:
I have used Takedasuns driver links mostly for Win9x, but i am gona try newer OS also out. Catalyst 7.11 is good driver for older games.
Does Catalyst v7.11 has HD3xxx AGP support is another question, but PCI-E they probably have and Table fog works with Catalyst 7.11.
Someone and someday should backup all these ati drivers and software if it gets lost: https://disk.yandex.com/d/vfgML2Vm3TR4mw
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / DVD : ATi RagePro drivers and software
30+MiniGL / OpenGL Win 9x dll files for all ATi Rage3 cards : Re: ATi RagePro OpenGL files
Reply 3 of 10, by agent_x007
You usually only have to force install driver through device manager (driver for HD 3450 PCIe should work on AGP card).
Unless you want to search for "AGP fix" versions.
Reply 4 of 10, by cydvog
11.5 driver not compatible with xp 32 bit ? i tried many catalyst version but none of them work ?
also catalyst installer not install drivers ? have to use manual install from device manager ?
Reply 5 of 10, by cydvog
also with drivers like 11.5 , 12-6 dxdiag not detect directdraw and direct3d support..
Reply 6 of 10, by gerwin
cydvog wrote on 2026-01-02, 07:53:
I used a very similar card, but in Windows 2000. I suppose the same driver will work in Windows XP.
HD3450 AGP Sapphire Passive (RV620) 512MB DDR2
Driver Version 09.2
https://www.transferxl.com/nl/download/08jd1DcWWXK6dm
Reply 7 of 10, by cydvog
gerwin wrote on 2026-01-03, 21:48:
I used a very similar card, but in Windows 2000. I suppose the same driver will work in Windows XP. HD3450 AGP Sapphire Passive […]
Driver Version 09.2
hi thanks , driver installed but in this zip folder catalyst control panel not exist ? can i install it separately?
Reply 8 of 10, by gerwin
cydvog wrote on 2026-01-03, 22:27:
Maybe I did not have the control panel because it was incompatible with Windows 2000. And maybe I used some other control software. I will check tomorrow.
But if you can find control panel v 09.2, sure you can try.
