How you know that whitelisted games are the only games that run or run well? Glide screensavers, demos, different game versions, patches for the games, community made fixes. I think there are so many to discover, even for limited number of the cif games, some can be unlisted, but still they use cif for sure. Example G-Police uses ati3dcif.dll and this game cant be run with Rage settings if ati3dcif compatible driver is not used and 2xagp/cif version has higher game settings. We may find more working glide games that work at later date, how glide2cif acts if unlisted and not whitelisted well working game uses that glide2cif wrapper version? Some CIF games have Rage Pro detection, but Rage XL/XC AGP also work on CIF and it gets bit harder to get those games to start with CIF normally at XL/XC at every start, one of those games is Turok 1997. I belive that even some new CIF games can be discovered, that has been hidden somehow, it may or may not happen.
Do you have plans to remove 8MB requirement and lower it to 4MB or 6MB, so more cards can start the games?
I could not test the CIF games with Rage2, i have only Rage2+DVD 4MB PCI/Rage2C 4MB AGP, not 8MB version.
If you allow to use glide2cif wrapper file or files on ATi CIF drivers, that would be great add-on to these old ati drivers.
I would gladly add your glide2cif wrapper to my driver at later, more mature version and mentioning your great work!
Like i already mentioned, i can test more Glide Games with Rage2 and Rage3 cards,list of starting and working games.
I can go past 5.40.x/2611 driver with cif,but its more limited then and i need to remember some files that i have used.
Some cif games and demos work with 2mb,but they all work with 4mb cards,4mb and more memory cards are better.
If you make glide2cif glide.dll i can test it also.
Glide.dll (2.11) games, there is probably more.
CyberGladiators
Incubation: Time Is Running Out
MechWarrior 2: 31st Century Combat (OEM 3dfx Edition)
Outlaws (Patch 1.1)
Pandemonium!
POD (Version 2.1.0.0)
Scorched Planet
SimCopter (Patch 1.02)
Speedboat Attack (Version 1.0)
Tigershark (Version 1.0)
Time Warriors
Even if one new games start to work at glide.dll, its maybe worth trying, same goes with glide2x.dll. I would not limit its capablity, just add list of starting/working games and if some new working glide game pops up, then great. Others, if they do not work, they dont work. I just wanted to show some games with errors and some that work and i am sure there is more games that work, because glide game list is very long with official releases and all of its later patches. Its your wrapper and you choice, i am just open to help to make it better as i can, even if only at testing.
Thank you for your amazing work and all your wrappers, all is well always.
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / GLUT / DVD : ATi RagePro drivers and software
33+MiniGL / OpenGL Win 9x dll files for all ATi-Rage3 based cards : ATi RagePro OpenGL files
