First post, by Patriarch K
Hi, 25 years has passed and these bugs still exist in the Lands of Lore 3 which are game breaking bugs. One of the major ones is when you are about to rescue Sionel from the Rulois to progress the talamari quest and enable new skills. However, after rescuing Sionel, she never returns to the guild and you're not able to progress. Similar issue with thieves guild, the Baccanel.
I tried myself last time I played if I could find any flags anywhere or try some reverse engineering. But I don't have those skills.
A possible solution would be to do some "save game editing". For example take a save file before rescuing Sionel and one after, and check which lines in the hex code changed and compare the files to find clues, but I have too little experience for that.
Anyone tried to make some kind of solution to these game breaking bugs?
Sorry if I put this question in the wrong forum. The community is very small for these game series.
- Patriarch K has spoken!
Reply 1 of 9, by Patriarch K
I've tried to perform this save game comparision myself but since there are thousands of hex values changed just by adding a single item to the inventory, it feels quite impossible.
However, what I managed to do was actually to locate the north/south and west/east addresses for the player position. This means you can teleport yourself to restricted areas. I have not tried what happens in the Talamari guild yet, but for future documentation I will add a small guide here and maybe other people will be able to make use of it. Since the door is locked to the room in the Talamari guild with this magic fence, you can never enter the room. But using this teleportation could possibly get you into that room and also out from the room again. Not sure if you can pick up the items or buy them, I have to test that later.
These are the addresses for North and South: (they all have the same value and all of them must be changed at the same time to the new value.)
0058C710
0058C71C
005D4EE4
00600730
00639E60
These are the addresses for west and east: (they all have the same value and all of them must be changed at the same time to the new value)
0058C714
0058C724
005D4EE8
00600734
00639350
1. Download Cheat Engine from here:
https://www.cheatengine.org/
2. Open up the Lands of Lore 3 game
3. Start the game so that you're moving around, or load a specific save state file where you want to enter a locked door.
4. Minimize the game window, ctrl+alt+del and then click on "task manager" was the only way for me to minimize the game.
5. Add the addresses above manually in Cheat Engine by clicking Add Address Manually (they should be found in the green coloured lol3.dat)
6. Try it out by freezing all the addresses. Select all of the added addresses and press Space to lock them
7. Reopen the minimized Lands of Lore 3 again, now your position should be locked and you can't move anymore. Woohoo! Then it works
8. Carefully increase/decrease the numbers. There are 5 addresses per coordinate, so if you want to move north, you need to change the value of all the 5 addresses (select all and press Enter and change number). Then reopen game and player position should have moved.
Well, it's not much, but it's better than anything else since I did not find anything for Lands of Lore 3 on the whole internet apart from some trainer where you can increase HP/Gold/MP or something.
FYI Addresses can also look like this i.e "lol3.dat+18C710" etc etc...
Also, increasing the value by around 5.000.000 (5 million) should be approx 1-2 metres in real world and enough to pass through a door if you stand next to it. I tried it myself and could enter talamari guild immediately without performing the first quest.
Reply 2 of 9, by keenerb
Patriarch K wrote on 2026-01-04, 23:22:
I've tried to perform this save game comparision myself but since there are thousands of hex values changed just by adding a sin […]
0058C710
0058C71C
005D4EE4
00600730
00639E60
0058C714
0058C724
005D4EE8
00600734
00639350
I've always wanted to find out these values for 🤣:GOD. There's a place in the ruins where you can see a small platform and torches faaaaaar across the water that I've always wanted to explore but it appears to be unreachable.
Reply 3 of 9, by Patriarch K
keenerb wrote on 2026-01-05, 03:52:
0058C710
0058C71C
005D4EE4
00600730
00639E60
0058C714
0058C724
005D4EE8
00600734
00639350
Hmm, can't you go with the "boat" (door) to that place? Not sure, but yeah. Should be possible using same mechanism as I used above 😀
Reply 4 of 9, by Patriarch K
I spent some more time with this and found out some more interesting addresses:
lol3.dat+18C4D8 (or 0058C4D8) is controlling the speech of quest givers like dawn (mute or unmute)
lol3.dat+18C560 (or 0058C560) is controlling the speech volume of quest givers like dawn (or any npc?)
lol3.dat+18C53C (or 0058C53C ) is controlling if cleric quest with wild boar is finished. If you lock this one, quest will never be completed
lol3.dat+170B08 (or 00570B08) has something to do with inventory bag or something, not sure and game crashes changing this
lol3.dat+1FA614 (or 005FA614) this seems to control glitter effect animation
lol3.dat+1822E8 (or 005822E8) this seems to control addition of glitter animation on skill and guild tabs
lol3.dat+170A08 (or 00570A08) this is enabling the guild tab hud icon first time
lol3.dat+170A20 (or 00570A20 this is enabling the skill tab hud icon first time
There was also a lot of other interesting addresses that seem to be related to getting completing a quest and getting a new skill. Ultimate goal with this is to enable all the skills from code, since some skills are not possible to get due to the quest bugs. But it all became tedious. I tried a bit with Claude Code, but using free tier version did not work for these kind of analysis. I will add some more interesting addresses here related to completing guild quests and getting new skills (the wild boar quest for clerics guild, just when you get your new cleric skills added to the skill list, some interesting values changed before and after). I'll copy pasted the addresses here just for documentation, in case someone else want to give it an attempt in the future or to give some AI tool some more hints. I'll give up on this now since there seem to be so many variables to change to be able to enable the skills, since game crashes if I don't set all variables properly, at least the teleportation hack is working fine. I was entering all locked doors using that movement manipulation so it works perfectly fine.
Reply 5 of 9, by keenerb
You inspired me to finally seriously explore the x/y memory coordinates of LOL2:GOD. I found the values, and once I get to the Dracoid Ruins I'll finally find out what the heck is across the water...
Reply 6 of 9, by Patriarch K
keenerb wrote on 2026-01-07, 02:53:
Haha, great to hear! Please share your LOL2 memory addresses in this thread so that it's documented (for future AI searches etc). I also might want to check that hidden place behind the river at some point, haha. But don't spoil what the secret is, I wanna check for myself 😁
Reply 7 of 9, by Patriarch K
I just found a thread where some other person did a similar thing a couple of years ago. I'll add all his/her findings here as well since he kept them in images and excel sheets which AI/SEO will not find. So all the creds goes to user "aramsunat" for these additional addresses.
https://www.gog.com/forum/lands_of_lore_serie … her_hacks/page1
Inventory items:
-139 211255104 FFFFFFFF75 0C977F40 Hand Axe 0C977F40:Hand Axe
-139 211255243 FFFFFFFF75 0C977FCB Backbiter 0C977FCB:Backbiter
-139 211255382 FFFFFFFF75 0C978056 Battle Axe 0C978056:Battle Axe
-139 211255521 FFFFFFFF75 0C9780E1 Bone Great Sword 0C9780E1:Bone Great Sword
-139 211255660 FFFFFFFF75 0C97816C Broadsword 0C97816C:Broadsword
-139 211255799 FFFFFFFF75 0C9781F7 Dagger 0C9781F7:Dagger
-139 211255938 FFFFFFFF75 0C978282 Dracoid Dagger 0C978282:Dracoid Dagger
-139 211256077 FFFFFFFF75 0C97830D Emerald Dagger 0C97830D:Emerald Dagger
-139 211256216 FFFFFFFF75 0C978398 Ornamental Longsword 0C978398:Ornamental Longsword
-139 211256355 FFFFFFFF75 0C978423 Gauntlets of Striking 0C978423:Gauntlets of Striking
-139 211256494 FFFFFFFF75 0C9784AE Great Axe Blizzard 0C9784AE:Great Axe Blizzard
-139 211256633 FFFFFFFF75 0C978539 Great Sword Darkstorm 0C978539:Great Sword Darkstorm
-139 211256772 FFFFFFFF75 0C9785C4 Great Sword Firestorm 0C9785C4:Great Sword Firestorm
-139 211256911 FFFFFFFF75 0C97864F Halberd 0C97864F:Halberd
-139 211257050 FFFFFFFF75 0C9786DA Bastion Shield 0C9786DA:Bastion Shield
-139 211257189 FFFFFFFF75 0C978765 Bracers of Valor 0C978765:Bracers of Valor
-139 211257328 FFFFFFFF75 0C9787F0 War Axe Traitor 0C9787F0:War Axe Traitor
-139 211257467 FFFFFFFF75 0C97887B Fire Shield 0C97887B:Fire Shield
-139 211257606 FFFFFFFF75 0C978906 Halberd Bastion 0C978906:Halberd Bastion
-139 211257745 FFFFFFFF75 0C978991 Long Sword 0C978991:Long Sword
-139 211257884 FFFFFFFF75 0C978A1C Platemail Breastplate 0C978A1C:Platemail Breastplate
-139 211258023 FFFFFFFF75 0C978AA7 Obsidian Chainmail 0C978AA7:Obsidian Chainmail
-139 211258162 FFFFFFFF75 0C978B32 Reflective Platemail 0C978B32:Reflective Platemail
-139 211258301 FFFFFFFF75 0C978BBD Ironwood Sap 0C978BBD:Ironwood Sap
-139 211258440 FFFFFFFF75 0C978C48 Coward’s Target Shield 0C978C48:Coward’s Target Shield
-139 211258579 FFFFFFFF75 0C978CD3 DO NOT USE 0C978CD3:DO NOT USE
-139 211258718 FFFFFFFF75 0C978D5E DO NOT USE 0C978D5E:DO NOT USE
-139 211258857 FFFFFFFF75 0C978DE9 DO NOT USE 0C978DE9:DO NOT USE
-139 211258996 FFFFFFFF75 0C978E74 DO NOT USE 0C978E74:DO NOT USE
-139 211259135 FFFFFFFF75 0C978EFF DO NOT USE 0C978EFF:DO NOT USE
-139 211259274 FFFFFFFF75 0C978F8A DO NOT USE 0C978F8A:DO NOT USE
-139 211259413 FFFFFFFF75 0C979015 DO NOT USE 0C979015:DO NOT USE
-139 211259552 FFFFFFFF75 0C9790A0 DO NOT USE 0C9790A0:DO NOT USE
-139 211259691 FFFFFFFF75 0C97912B DO NOT USE 0C97912B:DO NOT USE
-139 211259830 FFFFFFFF75 0C9791B6 DO NOT USE 0C9791B6:DO NOT USE
-139 211259969 FFFFFFFF75 0C979241 DO NOT USE 0C979241:DO NOT USE
-139 211260108 FFFFFFFF75 0C9792CC DO NOT USE 0C9792CC:DO NOT USE
-139 211260247 FFFFFFFF75 0C979357 DO NOT USE 0C979357:DO NOT USE
-139 211260386 FFFFFFFF75 0C9793E2 DO NOT USE 0C9793E2:DO NOT USE
-139 211260525 FFFFFFFF75 0C97946D DO NOT USE 0C97946D:DO NOT USE
-139 211260664 FFFFFFFF75 0C9794F8 DO NOT USE 0C9794F8:DO NOT USE
-139 211260803 FFFFFFFF75 0C979583 DO NOT USE 0C979583:DO NOT USE
-139 211260942 FFFFFFFF75 0C97960E DO NOT USE 0C97960E:DO NOT USE
-139 211261081 FFFFFFFF75 0C979699 DO NOT USE 0C979699:DO NOT USE
-139 211261220 FFFFFFFF75 0C979724 DO NOT USE 0C979724:DO NOT USE
-139 211261359 FFFFFFFF75 0C9797AF DO NOT USE 0C9797AF:DO NOT USE
-139 211261498 FFFFFFFF75 0C97983A DO NOT USE 0C97983A:DO NOT USE
-139 211261637 FFFFFFFF75 0C9798C5 DO NOT USE 0C9798C5:DO NOT USE
-139 211261776 FFFFFFFF75 0C979950 DO NOT USE 0C979950:DO NOT USE
-139 211261915 FFFFFFFF75 0C9799DB Acid Sac 0C9799DB:Acid Sac
-139 211262054 FFFFFFFF75 0C979A66 Ring of Regeneration 0C979A66:Ring of Regeneration
-139 211262193 FFFFFFFF75 0C979AF1 Two-Handed Sword 0C979AF1:Two-Handed Sword
-139 211262332 FFFFFFFF75 0C979B7C Ancient’s Stone 0C979B7C:Ancient’s Stone
-139 211262471 FFFFFFFF75 0C979C07 Fire Crystal 0C979C07:Fire Crystal
-139 211262610 FFFFFFFF75 0C979C92 Dead Fire Crystal 0C979C92:Dead Fire Crystal
-139 211262749 FFFFFFFF75 0C979D1D Lightning Crystal 0C979D1D:Lightning Crystal
-139 211262888 FFFFFFFF75 0C979DA8 Dead Lightning Crystal 0C979DA8:Dead Lightning Crystal
-139 211263027 FFFFFFFF75 0C979E33 Storm Crystal 0C979E33:Storm Crystal
-139 211263166 FFFFFFFF75 0C979EBE Dead Storm Crystal 0C979EBE:Dead Storm Crystal
-139 211263305 FFFFFFFF75 0C979F49 Greater Bezoar Ring 0C979F49:Greater Bezoar Ring
-139 211263444 FFFFFFFF75 0C979FD4 Lesser Bezoar Ring 0C979FD4:Lesser Bezoar Ring
-139 211263583 FFFFFFFF75 0C97A05F Healing Scroll 0C97A05F:Healing Scroll
-139 211263722 FFFFFFFF75 0C97A0EA Jade Dagger 0C97A0EA:Jade Dagger
-139 211263861 FFFFFFFF75 0C97A175 Jeweled Scarab 0C97A175:Jeweled Scarab
-139 211264000 FFFFFFFF75 0C97A200 Short Sword 0C97A200:Short Sword
-139 211264139 FFFFFFFF75 0C97A28B Vel’s Fruit 0C97A28B:Vel’s Fruit
-139 211264278 FFFFFFFF75 0C97A316 Light Crossbow 0C97A316:Light Crossbow
-139 211264417 FFFFFFFF75 0C97A3A1 Heavy Crossbow 0C97A3A1:Heavy Crossbow
-139 211264556 FFFFFFFF75 0C97A42C Valkyrie Crossbow 0C97A42C:Valkyrie Crossbow
-139 211264695 FFFFFFFF75 0C97A4B7 Noble Valkyrie’s Crossbow 0C97A4B7:Noble Valkyrie’s Crossbow
-139 211264834 FFFFFFFF75 0C97A542 Quest Item – Skeleton’s Key 0C97A542:Quest Item – Skeleton’s Key
-139 211264973 FFFFFFFF75 0C97A5CD Tar Crystal 0C97A5CD:Tar Crystal
-139 211265112 FFFFFFFF75 0C97A658 Pyra Pod 0C97A658:Pyra Pod
-139 211265251 FFFFFFFF75 0C97A6E3 Mandrake Root 0C97A6E3:Mandrake Root
-139 211265390 FFFFFFFF75 0C97A76E Dragon Gem 0C97A76E:Dragon Gem
-139 211265529 FFFFFFFF75 0C97A7F9 Colim’s Amulet 0C97A7F9:Colim’s Amulet
-139 211265668 FFFFFFFF75 0C97A884 Pork Chop 0C97A884:Pork Chop
-139 211265807 FFFFFFFF75 0C97A90F Spell - Summon Lesser Imp 0C97A90F:Spell - Summon Lesser Imp
-139 211265946 FFFFFFFF75 0C97A99A Spell - Summon Greater Imp 0C97A99A:Spell - Summon Greater Imp
-139 211266085 FFFFFFFF75 0C97AA25 Spell - Summon Ancient Imp 0C97AA25:Spell - Summon Ancient Imp
-139 211266224 FFFFFFFF75 0C97AAB0 Spell - Summon Imp Lord 0C97AAB0:Spell - Summon Imp Lord
-139 211266363 FFFFFFFF75 0C97AB3B Spell - Banish 0C97AB3B:Spell - Banish
-139 211266502 FFFFFFFF75 0C97ABC6 Spell - Lesser Spark 0C97ABC6:Spell - Lesser Spark
-139 211266641 FFFFFFFF75 0C97AC51 Spell - Greater Spark 0C97AC51:Spell - Greater Spark
-139 211266780 FFFFFFFF75 0C97ACDC Spell - Chain Spark 0C97ACDC:Spell - Chain Spark
-139 211266919 FFFFFFFF75 0C97AD67 Spell - Lightning 0C97AD67:Spell - Lightning
-139 211267058 FFFFFFFF75 0C97ADF2 Spell - Lightning Storm 0C97ADF2:Spell - Lightning Storm
-139 211267197 FFFFFFFF75 0C97AE7D Spell - Lesser Heal 0C97AE7D:Spell - Lesser Heal
-139 211267336 FFFFFFFF75 0C97AF08 Spell - Damage Shield 0C97AF08:Spell - Damage Shield
-139 211267475 FFFFFFFF75 0C97AF93 Spell - Poison Shield 0C97AF93:Spell - Poison Shield
-139 211267614 FFFFFFFF75 0C97B01E Spell - Greater Heal 0C97B01E:Spell - Greater Heal
-139 211267753 FFFFFFFF75 0C97B0A9 Spell - Regeneration 0C97B0A9:Spell - Regeneration
-139 211267892 FFFFFFFF75 0C97B134 Spell - Blind 0C97B134:Spell - Blind
-139 211268031 FFFFFFFF75 0C97B1BF Spell - Invisibility 0C97B1BF:Spell - Invisibility
-139 211268170 FFFFFFFF75 0C97B24A Spell - Hologram 0C97B24A:Spell - Hologram
-139 211268309 FFFFFFFF75 0C97B2D5 Spell - Sunray 0C97B2D5:Spell - Sunray
-139 211268448 FFFFFFFF75 0C97B360 Spell - Trinity 0C97B360:Spell - Trinity
-139 211268587 FFFFFFFF75 0C97B3EB Spell - Lesser Apparition 0C97B3EB:Spell - Lesser Apparition
-139 211268726 FFFFFFFF75 0C97B476 Spell - Greater Apparition 0C97B476:Spell - Greater Apparition
-139 211268865 FFFFFFFF75 0C97B501 Spell - Ghost 0C97B501:Spell - Ghost
-139 211269004 FFFFFFFF75 0C97B58C Spell - Spectral Phantoms 0C97B58C:Spell - Spectral Phantoms
-139 211269143 FFFFFFFF75 0C97B617 Spell - Lich 0C97B617:Spell - Lich
-139 211269282 FFFFFFFF75 0C97B6A2 Spell - Lesser Plasma Bolt 0C97B6A2:Spell - Lesser Plasma Bolt
-139 211269421 FFFFFFFF75 0C97B72D Spell - Greater Plasma Bolt 0C97B72D:Spell - Greater Plasma Bolt
-139 211269560 FFFFFFFF75 0C97B7B8 Spell - Plasma Spray 0C97B7B8:Spell - Plasma Spray
-139 211269699 FFFFFFFF75 0C97B843 Spell - Plasma Wall 0C97B843:Spell - Plasma Wall
-139 211269838 FFFFFFFF75 0C97B8CE Spell - Plasma Form 0C97B8CE:Spell - Plasma Form
-139 211269977 FFFFFFFF75 0C97B959 Spell - Lesser Blades 0C97B959:Spell - Lesser Blades
-139 211270116 FFFFFFFF75 0C97B9E4 Spell - Greater Blades 0C97B9E4:Spell - Greater Blades
-139 211270255 FFFFFFFF75 0C97BA6F Spell - Blade Turret 0C97BA6F:Spell - Blade Turret
-139 211270394 FFFFFFFF75 0C97BAFA Spell - Blade Strike 0C97BAFA:Spell - Blade Strike
-139 211270533 FFFFFFFF75 0C97BB85 Spell - Blade Storm 0C97BB85:Spell - Blade Storm
-139 211270672 FFFFFFFF75 0C97BC10 Spell - Terror 0C97BC10:Spell - Terror
-139 211270811 FFFFFFFF75 0C97BC9B Spell - Lesser Drain 0C97BC9B:Spell - Lesser Drain
-139 211270950 FFFFFFFF75 0C97BD26 Spell - Rage 0C97BD26:Spell - Rage
-139 211271089 FFFFFFFF75 0C97BDB1 Spell - Greater Drain 0C97BDB1:Spell - Greater Drain
-139 211271228 FFFFFFFF75 0C97BE3C Spell - Rune of Terror 0C97BE3C:Spell - Rune of Terror
-139 211271367 FFFFFFFF75 0C97BEC7 Spell - Lesser Light 0C97BEC7:Spell - Lesser Light
-139 211271506 FFFFFFFF75 0C97BF52 Spell - Lesser Light Pulse 0C97BF52:Spell - Lesser Light Pulse
-139 211271645 FFFFFFFF75 0C97BFDD Spell - Greater Light 0C97BFDD:Spell - Greater Light
-139 211271784 FFFFFFFF75 0C97C068 Spell - Greater Light Pulse 0C97C068:Spell - Greater Light Pulse
-139 211271923 FFFFFFFF75 0C97C0F3 Spell - Light Storm 0C97C0F3:Spell - Light Storm
-139 211272062 FFFFFFFF75 0C97C17E Spell - Lesser Shield 0C97C17E:Spell - Lesser Shield
-139 211272201 FFFFFFFF75 0C97C209 Spell - Greater Shield 0C97C209:Spell - Greater Shield
-139 211272340 FFFFFFFF75 0C97C294 Spell - Lesser Magic Shield 0C97C294:Spell - Lesser Magic Shield
-139 211272479 FFFFFFFF75 0C97C31F Spell - Greater Magic Shield 0C97C31F:Spell - Greater Magic Shield
-139 211272618 FFFFFFFF75 0C97C3AA Spell - Warding Shield 0C97C3AA:Spell - Warding Shield
-139 211272757 FFFFFFFF75 0C97C435 Spell - Lesser Firespark 0C97C435:Spell - Lesser Firespark
-139 211272896 FFFFFFFF75 0C97C4C0 Spell - Greater Firespark 0C97C4C0:Spell - Greater Firespark
-139 211273035 FFFFFFFF75 0C97C54B Spell - Lesser Fireball 0C97C54B:Spell - Lesser Fireball
-139 211273174 FFFFFFFF75 0C97C5D6 Spell - Greater Fireball 0C97C5D6:Spell - Greater Fireball
-139 211273313 FFFFFFFF75 0C97C661 Spell - Firestorm 0C97C661:Spell - Firestorm
-139 211273452 FFFFFFFF75 0C97C6EC Spell - Lesser Detonation Sphere 0C97C6EC:Spell - Lesser Detonation Sphere
-139 211273591 FFFFFFFF75 0C97C777 Spell - Lesser Explosive Runes 0C97C777:Spell - Lesser Explosive Runes
-139 211273730 FFFFFFFF75 0C97C802 Spell - Greater Detonation Sphere 0C97C802:Spell - Greater Detonation Sphere
-139 211273869 FFFFFFFF75 0C97C88D Spell – Greater Explosive Runes 0C97C88D:Spell – Greater Explosive Runes
-139 211274008 FFFFFFFF75 0C97C918 Spell – Cataclysm 0C97C918:Spell – Cataclysm
-139 211274147 FFFFFFFF75 0C97C9A3 Spell – Shroud Golem 0C97C9A3:Spell – Shroud Golem
-139 211274286 FFFFFFFF75 0C97CA2E Spell – Shroud Glitterfay 0C97CA2E:Spell – Shroud Glitterfay
-139 211274425 FFFFFFFF75 0C97CAB9 Spell – Shroud Homonculus 0C97CAB9:Spell – Shroud Homonculus
-139 211274564 FFFFFFFF75 0C97CB44 Spell – Shroud Shadow 0C97CB44:Spell – Shroud Shadow
-139 211274703 FFFFFFFF75 0C97CBCF Spell – Enlarge Golem 0C97CBCF:Spell – Enlarge Golem
-139 211274842 FFFFFFFF75 0C97CC5A Spell – Enlarge Glitterfay 0C97CC5A:Spell – Enlarge Glitterfay
-139 211274981 FFFFFFFF75 0C97CCE5 Spell – Enlarge Homonculus 0C97CCE5:Spell – Enlarge Homonculus
-139 211275120 FFFFFFFF75 0C97CD70 Spell – Enlarge Shadow 0C97CD70:Spell – Enlarge Shadow
-139 211275259 FFFFFFFF75 0C97CDFB Spell – Empower Golem 0C97CDFB:Spell – Empower Golem
-139 211275398 FFFFFFFF75 0C97CE86 Spell – Empower Glitterfay 0C97CE86:Spell – Empower Glitterfay
-139 211275537 FFFFFFFF75 0C97CF11 Spell – Empower Homonculus 0C97CF11:Spell – Empower Homonculus
-139 211275676 FFFFFFFF75 0C97CF9C Spell – Empower Shadow 0C97CF9C:Spell – Empower Shadow
-139 211275815 FFFFFFFF75 0C97D027 Spell – Ward Golem 0C97D027:Spell – Ward Golem
-139 211275954 FFFFFFFF75 0C97D0B2 Spell – Ward Glitterfay 0C97D0B2:Spell – Ward Glitterfay
-139 211276093 FFFFFFFF75 0C97D13D Spell – Ward Homonculus 0C97D13D:Spell – Ward Homonculus
-139 211276232 FFFFFFFF75 0C97D1C8 Spell – Ward Shadow 0C97D1C8:Spell – Ward Shadow
-139 211276371 FFFFFFFF75 0C97D253 Spell – Resurrect Golem 0C97D253:Spell – Resurrect Golem
-139 211276510 FFFFFFFF75 0C97D2DE Spell – Resurrect Glitterfay 0C97D2DE:Spell – Resurrect Glitterfay
-139 211276649 FFFFFFFF75 0C97D369 Spell – Resurrect Homonculus 0C97D369:Spell – Resurrect Homonculus
-139 211276788 FFFFFFFF75 0C97D3F4 Spell – Resurrect Shadow 0C97D3F4:Spell – Resurrect Shadow
-139 211276927 FFFFFFFF75 0C97D47F Aloe Biscuit 0C97D47F:Aloe Biscuit
-139 211277066 FFFFFFFF75 0C97D50A Aloe Leaf 0C97D50A:Aloe Leaf
-139 211277205 FFFFFFFF75 0C97D595 Cave Aloe 0C97D595:Cave Aloe
-139 211277344 FFFFFFFF75 0C97D620 Amber 0C97D620:Amber
-139 211277483 FFFFFFFF75 0C97D6AB Arrant Prac 0C97D6AB:Arrant Prac
-139 211277622 FFFFFFFF75 0C97D736 Axe of the Long Arm 0C97D736:Axe of the Long Arm
REFERENCE 211277761 REFERENCE 0C97D7C1 Bag of Rations 0C97D7C1:Bag of Rations
139 211277900 8B 0C97D84C Bag of Rotted Meat 0C97D84C:Bag of Rotted Meat
139 211278039 8B 0C97D8D7 Barbecued Stark 0C97D8D7:Barbecued Stark
139 211278178 8B 0C97D962 Quest Item – Barracks Key 0C97D962:Quest Item – Barracks Key
139 211278317 8B 0C97D9ED Black Lichen 0C97D9ED:Black Lichen
139 211278456 8B 0C97DA78 Blood Aloe 0C97DA78:Blood Aloe
139 211278595 8B 0C97DB03 Bon-Bons 0C97DB03:Bon-Bons
139 211278734 8B 0C97DB8E Bottle of Wine 0C97DB8E:Bottle of Wine
139 211278873 8B 0C97DC19 Quest Item – Brass Clock Key 0C97DC19:Quest Item – Brass Clock Key
139 211279012 8B 0C97DCA4 Quest Item – Broken Toy Sword 0C97DCA4:Quest Item – Broken Toy Sword
139 211279151 8B 0C97DD2F Brook Flounder 0C97DD2F:Brook Flounder
139 211279290 8B 0C97DDBA Cat Ring 0C97DDBA:Cat Ring
139 211279429 8B 0C97DE45 Chainmail Gloves 0C97DE45:Chainmail Gloves
139 211279568 8B 0C97DED0 Chainmail Armor 0C97DED0:Chainmail Armor
139 211279707 8B 0C97DF5B Champion Stone 0C97DF5B:Champion Stone
139 211279846 8B 0C97DFE6 Quest Item – Chesara’s Medallion 0C97DFE6:Quest Item – Chesara’s Medallion
139 211279985 8B 0C97E071 Coco’s Cap 0C97E071:Coco’s Cap
139 211280124 8B 0C97E0FC Crescent Razor 0C97E0FC:Crescent Razor
139 211280263 8B 0C97E187 Crossbow Myriad 0C97E187:Crossbow Myriad
139 211280402 8B 0C97E212 Quest Item - Crystal Device 0C97E212:Quest Item - Crystal Device
139 211280541 8B 0C97E29D Dagger of Light 0C97E29D:Dagger of Light
139 211280680 8B 0C97E328 Dagger of Light – Ranged 0C97E328:Dagger of Light – Ranged
139 211280819 8B 0C97E3B3 Axe of the Long Arm – Ranged 0C97E3B3:Axe of the Long Arm – Ranged
139 211280958 8B 0C97E43E Dark Bow 0C97E43E:Dark Bow
139 211281097 8B 0C97E4C9 Death Sac 0C97E4C9:Death Sac
139 211281236 8B 0C97E554 Death Stroke Shield 0C97E554:Death Stroke Shield
139 211281375 8B 0C97E5DF Quest Item – Dragon Claw Statuette 0C97E5DF:Quest Item – Dragon Claw Statuette
139 211281514 8B 0C97E66A Stone of the Cobra 0C97E66A:Stone of the Cobra
139 211281653 8B 0C97E6F5 Stone of the Gorgon 0C97E6F5:Stone of the Gorgon
139 211281792 8B 0C97E780 Stroke Dagger 0C97E780:Stroke Dagger
139 211281931 8B 0C97E80B Studded Leather Armor 0C97E80B:Studded Leather Armor
139 211282070 8B 0C97E896 Summoning Stone 0C97E896:Summoning Stone
139 211282209 8B 0C97E921 Swampblack Root 0C97E921:Swampblack Root
139 211282348 8B 0C97E9AC Quest Item – The Seal 0C97E9AC:Quest Item – The Seal
139 211282487 8B 0C97EA37 Thohan’s Greatsword 0C97EA37:Thohan’s Greatsword
139 211282626 8B 0C97EAC2 Boom Stick 0C97EAC2:Boom Stick
139 211282765 8B 0C97EB4D Tiger Meat 0C97EB4D:Tiger Meat
139 211282904 8B 0C97EBD8 Quest Item – Toy Sword 0C97EBD8:Quest Item – Toy Sword
139 211283043 8B 0C97EC63 Twin Bow 0C97EC63:Twin Bow
139 211283182 8B 0C97ECEE Valkyrie Charm 0C97ECEE:Valkyrie Charm
139 211283321 8B 0C97ED79 Venom Sac 0C97ED79:Venom Sac
139 211283460 8B 0C97EE04 Vortex Foil 0C97EE04:Vortex Foil
139 211283599 8B 0C97EE8F Vulcan Staff 0C97EE8F:Vulcan Staff
139 211283738 8B 0C97EF1A Vulcan Staff – Ranged 0C97EF1A:Vulcan Staff – Ranged
139 211283877 8B 0C97EFA5 War Cluster 0C97EFA5:War Cluster
139 211284016 8B 0C97F030 War Hammer 0C97F030:War Hammer
139 211284155 8B 0C97F0BB Warstone 0C97F0BB:Warstone
139 211284294 8B 0C97F146 Waterspark Leaf 0C97F146:Waterspark Leaf
139 211284433 8B 0C97F1D1 Wooden Shield 0C97F1D1:Wooden Shield
139 211284572 8B 0C97F25C Dragon Meat 0C97F25C:Dragon Meat
139 211284711 8B 0C97F2E7 Dragonfire Bracers 0C97F2E7:Dragonfire Bracers
139 211284850 8B 0C97F372 Dragon’s Blood 0C97F372:Dragon’s Blood
139 211284989 8B 0C97F3FD Dragonscale Armor 0C97F3FD:Dragonscale Armor
139 211285128 8B 0C97F488 Dragonscale Gauntlets 0C97F488:Dragonscale Gauntlets
139 211285267 8B 0C97F513 Drakelord Gem 0C97F513:Drakelord Gem
139 211285406 8B 0C97F59E Quest Item – Draracle’s Sigil 0C97F59E:Quest Item – Draracle’s Sigil
139 211285545 8B 0C97F629 Dreamshard 0C97F629:Dreamshard
139 211285684 8B 0C97F6B4 Earth Staff 0C97F6B4:Earth Staff
139 211285823 8B 0C97F73F Field Platemail 0C97F73F:Field Platemail
139 211285962 8B 0C97F7CA Fine Bracers 0C97F7CA:Fine Bracers
139 211286101 8B 0C97F855 Fine Leather Armor 0C97F855:Fine Leather Armor
139 211286240 8B 0C97F8E0 Fine Leather Buckler 0C97F8E0:Fine Leather Buckler
139 211286379 8B 0C97F96B Flintskin 0C97F96B:Flintskin
139 211286518 8B 0C97F9F6 Earth Staff – Ranged 0C97F9F6:Earth Staff – Ranged
139 211286657 8B 0C97FA81 Force Pod 0C97FA81:Force Pod
139 211286796 8B 0C97FB0C Full Platemail 0C97FB0C:Full Platemail
139 211286935 8B 0C97FB97 Gargoyle Bracers 0C97FB97:Gargoyle Bracers
139 211287074 8B 0C97FC22 Gauntlets of Might 0C97FC22:Gauntlets of Might
139 211287213 8B 0C97FCAD Gauntlets of Speed 0C97FCAD:Gauntlets of Speed
139 211287352 8B 0C97FD38 Geldenberry 0C97FD38:Geldenberry
139 211287491 8B 0C97FDC3 Gorgonite Nodules 0C97FDC3:Gorgonite Nodules
139 211287630 8B 0C97FE4E Greatbow Shard 0C97FE4E:Greatbow Shard
139 211287769 8B 0C97FED9 Greatbow Shift 0C97FED9:Greatbow Shift
139 211287908 8B 0C97FF64 Quest Item – Head 0C97FF64:Quest Item – Head
139 211288047 8B 0C97FFEF Guardian Orb 0C97FFEF:Guardian Orb
139 211288186 8B 0C98007A Guild Charters 0C98007A:Guild Charters
139 211288325 8B 0C980105 Quest Item – Bacchanal Charter 0C980105:Quest Item – Bacchanal Charter
139 211288464 8B 0C980190 Gummy Pod 0C980190:Gummy Pod
139 211288603 8B 0C98021B Heart of Sunrise 0C98021B:Heart of Sunrise
139 211288742 8B 0C9802A6 Heartstone 0C9802A6:Heartstone
139 211288881 8B 0C980331 Hot Bead 0C980331:Hot Bead
139 211289020 8B 0C9803BC Hound’s Heart 0C9803BC:Hound’s Heart
139 211289159 8B 0C980447 Ice Seed 0C980447:Ice Seed
139 211289298 8B 0C9804D2 Ice Shard 0C9804D2:Ice Shard
139 211289437 8B 0C98055D Iron Rod 0C98055D:Iron Rod
139 211289576 8B 0C9805E8 Iron Shield 0C9805E8:Iron Shield
139 211289715 8B 0C980673 Ivory Chip 0C980673:Ivory Chip
139 211289854 8B 0C9806FE Kelen’s Ring 0C9806FE:Kelen’s Ring
139 211289993 8B 0C980789 Kieran’s Circlet 0C980789:Kieran’s Circlet
139 211290132 8B 0C980814 Kieran’s Circlet – Ranged 0C980814:Kieran’s Circlet – Ranged
139 211290271 8B 0C98089F Quest Item – King’s Writ 0C98089F:Quest Item – King’s Writ
139 211290410 8B 0C98092A Lamplight Eggs 0C98092A:Lamplight Eggs
139 211290549 8B 0C9809B5 Large Flashpot 0C9809B5:Large Flashpot
139 211290688 8B 0C980A40 Leather Armor 0C980A40:Leather Armor
139 211290827 8B 0C980ACB Leather Buckler 0C980ACB:Leather Buckler
139 211290966 8B 0C980B56 Leather Gloves 0C980B56:Leather Gloves
139 211291105 8B 0C980BE1 Life Leech 0C980BE1:Life Leech
139 211291244 8B 0C980C6C Lifestones 0C980C6C:Lifestones
139 211291383 8B 0C980CF7 Longsword Prism 0C980CF7:Longsword Prism
139 211291522 8B 0C980D82 Longbow 0C980D82:Longbow
139 211291661 8B 0C980E0D Lorestone 0C980E0D:Lorestone
139 211291800 8B 0C980E98 Mace 0C980E98:Mace
139 211291939 8B 0C980F23 Magnesium Stone 0C980F23:Magnesium Stone
139 211292078 8B 0C980FAE Mana Bracers 0C980FAE:Mana Bracers
139 211292217 8B 0C981039 Mana Cluster 0C981039:Mana Cluster
139 211292356 8B 0C9810C4 Mana Foil 0C9810C4:Mana Foil
139 211292495 8B 0C98114F Mana Leech 0C98114F:Mana Leech
139 211292634 8B 0C9811DA Mana Mask 0C9811DA:Mana Mask
139 211292773 8B 0C981265 Manastone 0C981265:Manastone
139 211292912 8B 0C9812F0 Mana Pod 0C9812F0:Mana Pod
139 211293051 8B 0C98137B Masque of Shadows 0C98137B:Masque of Shadows
139 211293190 8B 0C981406 Quest Item – Mechanical Eye 0C981406:Quest Item – Mechanical Eye
139 211293329 8B 0C981491 Mimic Stone 0C981491:Mimic Stone
139 211293468 8B 0C98151C Mind Cluster 0C98151C:Mind Cluster
139 211293607 8B 0C9815A7 Mugwort 0C9815A7:Mugwort
139 211293746 8B 0C981632 Mushroom Rot 0C981632:Mushroom Rot
139 211293885 8B 0C9816BD Oculus Pod 0C9816BD:Oculus Pod
139 211294024 8B 0C981748 Orcish Mace 0C981748:Orcish Mace
139 211294163 8B 0C9817D3 Orcish Reaver 0C9817D3:Orcish Reaver
139 211294302 8B 0C98185E Phial of Transfer 0C98185E:Phial of Transfer
139 211294441 8B 0C9818E9 Plasma Staff 0C9818E9:Plasma Staff
139 211294580 8B 0C981974 Plasma Staff – Ranged 0C981974:Plasma Staff – Ranged
139 211294719 8B 0C9819FF Platemail Bracers 0C9819FF:Platemail Bracers
139 211294858 8B 0C981A8A Poison Paint 0C981A8A:Poison Paint
139 211294997 8B 0C981B15 Quicksilver 0C981B15:Quicksilver
139 211295136 8B 0C981BA0 Rainbow Sulfite 0C981BA0:Rainbow Sulfite
139 211295275 8B 0C981C2B Rat Meat 0C981C2B:Rat Meat
139 211295414 8B 0C981CB6 Reaver of the Great Orc 0C981CB6:Reaver of the Great Orc
139 211295553 8B 0C981D41 Ring of Drakefire 0C981D41:Ring of Drakefire
139 211295692 8B 0C981DCC Ring of Reflection 0C981DCC:Ring of Reflection
139 211295831 8B 0C981E57 Rock 0C981E57:Rock
139 211295970 8B 0C981EE2 Quest Item – Ruby of Truth 0C981EE2:Quest Item – Ruby of Truth
139 211296109 8B 0C981F6D Quest Item – Ruloi Hand 0C981F6D:Quest Item – Ruloi Hand
139 211296248 8B 0C981FF8 Sandcrust 0C981FF8:Sandcrust
139 211296387 8B 0C982083 Scavenger Eyes 0C982083:Scavenger Eyes
139 211296526 8B 0C98210E Shard Staff 0C98210E:Shard Staff
139 211296665 8B 0C982199 Shard Staff – Ranged 0C982199:Shard Staff – Ranged
139 211296804 8B 0C982224 Quest Item – Sheet Music 0C982224:Quest Item – Sheet Music
139 211296943 8B 0C9822AF Shimmerfoil 0C9822AF:Shimmerfoil
139 211297082 8B 0C98233A Silver Fang 0C98233A:Silver Fang
139 211297221 8B 0C9823C5 Silver Fang Hilt 0C9823C5:Silver Fang Hilt
139 211297360 8B 0C982450 Silver Leaf 0C982450:Silver Leaf
139 211297499 8B 0C9824DB Skull Key 0C9824DB:Skull Key
139 211297638 8B 0C982566 Small Flashpot 0C982566:Small Flashpot
139 211297777 8B 0C9825F1 Soft Leather Armor 0C9825F1:Soft Leather Armor
139 211297916 8B 0C98267C Soulmeat 0C98267C:Soulmeat
139 211298055 8B 0C982707 Spiked Iron Shield 0C982707:Spiked Iron Shield
139 211298194 8B 0C982792 Spiked Mace 0C982792:Spiked Mace
139 211298333 8B 0C98281D Spirit Staff 0C98281D:Spirit Staff
139 211298472 8B 0C9828A8 Spirit Staff – Ranged 0C9828A8:Spirit Staff – Ranged
139 211298611 8B 0C982933 Staff of Healing 0C982933:Staff of Healing
139 211298750 8B 0C9829BE Stick 0C9829BE:Stick
139 211298889 8B 0C982A49 Stone Bracers 0C982A49:Stone Bracers
139 211299028 8B 0C982AD4 Stone Cube 0C982AD4:Stone Cube
139 211299167 8B 0C982B5F Quest Item – Red Gem 0C982B5F:Quest Item – Red Gem
139 211299306 8B 0C982BEA Quest Item – Blue Gem 0C982BEA:Quest Item – Blue Gem
139 211299445 8B 0C982C75 Quest Item – Violet Gem 0C982C75:Quest Item – Violet Gem
139 211299584 8B 0C982D00 Quest Item – Green Gem 0C982D00:Quest Item – Green Gem
139 211299723 8B 0C982D8B Flashpot Trigger 0C982D8B:Flashpot Trigger
139 211299862 8B 0C982E16 Quest Item – Crystal Device Filled 0C982E16:Quest Item – Crystal Device Filled
139 211300001 8B 0C982EA1 Dagger of the Empty Hand 0C982EA1:Dagger of the Empty Hand
139 211300140 8B 0C982F2C Dagger of the Empty Hand – Ranged 0C982F2C:Dagger of the Empty Hand – Ranged
139 211300279 8B 0C982FB7 Quest Item – Empty Jar 0C982FB7:Quest Item – Empty Jar
139 211300418 8B 0C983042 Quest Item – Tower Key 0C983042:Quest Item – Tower Key
139 211300557 8B 0C9830CD Quest Item – Jar of Oil 0C9830CD:Quest Item – Jar of Oil
<?xml version="1.0" encoding="utf-8"?>
<CheatTable CheatEngineTableVersion="28">
<CheatEntries>
<CheatEntry>
<ID>18</ID>
<Description>"Character Stats"</Description>
<Options moManualExpandCollapse="1"/>
<LastState Value="" RealAddress="00000000"/>
<GroupHeader>1</GroupHeader>
<CheatEntries>
<CheatEntry>
<ID>17</ID>
<Description>"Protection"</Description>
<LastState Value="256" RealAddress="005D50A8"/>
<VariableType>4 Bytes</VariableType>
<Address>005D50A8</Address>
</CheatEntry>
<CheatEntry>
<ID>16</ID>
<Description>"Power"</Description>
<LastState Value="122" RealAddress="005D50A4"/>
<Address>005D50A4</Address>
</CheatEntry>
<CheatEntry>
<ID>3</ID>
<Description>"Max Mana"</Description>
<LastState Value="478" RealAddress="005D5094"/>
<Address>005D5094</Address>
</CheatEntry>
<CheatEntry>
<ID>6</ID>
<Description>"Max Health"</Description>
<LastState Value="202" RealAddress="005D509C"/>
<Address>005D509C</Address>
</CheatEntry>
<CheatEntry>
<ID>4</ID>
<Description>"Current Mana"</Description>
<LastState Value="478" RealAddress="005D5098"/>
<Address>005D5098</Address>
</CheatEntry>
<CheatEntry>
<ID>5</ID>
<Description>"Current Health"</Description>
<LastState Value="202" RealAddress="005D50A0"/>
<Address>005D50A0</Address>
</CheatEntry>
<CheatEntry>
<ID>8</ID>
<Description>"Ancient Magic"</Description>
<LastState Value="311" RealAddress="00570AB9"/>
<Address>lol3.dat+170AB9</Address>
</CheatEntry>
<CheatEntry>
<ID>2</ID>
<Description>"Silver Crowns"</Description>
<LastState Value="20546" RealAddress="005D5149"/>
<Address>lol3.dat+1D5149</Address>
</CheatEntry>
</CheatEntries>
</CheatEntry>
<CheatEntry>
<ID>19</ID>
<Description>"Experience points"</Description>
<CheatEntries>
<CheatEntry>
<ID>20</ID>
<Description>"Wizard Experience"</Description>
<LastState Value="4954" RealAddress="005D50B0"/>
<Address>005D50B0</Address>
</CheatEntry>
<CheatEntry>
<ID>22</ID>
<Description>"Warrior Experience"</Description>
<LastState Value="3338" RealAddress="005D50AC"/>
<Address>005D50AC</Address>
</CheatEntry>
<CheatEntry>
<ID>7</ID>
<Description>"Thief Experience"</Description>
<LastState Value="7342" RealAddress="005D50B8"/>
<Address>lol3.dat+1D50B8</Address>
</CheatEntry>
<CheatEntry>
<ID>21</ID>
<Description>"Cleric Experience"</Description>
<LastState Value="5291" RealAddress="005D50B4"/>
<Address>005d50b4</Address>
</CheatEntry>
</CheatEntries>
</CheatEntry>
<CheatEntry>
<ID>220</ID>
<Description>"Item Hacking"</Description>
<CheatEntries>
<CheatEntry>
<ID>214</ID>
<Description>"Hand Slot Memory Reference"</Description>
<LastState Value="00000000" RealAddress="00585488"/>
<ShowAsHex>1</ShowAsHex>
<Address>lol3.dat+185488</Address>
</CheatEntry>
<CheatEntry>
<ID>219</ID>
<Description>"Inventory Slot 1 Memory Reference"</Description>
<LastState Value="00854F78" RealAddress="00546A58"/>
<Address>00546A58</Address>
</CheatEntry>
<CheatEntry>
<ID>217</ID>
<Description>"Inventory Memory Slot 1 HEX"</Description>
<DropDownList ReadOnly="1" DescriptionOnly="1">0CA2E988:Hand Axe
0CA2EA13:Backbiter
0CA2EA9E:Battle Axe
0CA2EB29:Bone Great Sword
0CA2EBB4:Broadsword
0CA2EC3F:Dagger
0CA2ECCA:Dracoid Dagger
0CA2ED55:Emerald Dagger
0CA2EDE0:Ornamental Longsword
0CA2EE6B:Gauntlets of Striking
0CA2EEF6:Great Axe Blizzard
0CA2EF81:Great Sword Darkstorm
0CA2F00C:Great Sword Firestorm
0CA2F097:Halberd
0CA2F122:Bastion Shield
0CA2F1AD:Bracers of Valor
0CA2F238:War Axe Traitor
0CA2F2C3:Fire Shield
0CA2F34E:Halberd Bastion
0CA2F3D9:Long Sword
0CA2F464:Platemail Breastplate
0CA2F4EF:Obsidian Chainmail
0CA2F57A:Reflective Platemail
0CA2F605:Ironwood Sap
0CA2F690:Coward’s Target Shield
0CA2F71B:DO NOT USE
0CA2F7A6:DO NOT USE
0CA2F831:DO NOT USE
0CA2F8BC:DO NOT USE
0CA2F947:DO NOT USE
0CA2F9D2:DO NOT USE
0CA2FA5D:DO NOT USE
0CA2FAE8:DO NOT USE
0CA2FB73:DO NOT USE
0CA2FBFE:DO NOT USE
0CA2FC89:DO NOT USE
0CA2FD14:DO NOT USE
0CA2FD9F:DO NOT USE
0CA2FE2A:DO NOT USE
0CA2FEB5:DO NOT USE
0CA2FF40:DO NOT USE
0CA2FFCB:DO NOT USE
0CA30056:DO NOT USE
0CA300E1:DO NOT USE
0CA3016C:DO NOT USE
0CA301F7:DO NOT USE
0CA30282:DO NOT USE
0CA3030D:DO NOT USE
0CA30398:DO NOT USE
0CA30423:Acid Sac
0CA304AE:Ring of Regeneration
0CA30539:Two-Handed Sword
0CA305C4:Ancient’s Stone
0CA3064F:Fire Crystal
0CA306DA:Dead Fire Crystal
0CA30765:Lightning Crystal
0CA307F0:Dead Lightning Crystal
0CA3087B:Storm Crystal
0CA30906:Dead Storm Crystal
0CA30991:Greater Bezoar Ring
0CA30A1C:Lesser Bezoar Ring
0CA30AA7:Healing Scroll
0CA30B32:Jade Dagger
0CA30BBD:Jeweled Scarab
0CA30C48:Short Sword
0CA30CD3:Vel’s Fruit
0CA30D5E:Light Crossbow
0CA30DE9:Heavy Crossbow
0CA30E74:Valkyrie Crossbow
0CA30EFF:Noble Valkyrie’s Crossbow
0CA30F8A:Quest Item – Skeleton’s Key
0CA31015:Tar Crystal
0CA310A0:Pyra Pod
0CA3112B:Mandrake Root
0CA311B6:Dragon Gem
0CA31241:Colim’s Amulet
0CA312CC:Pork Chop
0CA31357:Spell - Summon Lesser Imp
0CA313E2:Spell - Summon Greater Imp
0CA3146D:Spell - Summon Ancient Imp
0CA314F8:Spell - Summon Imp Lord
0CA31583:Spell - Banish
0CA3160E:Spell - Lesser Spark
0CA31699:Spell - Greater Spark
0CA31724:Spell - Chain Spark
0CA317AF:Spell - Lightning
0CA3183A:Spell - Lightning Storm
0CA318C5:Spell - Lesser Heal
0CA31950:Spell - Damage Shield
0CA319DB:Spell - Poison Shield
0CA31A66:Spell - Greater Heal
0CA31AF1:Spell - Regeneration
0CA31B7C:Spell - Blind
0CA31C07:Spell - Invisibility
0CA31C92:Spell - Hologram
0CA31D1D:Spell - Sunray
0CA31DA8:Spell - Trinity
0CA31E33:Spell - Lesser Apparition
0CA31EBE:Spell - Greater Apparition
0CA31F49:Spell - Ghost
0CA31FD4:Spell - Spectral Phantoms
0CA3205F:Spell - Lich
0CA320EA:Spell - Lesser Plasma Bolt
0CA32175:Spell - Greater Plasma Bolt
0CA32200:Spell - Plasma Spray
0CA3228B:Spell - Plasma Wall
0CA32316:Spell - Plasma Form
0CA323A1:Spell - Lesser Blades
0CA3242C:Spell - Greater Blades
0CA324B7:Spell - Blade Turret
0CA32542:Spell - Blade Strike
0CA325CD:Spell - Blade Storm
0CA32658:Spell - Terror
0CA326E3:Spell - Lesser Drain
0CA3276E:Spell - Rage
0CA327F9:Spell - Greater Drain
0CA32884:Spell - Rune of Terror
0CA3290F:Spell - Lesser Light
0CA3299A:Spell - Lesser Light Pulse
0CA32A25:Spell - Greater Light
0CA32AB0:Spell - Greater Light Pulse
0CA32B3B:Spell - Light Storm
0CA32BC6:Spell - Lesser Shield
0CA32C51:Spell - Greater Shield
0CA32CDC:Spell - Lesser Magic Shield
0CA32D67:Spell - Greater Magic Shield
0CA32DF2:Spell - Warding Shield
0CA32E7D:Spell - Lesser Firespark
0CA32F08:Spell - Greater Firespark
0CA32F93:Spell - Lesser Fireball
0CA3301E:Spell - Greater Fireball
0CA330A9:Spell - Firestorm
0CA33134:Spell - Lesser Detonation Sphere
0CA331BF:Spell - Lesser Explosive Runes
0CA3324A:Spell - Greater Detonation Sphere
0CA332D5:Spell – Greater Explosive Runes
0CA33360:Spell – Cataclysm
0CA333EB:Spell – Shroud Golem
0CA33476:Spell – Shroud Glitterfay
0CA33501:Spell – Shroud Homonculus
0CA3358C:Spell – Shroud Shadow
0CA33617:Spell – Enlarge Golem
0CA336A2:Spell – Enlarge Glitterfay
0CA3372D:Spell – Enlarge Homonculus
0CA337B8:Spell – Enlarge Shadow
0CA33843:Spell – Empower Golem
0CA338CE:Spell – Empower Glitterfay
0CA33959:Spell – Empower Homonculus
0CA339E4:Spell – Empower Shadow
0CA33A6F:Spell – Ward Golem
0CA33AFA:Spell – Ward Glitterfay
0CA33B85:Spell – Ward Homonculus
0CA33C10:Spell – Ward Shadow
0CA33C9B:Spell – Resurrect Golem
0CA33D26:Spell – Resurrect Glitterfay
0CA33DB1:Spell – Resurrect Homonculus
0CA33E3C:Spell – Resurrect Shadow
0CA33EC7:Aloe Biscuit
0CA33F52:Aloe Leaf
0CA33FDD:Cave Aloe
0CA34068:Amber
0CA340F3:Arrant Prac
0CA3417E:Axe of the Long Arm
0CA34209:Bag of Rations
0CA34294:Bag of Rotted Meat
0CA3431F:Barbecued Stark
0CA343AA:Quest Item – Barracks Key
0CA34435:Black Lichen
0CA344C0:Blood Aloe
0CA3454B:Bon-Bons
0CA345D6:Bottle of Wine
0CA34661:Quest Item – Brass Clock Key
0CA346EC:Quest Item – Broken Toy Sword
0CA34777:Brook Flounder
0CA34802:Cat Ring
0CA3488D:Chainmail Gloves
0CA34918:Chainmail Armor
0CA349A3:Champion Stone
0CA34A2E:Quest Item – Chesara’s Medallion
0CA34AB9:Coco’s Cap
0CA34B44:Crescent Razor
0CA34BCF:Crossbow Myriad
0CA34C5A:Quest Item - Crystal Device
0CA34CE5:Dagger of Light
0CA34D70:Dagger of Light – Ranged
0CA34DFB:Axe of the Long Arm – Ranged
0CA34E86:Dark Bow
0CA34F11:Death Sac
0CA34F9C:Death Stroke Shield
0CA35027:Quest Item – Dragon Claw Statuette
0CA350B2:Stone of the Cobra
0CA3513D:Stone of the Gorgon
0CA351C8:Stroke Dagger
0CA35253:Studded Leather Armor
0CA352DE:Summoning Stone
0CA35369:Swampblack Root
0CA353F4:Quest Item – The Seal
0CA3547F:Thohan’s Greatsword
0CA3550A:Boom Stick
0CA35595:Tiger Meat
0CA35620:Quest Item – Toy Sword
0CA356AB:Twin Bow
0CA35736:Valkyrie Charm
0CA357C1:Venom Sac
0CA3584C:Vortex Foil
0CA358D7:Vulcan Staff
0CA35962:Vulcan Staff – Ranged
0CA359ED:War Cluster
0CA35A78:War Hammer
0CA35B03:Warstone
0CA35B8E:Waterspark Leaf
0CA35C19:Wooden Shield
0CA35CA4:Dragon Meat
0CA35D2F:Dragonfire Bracers
0CA35DBA:Dragon’s Blood
0CA35E45:Dragonscale Armor
0CA35ED0:Dragonscale Gauntlets
0CA35F5B:Drakelord Gem
0CA35FE6:Quest Item – Draracle’s Sigil
0CA36071:Dreamshard
0CA360FC:Earth Staff
0CA36187:Field Platemail
0CA36212:Fine Bracers
0CA3629D:Fine Leather Armor
0CA36328:Fine Leather Buckler
0CA363B3:Flintskin
0CA3643E:Earth Staff – Ranged
0CA364C9:Force Pod
0CA36554:Full Platemail
0CA365DF:Gargoyle Bracers
0CA3666A:Gauntlets of Might
0CA366F5:Gauntlets of Speed
0CA36780:Geldenberry
0CA3680B:Gorgonite Nodules
0CA36896:Greatbow Shard
0CA36921:Greatbow Shift
0CA369AC:Quest Item – Head
0CA36A37:Guardian Orb
0CA36AC2:Guild Charters
0CA36B4D:Quest Item – Bacchanal Charter
0CA36BD8:Gummy Pod
0CA36C63:Heart of Sunrise
0CA36CEE:Heartstone
0CA36D79:Hot Bead
0CA36E04:Hound’s Heart
0CA36E8F:Ice Seed
0CA36F1A:Ice Shard
0CA36FA5:Iron Rod
0CA37030:Iron Shield
0CA370BB:Ivory Chip
0CA37146:Kelen’s Ring
0CA371D1:Kieran’s Circlet
0CA3725C:Kieran’s Circlet – Ranged
0CA372E7:Quest Item – King’s Writ
0CA37372:Lamplight Eggs
0CA373FD:Large Flashpot
0CA37488:Leather Armor
0CA37513:Leather Buckler
0CA3759E:Leather Gloves
0CA37629:Life Leech
0CA376B4:Lifestones
0CA3773F:Longsword Prism
0CA377CA:Longbow
0CA37855:Lorestone
0CA378E0:Mace
0CA3796B:Magnesium Stone
0CA379F6:Mana Bracers
0CA37A81:Mana Cluster
0CA37B0C:Mana Foil
0CA37B97:Mana Leech
0CA37C22:Mana Mask
0CA37CAD:Manastone
0CA37D38:Mana Pod
0CA37DC3:Masque of Shadows
0CA37E4E:Quest Item – Mechanical Eye
0CA37ED9:Mimic Stone
0CA37F64:Mind Cluster
0CA37FEF:Mugwort
0CA3807A:Mushroom Rot
0CA38105:Oculus Pod
0CA38190:Orcish Mace
0CA3821B:Orcish Reaver
0CA382A6:Phial of Transfer
0CA38331:Plasma Staff
0CA383BC:Plasma Staff – Ranged
0CA38447:Platemail Bracers
0CA384D2:Poison Paint
0CA3855D:Quicksilver
0CA385E8:Rainbow Sulfite
0CA38673:Rat Meat
0CA386FE:Reaver of the Great Orc
0CA38789:Ring of Drakefire
0CA38814:Ring of Reflection
0CA3889F:Rock
0CA3892A:Quest Item – Ruby of Truth
0CA389B5:Quest Item – Ruloi Hand
0CA38A40:Sandcrust
0CA38ACB:Scavenger Eyes
0CA38B56:Shard Staff
0CA38BE1:Shard Staff – Ranged
0CA38C6C:Quest Item – Sheet Music
0CA38CF7:Shimmerfoil
0CA38D82:Silver Fang
0CA38E0D:Silver Fang Hilt
0CA38E98:Silver Leaf
0CA38F23:Skull Key
0CA38FAE:Small Flashpot
0CA39039:Soft Leather Armor
0CA390C4:Soulmeat
0CA3914F:Spiked Iron Shield
0CA391DA:Spiked Mace
0CA39265:Spirit Staff
0CA392F0:Spirit Staff – Ranged
0CA3937B:Staff of Healing
0CA39406:Stick
0CA39491:Stone Bracers
0CA3951C:Stone Cube
0CA395A7:Quest Item – Red Gem
0CA39632:Quest Item – Blue Gem
0CA396BD:Quest Item – Violet Gem
0CA39748:Quest Item – Green Gem
0CA397D3:Flashpot Trigger
0CA3985E:Quest Item – Crystal Device Filled
0CA398E9:Dagger of the Empty Hand
0CA39974:Dagger of the Empty Hand – Ranged
0CA399FF:Quest Item – Empty Jar
0CA39A8A:Quest Item – Tower Key
0CA39B15:Quest Item – Jar of Oil
</DropDownList>
<Address>021D4E08</Address>
</CheatEntry>
<CheatEntry>
<ID>218</ID>
<Description>"Inventory Memory Slot 1 DEC"</Description>
<DropDownList DescriptionOnly="1">0CE4D7C1:Bag of Rations
0CE51491:Mimic Stone
0CE518E9:Plasma Staff
</DropDownList>
</CheatEntry>
</CheatEntries>
</CheatEntry>
<CheatEntry>
<ID>247</ID>
<Description>"Location Hacking"</Description>
<CheatEntries>
<CheatEntry>
<ID>246</ID>
<Description>"Copper's X axis location"</Description>
<LastState Value="3033" RealAddress="005D4EE6"/>
<VariableType>2 Bytes</VariableType>
<Address>005D4EE6</Address>
</CheatEntry>
<CheatEntry>
<ID>244</ID>
<Description>"Copper's Y axis location"</Description>
<LastState Value="63581" RealAddress="005D4EEA"/>
<Address>005D4EEA</Address>
</CheatEntry>
<CheatEntry>
<ID>245</ID>
<Description>"Copper's Z axis location"</Description>
<LastState Value="185" RealAddress="005D4EEE"/>
<Address>005D4EEE</Address>
</CheatEntry>
<CheatEntry>
<ID>248</ID>
<Description>"Precise location"</Description>
<CheatEntries>
<CheatEntry>
<ID>243</ID>
<Description>"Copper's X axis location PRECISE"</Description>
<LastState Value="198830431" RealAddress="005D4EE4"/>
<Address>005D4EE4</Address>
</CheatEntry>
<CheatEntry>
<ID>242</ID>
<Description>"Copper's Y axis location PRECISE"</Description>
<LastState Value="4166855447" RealAddress="005D4EE8"/>
<Address>005D4EE8</Address>
</CheatEntry>
<CheatEntry>
<ID>241</ID>
<Description>"Copper's Z axis location PRECISE"</Description>
<LastState Value="12124160" RealAddress="005D4EEC"/>
<Address>005D4EEC</Address>
</CheatEntry>
</CheatEntries>
</CheatEntry>
</CheatEntries>
</CheatEntry>
</CheatEntries>
<UserdefinedSymbols/>
<Comments>03 36 01 00 00 00 00 40 03 00
03 00 00 00 03 00 00 00 03 00 00 00 03
open
01 00 02 00 01 00 02 00 01 00 02 00 01 00 00 00
Closed
03 00 02 00 03 00 02 00 03 00 02 00 03 00 00 00
E1C2B2FF
Open
228 255
Closed
42 00
Grafikai elem?
Open 70
Closed 0
Open
46 00 98 B8 02 0E 38 CD B3 21 82 05 00 00 02 00 10 00 00 00 00 00 AA 79 5B F0 FD 28 00 00 FF FF 00 00 00 00 00 CD DC 09 FF 0D 00 00 00 00 38 00 FF FF 00 00 00 01 00 00 00 00 00 00 B9 FC 00 00 94 F9 00 00 00 00 46 00 46 00 00 00 01 01 01
Closed
00 00 98 B8 02 0E 38 CD B3 21 82 05 00 00 02 00 14 00 00 00 00 00 AA 79 5B F0 FD 28 00 00 FF FF 00 00 00 01 00 CD DC 09 FF 0D 00 00 00 00 38 00 FF FF 00 00 00 01 00 00 00 00 00 00 B9 FC 00 00 94 F9 00 00 46 00 46 00 46 00 46 00 01 01 01
Open
F4 45 C1 0F F0 46 C1 0F EC 47 C1 0F CC DE C3 0F D0 DD C3 0F D8 DB C3 0F E0 D9 C3 0F E8 D7 C3 0F F0 D5 C3 0F F4 D4 C3 0F F8 D3 C3 0F C0 E1 C3 0F C8 DF C3 0F D4 DC C3 0F DC DA C3 0F E4 D8 C3 0F EC D6 C3 0F F8 D3 C3 0F F4 D4 C3 0F F8 D3 C3 0F F4 D4 C3 0F F8 D3 C3 0F F8 D3 C3 0F F8 D3 C3 0F F0 D5 C3 0F F4 D4 C3 0F F8 D3 C3 0F F8 D3 C3 0F D8 DB C3 0F E0 D9 C3 0F E8 D7 C3 0F F0 D5 C3 0F F4 D4 C3 0F F8 D3 C3 0F D0 DD C3 0F D8 DB C3 0F E0 D9 C3 0F E8 D7 C3 0F F0 D5 C3 0F F4 D4 C3 0F F8 D3 C3 0F F0 D5 C3 0F F4 D4 C3 0F F8 D3 C3 0F F8 D3 C3 0F F8 D3 C3 0F F8 D3 C3 0F F0 D5 C3 0F F4 D4 C3 0F F8 D3 C3 0F F4 D4 C3 0F F8 D3 C3 0F F8 D3 C3 0F F8 D3 C3
Closed
64 2A C1 0F 60 2B C1 0F 5C 2C C1 0F C0 20 C4 0F B4 23 C4 0F B8 22 C4 0F 90 ED C3 0F 98 EB C3 0F A0 E9 C3 0F A8 E7 C3 0F B0 E5 C3 0F B8 E3 C3 0F C0 E1 C3 0F C8 DF C3 0F D4 DC C3 0F DC DA C3 0F E4 D8 C3 0F EC D6 C3 0F 00 11 C4 0F 04 10 C4 0F 08 0F C4 0F 0C 0E C4 0F 10 0D C4 0F 14 0C C4 0F 18 0B C4 0F 1C 0A C4 0F 20 09 C4 0F 24 08 C4 0F 28 07 C4 0F 2C 06 C4 0F 30 05 C4 0F 34 04 C4 0F 38 03 C4 0F 3C 02 C4 0F 40 01 C4 0F 44 00 C4 0F 48 FF C3 0F 5C FA C3 0F 94 EC C3 0F 9C EA C3 0F A4 E8 C3 0F AC E6 C3 0F B4 E4 C3 0F BC E2 C3 0F C4 E0 C3 0F CC DE C3 0F D0 DD C3 0F D8 DB C3 0F E0 D9 C3 0F E8 D7 C3 0F F0 D5 C3 0F F4 D4 C3 0F F8 D3 C3 0F F8 D3 C3
Closed
00 00 F0 60 58 00 00 00 00 00 BE 52 39 00 00 00 06 00 00 00 00 00 C8 2E 25 02 86 67 4D 00 00 00 2A 00 B7 A0 78 FF 47 E9 00 00 75 78 FF FF 2B D9 00 00 E0 4E 5D 00 58 44 25 02 00 00 00 00 01 00 01 00 E8 2C 25 02 68 2E 25 02 86 67 4D 00 00 00 2A 00 B7 A0 78 FF 47 E9 00 00 75 78 FF FF 2B D9 00
Open
FF FF F0 60 58 00 00 00 00 00 BE 52 39 00 00 00 06 00 00 00 00 00 58 2F 25 02 4A 5F 64 00 00 00 2A 00 86 67 68 00 47 A9 00 00 D5 26 FF FF 75 78 FF FF E0 4E 5D 00 58 44 25 02 00 00 00 00 01 00 01 00 E8 2C 25 02 18 2D 25 02 4A 5F 64 00 00 00 2A 00 86 67 68 00 47 A9 00 00 D5 26 FF FF 75 78 FF
Closed
FF FF FF FF FF FF FF FF FF 7F 73
Open
FF FF 55 FD 7F 0F 00 00 00 00 73
</Comments>
</CheatTable>
Reply 8 of 9, by keenerb
Patriarch K wrote on 2026-01-07, 13:11:
It's not as simple as a memory address, every time LOL2 boots it assigns a new address to the values. It's some sort of dynamic address allocation.
Need to start a new game, and without moving the character search for "4232445952". It will show up in five or six locations, but the address that ends in 594 that contains that value will be what we're looking for.
XXXXX598, 594 are the x/y coordinates, and XXXXX59C is the Z coordinate FOR THAT PARTICULAR EXECUTION OF 🤣:GOD. This was TREMENDOUSLY annoying to figure out.
I've already gotten into a few places (behind a locked gate, up on a platform in the corner of the starting dungeon water cave area) so far with this, but the game interface freezes if you set a value beyond a wall/try to noclip. If you reset the x/y to a valid value it will resume working though.
Reply 9 of 9, by Patriarch K
keenerb wrote on 2026-01-07, 14:11:
It's not as simple as a memory address, every time LOL2 boots it assigns a new address to the values. It's some sort of dynamic […]
Hmm, strange that LOL2 has dynamic one and LOL3 has a static one. When I found out my addresses, I performed a scan of unknown value first, then moved a little bit forward, searched for increasing values in next scan, moved backwards, searched for decreasing in next scan, moved forwards, searched for increasing again...etc etc...like 10 iterations. Until it was like 300 values left, I froze those values 10 by 10 to see which ones that affected the movement in the game. Maybe you did something similar?
