First post, by Rolo_Ranger
I seem to be having an issue.
Everything runs fine - 6.22 and Win 3.11 boot without issue at startup.
But once I try exiting windows back into DOS i get nothing but a blinking underscore in the top left.
I tried running memmaker after windows install to see if that'd do anything. No luck.
Has anyone else had this issue before?
Reply 1 of 8, by wbahnassi
Yes it happened to me and I'm trying to recall when..
Is it by any chance installed on a FAT32 or is running from a Win95+MSDOS setup?
Turbo XT 12MHz, EGA, MFM HDD
Intel 386 DX-33, Speedstar 24X, SB 1.5, FDDx3
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
IBM BlueLightning 100MHz, CL5428, SB16, 4x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, RTX2060
Reply 2 of 8, by BitWrangler
Have you messed around with mono graphics or copied this windows install from another machine?
It may be that it is returning to the wrong DOS text mode. In that it is returning to a DOS prompt, just not on the hardware you are looking at. Give it a bit until all disk activity seems to have stopped, then type
mode co80
blind at the prompt, press return and see if you get back.
Also if the windows install didn't come off generic disks check you haven't got a win.bat file in your path running win then putting a mode mono in after so it is trying to return to mono.
Reply 3 of 8, by Rolo_Ranger
wbahnassi wrote on 2026-01-06, 17:30:
No, it was a (supposedly) fresh msdos install with Fat16 (albeit, from many years ago)
BUT I see that FDisk /status is reporting back
Disk    Drv    MBytes    Free    Usage
1 16 0 100%
C: 503
and FDISK > selection 4 shows:
Partition    Status    Type           Volume    Label    MBytes    System    Usage
C:1 A PRI DOS DOS 503 FAT16 100%
Total Disk Space is 16 MBytes
That seems odd.
Reply 4 of 8, by Rolo_Ranger
Rolo_Ranger wrote on 2026-01-06, 19:39:
No, it was a (supposedly) fresh msdos install with Fat16 (albeit, from many years ago) […]
1 16 0 100%
C: 503
That seems odd.
Seems something got screwed in the original install if it's only showing 16MB of total disk space.
I reckon a fresh start is probably best bet?
Reply 5 of 8, by BitWrangler
Possibly could happen like that if you partitioned with old version of DOS and did a format /s from newer MSDOS... orrr something. talking about the FAT12 FAT16 thing.
Reply 6 of 8, by myne
Paste Autoexec.
Path?
Comspec?
I built:
Reply 7 of 8, by Rolo_Ranger
I believe the issue stems back to my BIOS. I figured out why DOS FDISK was only reporting 16mb. My hard drive had like 1057 cylinders, MSDOS6.22 only understands up to 1024. My motherboard is pretty old for a 486 and does not appear to support LBA.
Wish I discovered this issue before i wiped everything! But I believe this was the root cause. I backed everything important up anyways.
Reply 8 of 8, by Jo22
Rolo_Ranger wrote on 2026-01-07, 18:33:
1024 cylinders go from 0 to 1023
16 heads go from 0 to 15
63 sectors go from 1 to 63
It depends on the CMOS Setup, however, how the values are interpreted.
Maybe entering 1024 cylinders (total) or 1023 (0 to 1023) is the right thing to do. Same goes for heads (15 or 16).
To be on the safe side, better check the calculated storage capacity.
Entering 1020 cylinders, 16 heads, 63 should also work.
