MartyPC
Reply 600 of 629, by peterfirefly
BinaryDemon wrote on 2026-01-06, 15:04:
What workload/benchmark would you like tested? I always found I had to do a lot of DosBox testing because low end systems would mask performance issues by dropping video frames or audio. Not sure if MartyPC would do the same.
I have a celeron N3350 4gb ram with integrated graphics running Win10. I probably even have some dual core atom thin clients in my basement.
Just having MartyPC boot ordinary DOS with CGA might be a challenge for that machine. Just sitting at the A> prompt with a blinking cursor might be.
This is the microarchitecture:
https://en.wikipedia.org/wiki/Goldmont
It's the first Atom microarchitecture that has out-of-order execution but it isn't very wide or deeep.
This is Intel's page about that specific CPU:
https://www.intel.com/content/www/us/en/produ … ifications.html
Here are Geekbench's scores:
https://browser.geekbench.com/processors/intel-celeron-n3350
For comparison, here's my i3-7100U (Kaby Lake microarch) that used to be on the slower end for MartyPC (older versions):
https://browser.geekbench.com/processors/intel-core-i3-7100u
and my current AMD Ryzen 5 8640HS (Zen 4) that should be very nice (haven't tested MartyPC with it yet):
https://browser.geekbench.com/processors/amd-ryzen-5-8640hs
This is what a Raspberry Pi 5 can deliver:
https://browser.geekbench.com/v6/cpu/9919608
Reply 601 of 629, by BinaryDemon
So I was wrong about the cpu it’s - Celeron N3450 Quadcore 1.1 ghz that can turbo to 2.2ghz
The startup pc speaker beep sounds drawn out.
Alleycat is playable?
Trying to get a benchmark to run but having issues.
So this is probably what GloriousCow would want to see.. 3.55mhz would be a little on the slow side.
The attachment IMG_0741.jpeg is no longer available
Reply 602 of 629, by SoftCat
jal wrote on 2026-01-05, 10:27:
I have a fairly high-end laptop with a Intel Core i7-9750H CPU, which is from 2o19, with both integrated Intel graphics (630) as a discrete NVIDIA Quadra T1000, and MartyPC runs fine.
I see, thanks for the information.
Reply 603 of 629, by SoftCat
I'm interested in what the minimum CPU is for emulating a PC-XT with CGA.
Reply 604 of 629, by BinaryDemon
SoftCat wrote on 2026-01-06, 22:20:
I’ve run XT Emulators (not MartyPC obviously) on ESP VGA32 devices. Those are 240mhz dual core risc chips.
https://youtu.be/BfOZAfTfuOg?si=6IAEmfiUFy9Ul1oX
It evens runs fast (so I guess less accurate).
Reply 606 of 629, by BinaryDemon
SoftCat wrote on 2026-01-06, 22:52:
I'm interested in MartyPC for Windows 10.
Ah, I’d bet modern Celerons could handle it but might want to atleast go i3 to be sure.
Reply 607 of 629, by GloriousCow
I've finally implemented PLL-based monitor emulation, and now I can display your 768x200 mode.
The attachment ega_768.PNG is no longer available
MartyPC: A cycle-accurate IBM PC/XT emulator | web version: https://martypc.net | https://github.com/dbalsom/martypc
Reply 609 of 629, by chjmartin2
I just have to say this without any reservation. MartyPC is awesome. Like what an amazing tool for people who want to write cycle accurate code on 8088's. Chef's kiss to the author man. I have some stuff cooking, it isn't impressive, it is quite derivative but I have had a blast working on it. I couldn't possibly be doing this without Marty as the iteration required to go to hardware is just too high. I am not done, lots more to discover and figure out. I'm using AI to help which has sped up this kind of work considerably and frankly I couldn't get here without it. But, MartyPC is amazing, what a fantastic piece of code that you have generously gifted to the world. I know what it is like to put hours and hours into things and recognizing how amazingly cool they are - and MartyPC is a work of flippin' art man. Kudos to you. Hat's off.
The attachment SonicMar.jpg is no longer available
This is a little preview. It is a total ripoff of Reenigne's CGA model, but novel a bit in that it optimizes all character combinations in the 80x50 mode and uses a Viterbi algo to optimize the lines. Here is the MartyPC output. I have no idea how it will run on bare metal but looks promising.
The attachment sonicmar2.jpg is no longer available
Anyway, I'm still working here and don't feel it is ready for prime-time (and not sure anybody would look at it) but I just had to come here and share my admiration for your project. It's great and I thank you.
Chris
Reply 610 of 629, by SoftCat
Are you planning to emulate the FD1793 (or WD1793) floppy disk drive controller?
Reply 611 of 629, by GloriousCow
chjmartin2 wrote on 2026-06-05, 05:08:
Thanks for the kind words, I'm glad you find it useful!
SoftCat wrote on 2026-06-19, 23:42:
Not anytime soon.
Reply 612 of 629, by GloriousCow
Only tangentially, MartyPC related, I've put a web front end on what I hope will someday be MartyPC's new disassembler.
It currently lacks support for FPU instructions (they will decode as ESC), but I think it's quite useful already. You can select a specific CPU. I don't know if I've seen proper V20 support in a disassembler anywhere else.
Let me know what you think.
https://dasm.martypc.net
Reply 615 of 629, by jal
GloriousCow wrote on 2026-08-14, 01:56:
I've updated https://martypc.net to 0.4.2, now with floppy sounds!
Floppy device sounds or actual floppy sounds? And if the latter, which brand? Mostly floppies were pretty silent, except Nashshshshshshshua.
JAL
Reply 616 of 629, by GloriousCow
jal wrote on 2026-08-14, 11:24:
Both - there are two versions of the motor on sound, one with disk in and one with disk out. There's a slight hiss. I used IMSAI PLUS media from a NOS box off eBay, they're clean and in excellent condition.
You will also hear the disk be inserted and removed as appropriately when you select or eject an image .
Reply 617 of 629, by GloriousCow
Multimonitor support is back and improved - now supporting multi-head configurations in a single window.
Here's 16 monitors on a single CGA card. Silly? Yes.
Each configured display can have independent shader parameters.
The attachment martypc_multimon.png is no longer available
Reply 618 of 629, by GloriousCow
https://martypc.net now has a new launcher.
You can now select your video card up to VGA, and Adlib is now enabled thanks to a new rust-native port of nuked-opl3.
The attachment martypc_net_frontend_02.PNG is no longer available
Reply 619 of 629, by superfury
GloriousCow wrote on 2026-08-20, 20:22:
Cycle-accurate Adlib too (at real 49kHz, like with my emulator)? Last I checked nuked wasn't?
UniPCemu Git repository
