First post, by Gabriel-LG
I have 2 AT cases here, which are nearly identical and both are in dumpster state.
One case has broken plastics, and the cover is severely damaged and scratched. But the frame is in good shape.
The other case's plastic parts are like new and the cover is OK. But the frame is (severely) rusted.
So I would really like to combine the good parts of both cases. And everything fits, except that the threaded holes for screwing on the cover, are in different locations.
So I want to make new threaded holes for the cover. But for drilling and tapping, the material is too thin to get proper thread engagement. Looking at threaded holes in AT(X) cases, they are usually flanged, to create enough surface area, to allow for 2 or 3 threads.
Can I make such flanged holes at home? Are there any alternatives?
Reply 1 of 9, by nali
Maybe by moving the metal like a crater with a punch, before drill a very small hole ?
Than use a screw instead of taping ?
Reply 2 of 9, by StriderTR
I've had success in the past using roll form taps on PC case sheet metal. Perhaps take a look at those. No material loss from drilling means more metal to thread.
DOS, Win9x, General "Retro" Enthusiast. Professional Tinkerer. Technology Hobbyist. Expert at Nothing! Build, Create, Repair, Repeat!
This Old Man's Builds, Projects, and Other Retro Goodness: https://theclassicgeek.blogspot.com/
Reply 3 of 9, by maxtherabbit
nali wrote on 2026-01-08, 21:06:
this is what I would do, use a sheet metal screw instead of the usual 6-32 machine screw
Reply 4 of 9, by paradigital
Can’t you just put a hole where needed and use a correctly threaded nut behind said hole?
Reply 5 of 9, by NeoG_
Rivnuts
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
Reply 6 of 9, by Gabriel-LG
StriderTR wrote on 2026-01-08, 22:55:
Roll form taps are interesting, I did not know about these. Using one of those in a hole like described by Nali could work.
Normally roll forming taps require an exact (large) hole size, but in this case the excess material can be pushed out of the way, forming a flanged hole.
maxtherabbit wrote on 2026-01-08, 23:15:
Even though I am a metrics guy, for some reason the UNC #6-32 screws are part of the PC tinkering experience 😉 so I will try to keep those in. That being said, having a cover actually screws in place is the most important goal.
paradigital wrote on 2026-01-09, 06:19:
Unless I can somehow fixate the nuts, it will spin, making it impossible to screw or unscrew (the nuts will be inaccessible once the cover is on).
NeoG_ wrote on 2026-01-09, 07:18:
Rivnuts
Yes, UNC #6-32 rivnuts exist! This will be my plan B.
Since metric cutting taps are the standard here, I will need to order a (fluteless) roll forming tap from abroad. It will probably take a few weeks to arrive. In the meanwhile I will also order some rivnuts (+ 6-32 bolts, since I do not have a rivnut tool), I think those can be handy to repair stripped threads.
I will keep you posted. Thanks for the suggestions!
Reply 7 of 9, by nali
I just remembered those things exist.
I think they are easy to find, maybe with car parts.
In case the hole is too far from an edge, at least it's wide enough it should hold in place when glued by some epoxy. Maybe cutting them in half before.
Reply 8 of 9, by Gabriel-LG
Last week, I finally got around to fixing my AT case.
Initially I tried to obtain UNC #6-32 rivnuts, but I ended up using M4 instead.
It turned out great an I would definitely recommend them. The manual tool will set you back about €5 and is easy to source.
Here are some pictures of the end result:
The attachment PXL_20260531_104349091.jpg is no longer available
The attachment PXL_20260531_104409090.jpg is no longer available
The attachment PXL_20260531_104011429.jpg is no longer available
The attachment PXL_20260531_104047925.jpg is no longer available
As an added bonus, I also found this, under the EPA sticker 😁
I just love the idea idea of putting a MHz display into my 486
The attachment PXL_20260606_140338500.jpg is no longer available
Reply 9 of 9, by wiretap
Looks good. Rivnuts are the way to go. You can get all different kinds too.. open end, closed end, flush mount, etc. With thin cheap sheet metal, tapping will only get you one or two threads at best -- which of course will strip or cross-thread easily.
For that EnergyStar logo, I think backlighting it with a green LED would be pretty awesome as well. (if the lettering has transparency) The case isn't really from an era where MHz displays were useful anymore.
My Github
Circuit Board Repair Manuals
